Question about Dometic RM2652 Refrigerator
I don't currently have a problem, but have recently heard that one shouldn't leave their refer turned off when it is parked for a long while and not in use - like over the winter. This person said they were told to keep the refer running all the time. I don't know what brand of refer they have, but they had to replace theirs, and were told to run it all the time. Does it matter? Is that advice good or bad? Our 5th wheel is a 1997 and we have never run it full time, just when we are out and using it that way. It has never given us any problems.
  • 8,404 Answers
Depends. How often do you travel? Weekly, monthly, once a year?
If you travel frequently, you might as well leave it on. Like all machinery, it likes to run. Start-up and shut-down have costs not necessarily associated with daily operation. When you start it up, there is a shock to the system (the act of heating up - stretching and expanding the system) just as when you shut it down there is a shock to the system (shrinking as it cools). Keeping it on reduces the dampness at the rear of the unit and thus the rust on the exterior as well as the number of times it gets its startup/shutdown shock. There is also something to be said for keeping the amonia solution circulating on the inside. I am not a absorption refrig engineer - I suspect there is benefit to keeping the liquid circulating on the inside of the unit ... though, when these units fail, it is usually attributed to rust blocking the orifice inside the unit. An absorbtion refrig should, in theory, operate forever as there are no moving parts to wear out.
I am on my 4th unit - three Norcold and one Dometic in my 1985 Prowler. We have not taken the unit out 'camping' for more than 15 years, rather, we use it at home for a get-away when it is hot (our house is not AC). Prior to that, we camped at least twice per month April through October. We were ready to go at a moments notice. Now, we keep it full of beverage and snack ready for imprompty picnics and unexpected guests. We usually turn it off in the winter, but not always. We do expect to take our rig out someday in the future ... even though it would be a 'bussmans holiday' for me. It is ready, fully equipped and packed except for bread, milk and eggs.
If you go out once a month for a weekend during the summer and otherwise don't use it ... I would advise you to turn it on a day or so ahead of your departure (to get it running and cold) and secure it when you come home. If you are a frequent traveler ... leave it on during your expected travel season. It will, of course, use electricity (12 volts, 110 volts and or gas) while setting at your storage place. Your frig needs 12 volts for control and it needs either 110 volts or gas to create the heat needed to boil the amonia solution. The 12 volts will come from your battery, even if plugged in.
Keep your battery in good condition. If your battery is original, it is time to replace it. Your battery not only powers your frig and other 12 appliances and lighting in your rig, your emergency brake will not work in the case of break away if your battery is dead. Don't depend on your battery charger to provide a good supply of 12 volts like your battery can. Typically, a battery charger will produce 15 amps of 12 volt power. Your battery will typically supply more than 100 amp hours of power with no outside assistance. Everything just runs better when fully powered by your fully charged battery.
Thank you for your interest in FixYa.com.
If you found my response to your question helpful, the courtesy of a positive response and positive vote will be appreicated.
Thank you
Posted on Aug 23, 2010
  • 909 Answers
Actually, "very good advice". For some unknown reason, when a refrigerator is left to stand, an acidic action seems to take place internally. Most of my repairs in Holiday seasons are housesholders that have turned their refrigerators off. What i suggest to the customers is to buy a cheap 24 hour mechanical timer and set it to 1 hour on, and 4 hours off. just enough to keep the system warm and in operation.(The older the fridge is the more chance it has of becoming a problem if left for long periods).
My 2008 cadillac cts with automatic transmission doesn`t want to go into drive.
Sounds like the shift cable has slipped or stretched when you forced it in reverse. I would check that before removing the trans pan. Make sure to leave the park brake on, Remove the cable from the transmission, usually just one nut. After doing that see if you can shift the transmission with your fingers or a pair of pliers. If so, then the problem is in the cable/linkage and not the trans. Hope this helps
Mar 20, 2014 | Cars & Trucks
My 99 Buick Century's Cooling fans wont turn on automatically when the temperature gauge goes past the half mark, do you know why?
The fans should switch on automatically when the engine temperature reaches the prescribed temperature. Probably around 95C
Feb 17, 2018 | 1999 Buick Century
1990 festiva blows 10 amp but blows fuse after engine staetsfuse everything woeks fine with key in on position
Get a wiring diagram & see what is on that fused
circuit & work that circuit. Leave the fuse out at
first & make sure only that fuse & circuit is involved
When a car gets over 15 years old, then & only
then, do you start to have fuse issues as wiring,
connections,relays,switches & devices using electrical
current, start to get loose,corroded,& develop resistance
I would remove & clean every ground wire on the car you
can find
Both ends of the battery cables as well
Do voltage drops afterwords on cables
Check for alternator diode leakage or what
is called a/c ripple
Check for current draw by putting an amp meter
in series with either battery cable & wait for things
to time out,make sure you leave the doors closed
& allow at least 10 to 15 min.
You shouldn't have over 50 to 70 milli-amps
Just the clock & computer memory & some keep
alive items
Don't keep replacing the fuse,that is not a fix
Nov 13, 2012 | Cars & Trucks
Do I leave the router on all the time. If not will I have to reconnect or just enter my SSID and password to reestablish
you don't have to leave router on all the time. If you set your pc to automatically connect to it, when you turn it on it shouldn't need you to do anything, it should just connect.
Jul 28, 2012 | Linksys Computers & Internet
Heard a pop when I turned on tv and now nothing
don't leave it on and have it looked at---most likely is if it uses a lamp that may be the problem but if not it may be in the power supply.
May 20, 2012 | Sony KDF-E55A20 55 in. LCD Television
1992 Buick Park Avenue ignition switch
remove extra keys from key ring. if helps replace ignition switch . I never heard of the ignition making trunk pop but there s always a first.
Sep 06, 2017 | 1992 Buick Park Avenue
What would cause slack in my timing chain
Not sure which engine this is,but if it has a chain,it most likely has a tensioner,either spring loaded or oil pressure fed.(if you dont see oil everywhere,it's probably spring loaded).These tensioners usually wear out before the chain breaks,but you'll want to replace both at the same time.If the engine was still running decent untill you shut it off,then there shouldn't be any other damage.
Dec 31, 2011 | 2004 Chevrolet Cavalier
My 08impala makes knocking or a clicking sound after I remote start it and then turn key. What is the knocking or clicking sound it sounds like its coming form them where radio is at. Is that my starter...
I have heard this click. It's electrical interference. When you remote start it doesn't turn everything on like the key would. It really shouldn't do this, but it doesn;t seem to hurt anything. If you had the remote installed recently ask the company about it.
May 18, 2011 | 2008 Chevrolet Impala
S type jaguar parking brake warning that brake cannot be applied
Do you mean 'parking brake fault' This message can sometimes appear with low battery causing the electronic park brake to lose its calibration.
To recalibrate it disconnect your battery and leave for 10 Min's. then reconnect and with the ignition on apply the foot brake and whilst keeping applied switch the parking brake on. then release the foot brake turn ignition off - on and the handbrake fault message should be gone and the parking brake should release as you drive off.
IMPORTANT - make sure you have you radio code as you will need this after a battery disconnect.
hope this helps - good luck
Sep 15, 2009 | 2002 Jaguar S-Type
The swifter will not leave park
check the fuse the shift interlock not working
refer to owners manual for fuse location & discription
Dec 13, 2008 | 1997 Suzuki Esteem
Dometic RM2652 Refrigerator Logo
128 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
