I have an rca R52WH74 projection TV. It started flickering the screen and then it goes green and black like a negative and sometimes it comes back but other times it just goes blank. We turn it off for a while and then it will come back on but will start doing the same thing again. Is this the bulb that needs replacing
2 Suggested Answers
yammy_alf
  • 666 Answers
SOURCE: RCA 37" FLAT SCREEN NON STOP FLICKERING/FLASHING SCREEN
you need to remove main ckt, (m.board) some part need to re solder specially in hot area. (lost contact i one of the flickering problem you encountered.
Posted on Mar 26, 2010
R52wh74 fades to one color then dark, then black
awewryte,
I have the same TV and now have the identical problem that you described. Did you ever get it fixed or find out what the problem was? If so, will you please pass the information on?
Thanks.
Aug 08, 2009 | RCA Televison & Video
Tv's green light comes on then off three times
Check capacitors cp150 ,114, 120 ,if cp150 is puffed up on top it is bad.2200uf 16v and the other 2 are 220uf 35v.
Feb 11, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
On same Board that you replaced fuse Look at cp 150 if it is puffed up on top it is bad so replace cp150,114,120 one will be 2200u 16v
other 2 caps will be 220uf 35v With tv turned OFF Press and Hold Vol- and CH - at same Time on Front Panel board wait untill set comes on you should now be in Service mode Go to Convergence Try to aline convergence Do Auto converge
Feb 08, 2009 | RCA Televison & Video
With TV OFF Press and hold vol- and ch- at same time untill tv comes back on release you should now be in Service Menu.
Feb 07, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Model R52HW74
that is not fear they should have your info in their system, anyway, If i understand correctly the problem you have a convergence problem, this is a good hd tv you should fix it
Nov 30, 2008 | RCA P52926 52" Rear Projection Television
RCA Model # R52WH74
ALL of you have a problem in power supply/deflection board 3 capacitors open located cp150 2200uf 16volt and two 220uf 35 volt, check them first then resolder around FBT other wise order new deflection board 125.00
Jul 02, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA R52WH74 rear proj 52inch...gets dark and then fades to black
Yes ,your set like so many others is one of RCAs biggest mess i would say if under warranty get to service center fast!!!! other wise you might be one of the lucky ones that only needs power supply broad solder start with Flyback transfomer solder all pins.
May 06, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Really green picture with flashes
Hi...the flickering and the green is the colorwheel going bad. Very common for this model and an easy fix too.
Mar 28, 2008 | RCA HD50LPW42 50" Rear Projection HDTV
Half black screen on projection tv
Sounds like the vertical area like Output, but I would look for bad caps first and resistors. In this area
Sep 14, 2007 | Televison & Video
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
