Question about Garden
Honda Excell 2600 no pressure and water is leaking from the pump. i believe it's the unloader but can i fix it myself. i'm handy with tools and repairs but do no have the manual.
    Problem Solver:
  • 18 Answers
A manual will not tell you how to replace the unloader if you have the same unloader you will need a pressure gauge to adjust it at 2600 psi and your spike pressure should not exceed 3100psi and the leak at pump you need to check your oil make sure is not milky and if not you will need seals also
Posted on Aug 27, 2010
Grey oil leak and no water pessure
depends on where the oil leaks from , normally a cloudy or "grey" oil sheen ,oozing out from here and there doesnt consern me too much , but now the oil running from the big hole or crack in the housing now that conserns me , make sure unit is "primed" with water (small flow from tip with motor off but hose turned on) if still no good then cycle your unloader a few times by tunring the pressure adjustment all the way up and all the way down with water on and motor runninng , this should work unless you have a larger problem
Feb 20, 2015 | Karcher G 2600 VH 2600 PSI 2.3 GPM 161cc...
How to fix power washer with no pressure with out have to buy the hole pump what can i do to fix it
Cover soap inlet and retry. Mine will not pressurize without soap or without inlet covered.
Jul 22, 2014 | Annovi Reverberi Garden
My honda excel 2600 psi pressure washer do not have any pressure when i squeez the trigger
Trash in, worn or damaged inlet and outlet valves are one possibility. Unloader valve stuck open or badly worn would also cause low pressure. Wrong spray nozzle size is another. Is the nozzle the right size for your pump?
Is water leaking from under the pump? That would show worn high pressure seals.
Apr 13, 2014 | Garden
Honda XR 2600 pressure washer, cord will not pull on engine
This is typically due to the unloader bypass valve not operating properly. You can remove and clean this valve or you may want to replace the valve with a new one.
If you take the high pressure hose off of the pump and with the water turned on you can start the engine each time then you probably should replace the unloader bypass valve.
Here is a link to the pump.
http://www.allpartsinc.com/mmAllParts/Others/A14292-001.pdf
Oct 08, 2012 | Honda Maxus Pressure Washer MX5222
Devilbis Excell pressure washer with Honda engine runs smoothly without wand, but stalls when wand is attached.
If the pressure unloader is not working correctly and/or the nozzle is partially clogged with debris, the engine will be overtasked. Try lowering the pressure by turning the pressure knob to lowest setting and test. If the engine continues to run, gradually increase the pressure. Try using the washer set to about 75% of rated capacity and use max pressure for stubborn stains. Using any machine at max will shorten the life of components. If lowering pressure does not help, then unloader is faulty or stuck. Try storing the unit with oil in the pump. Remove both hoses and infuse oil into water inlet intill all the water is displaced (let set for day or two). Good luck
Sep 27, 2011 | Karcher 2500 PSI Pressure Washer
I have a honda power washer and it will run for about 30 minutes and then start losing pressure,gaining pressure back and losing for about a minute until dying, if i let cool off it will be good for...
Since you did not include a model number.. I have to speak in generic terms. On the output side of the pump there is a high pressure / unloader / bypass valve. There is probably corrosion on the stem of the unloader and the corrosion is causing the stem to stick in the brass stem guide. Remove the unloader valve assy from the output side of the pump. Clean off the corrosion with some scotch brite and the GREASE the stem. (Make sure the input water supply hose is connected but NOT on.) Dump about 2 oz of engine oil into the hole where you removed the unloader valve. Place a liberal amount of grease in the hole where the unloader was then install the unloader valve.
Start the unit but do NOT turn on the water for about 1 minute. Squeeze the power wand knowing full well your going to get oil and grease out of the end of the nozzle for about 45 seconds. Begin cycling the wand trigger rapidly.... multiple times. Your forcing the unloader valve to work.... Then try normal use.
I Not only work on these I have an Excell 2400 with the honda 5.5hp GX 160 engine that just this last weekend I had to do this exact procedure for the same reasons.... It is working like a champ again and it was new in 1997.
Thanks for choosing FixYa,
Kelly
Jun 03, 2011 | Garden
Excell r 2522 presure washer pump rebuild
I like http://www.ppe-pressure-washer-parts.com/excell-vr2522-replacement-parts-pump See pump upgrade and compare to rebuilding. Another good site is www.pressure-washer-parts.com. Piston seals usual begin by overheating from excessive idling. You might add a thermostatic relief valve to help this.
Jul 25, 2010 | Honda Garden
Pump with upgraded pump only getting half power
if you bought a new pump make sure its the correct type
then check for a unloader the adjustment part like a handle or an Allen screw on the head of the pump
dismantle grease up and replace
Aug 02, 2009 | Honda Pressure Washer PSI 3000
Honda excell pressure washer does not have pressure
if the machine is running on suction, ie sucking out of a barrel there may be an air leak on the suction hose or pump. it will pull air easier than pulling water .
put the machine under mains water pressure, hose pipe straight from tap to pump.
check all around the pump and inlet pipes for leaks.
if water leaking this needs rectifiying for it to work on suction.
run the pressure washer while on mains pressure with the hose on, does this make a difference?
if not then probably the unloader is stuck in the pump head. remove unloader , clean and replace it
parts breakdowns are available on the internet for your machine.
possibly valves stuck, or the valve springs have broken, seen this quite few times on these machines. if so replace springs .
These sort of machines do not last very long anyway, about 50 hours use if your lucky.
Jul 22, 2009 | Honda Garden
Garden Logo
373 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
