Question about Whirlpool Calypso GVW9959K Top Load Washer
I have the LD 5 flashing. there seems to be a problem with the electronics - switch?
  • 15,935 Answers
The control should flash this error code if it cannot detect the lid switch opening and closing properly.
This error code may also be used if there is a disagreement between the motor and machine controllers on the state of the lid switch.
The control should not allow the unit to run in this condition. This code will also appear if the user presses the START key while the lid is open.
Open the lid or press STOP/CANCEL to clear the display
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 21, 2010
LD is showing.Does not do the washing.When started, it stops and LD shows and just keeps on beeping.
Ld - Long drain - Ld flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets. Press STOP/CANCEL to clear the display.
Mar 13, 2011 | Washing Machines
I have a whirlpool gold catalyst it will not drain water, reading says LD?
LD = Long Drain...  "Ld" flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.  could be a bad pressure switch, the pressure hose, the water pump..  those are good places to start.
Jul 31, 2010 | Whirlpool GSW9800PW Washer
What does "Ld" mean?
Ld
Long Drain
Check for obstructions.
www.appliancehelponline.com
Mar 22, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Ld Long Drain Ld flashes
ld indicates a LONG DRAIN. yo ucan remove the lower panel and clean the filter housing, this will impede the draining abiltiy
Feb 09, 2010 | Kenmore Elite 45986 Front Load Washer
My Duet washer doesn't seem to want to completely drain. I am not getting any error codes and the line seems clear.
Hi There
i found something for you to read to help you out on your problem.Hope this gets you in the right direction.
Ld Long Drain Ld flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.
Press STOP/CANCEL to clear the display. Thank you for writing to fix ya. Merry X-Mass and a Happy New Year.
Best Regards Richard
Dec 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
LD appears. I cannot shut off unless I unplug it
Long Drain you may have a something in the drain hose or drain pump or damaged drain pump.
“Ld” flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.  Press STOP/CANCEL to clear the display.
Sep 19, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
My Whirlpool Cabrio (WTW6600SW1) drains completely then Ld error!
I have a call with the same problem. Pumps all the water out but still flashes LD. Should be the board, The electronic pressure switch is built in to the board. Make sure the pressure chamber on the back right side is not cloged
Aug 10, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
What does LD mean in the LED time screen? it fills for a min then stops and flashes Ld
Jul 28, 2009 | Kenmore Elite 45986 Front Load Washer
Ld error
Good Luck!!
Thanks
Jun 23, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Washer won't empty water....
Ld Long drain "Ld" flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.
Mar 18, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
27 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
