Question about Canon PowerShot A540 Digital Camera
Does not work with 8mb memory card. Why not please? Canon A540. Problem occurs when change a 2mb card for a 8mb card. Have not tried anything to fix problem
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
The A540 is designed to work with SD cards. Your 8GB card (I assume you really mean gig, not meg) is actually an SDHC card (SDHC stands for Secure Digital High Capacity). While SDHC cards will fit into SD slots, they will not work in SD devices. You need to keep using SD cards, 2GB and smaller.
Posted on Aug 23, 2010
When putting a Lexar Multi-Use 16 GB SDHC memory card in my Canon Powershot A540 I get Memory Card Error message as well Card Locked message. Have tried unlocking it by the slide on side of card, is t
It's a lost cause. The A540 works with SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work in devices not designed for them. You need to stay with SD cards, 2GB and smaller.
Jan 03, 2013 | Canon PowerShot A540 Digital Camera
Window Vista not recognizing my Canon Power Shot A540 to download
I recommend getting a USB card reader for your memory card.
You should make sure that the camera is on for the transfer. If that doesn't work, try another USB input.
Nov 17, 2012 | Canon PowerShot A540 Digital Camera
I have a canon powershot a540 bought used and i cant not format the memory card
Hi Hello,if your Digital camera and memory card can't format,try to my advice, you get out your memory card to your digital camera,and you can try to reformat your memory using your computer,if the memory card can't format throught using your computer,its mean your memory is need to replace new memory card. hope its work it,thanks
Jul 28, 2011 | Canon PowerShot A540 Digital Camera
Hi, My canon PowerShot A540 camera gives an error " Card locked" Memory card error. I tried switching off the lock, but it didn't help. The card does not get recognized while inserting it in...
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. Other causes include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
You also mention recovering photos saved on the card. If you actually did take pictures with this card (assuming it's a 2GB or less standard SD card, as 4GB SDHC was not designed for your camera), you may be able to recover the photos using recovery software. See this other link.
Jun 10, 2011 | Canon PowerShot A540 Digital Camera
Canon powershot A540 I have tried to erase memory card but it says card locked. How do I unlock.
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Dec 17, 2010 | Canon PowerShot A540 Digital Camera
Memory card locked
When this problem occur you need to set the memory card unlock or not protected. Remove the memory card from camera and you can see a small button in the memory card, so you need to slide that to set the memory card unlock or not protected.
Feb 07, 2010 | Canon PowerShot A540 Digital Camera
A540 says "memory card error" " card locked" but 4gb card is not locked - can access card on card reader - copy on and off. a540 works with 2gb sd card no problem. please help?
The A540 works with SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work in this camera. You need to use SD cards, 2GB and smaller.
Jan 13, 2010 | Canon PowerShot A540 Digital Camera
I need sdc 8m 8mb sd Memory card for Canob zr 300. Can't find it.
if you still need it, i'd be happy to offer you mine. almost brand new (canon SD memory card sdc-8m).
Mar 19, 2009 | Canon ZR300 Mini DV Digital Camcorder
Canon A540 or SD card problem
Hi Rich, This sounds like a problem with filing system of the memory card and is indicative of forthcoming bigger problems. Try remove from the camera and slip into a memory card reader attached to a PC. You have to try and recover as much photos as you can. Thereafter, it may be required to format the memory card either via PC or the format command in the set-up/menu of the camera. Further you can use diagnostic utilities (PC side) to determine if the memory has developed any bad areas. Hope this be of help/idea. Post back how things turns up or should you need additional information. Good luck and kind regards.
Oct 04, 2007 | Canon PowerShot A540 Digital Camera
Canon PowerShot A540 Digital Camera Logo
243 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
