Question about Panasonic PT-53WX42 53" Rear Projection Television
Panasonic problem I am having the same issue with my panasonic...led flashing three times with no picture. Did you ever find a solution? Thanks
  • nyecua Jun 04, 2008
    I had a tech come over the house and said i needed to replace the flyback transformer, any help on how to do that?
  • dtolbert636 Jul 01, 2008
    Led is blinking three times with nothing showing on the screen
Convergence board needs to be replaced. A qualified technician should be able to fix it. Mine cost $180 to fix
Posted on Jun 21, 2008
Pow lite flashes three times it tries to turn on then shuts down
LED 3 times blinks shows problem with convergence out section in TV and may requires convergence out ICs replacement.
If you are familiar with TV repair and can solder parts on PCB then let me know to provide you more technical info.
Thanks.
Jul 23, 2009 | Panasonic PT-53WX53 53" Rear Projection...
When turning on my panasonic cinemavision tv, it makes a click sound then the power button light flashes red three times, no picture comes on the screen, any ideas what should be done?
Most likely a power supply failure although the flashing of the LED a fixed number of times may point to something else such as a lamp failure. If you can find a forum for this series, you may find a Panasonic tech who can give you a better read on this.
Feb 18, 2009 | Toshiba TP55H60 55" Rear Projection...
Standby indicator light on TV flashes - Sony TV
    Please check fisrst that indicator liight (LED) blinks how many times.it could be from 1 to 8 times and the interval would be of three seconds.So, count the led flashes how many times and then tell me i will try my best to find and fix the solution.
Thanks
Nov 17, 2008 | Sony KP-53HS30 53" Rear Projection...
3 months ago Led blinks 7 times now Led blinks 6 times
Sorry to hear that. You could fix it with Best Buy or the warranty service repairman recommended by Panasonic.com
I have a client that had used one of the panasonic repairman to fix the same problem that you have about a year ago,the TV is good ever seen.
I am in the A/V installation business, my recommendation(Pioneer Kuro Plasma TV or Sharp LCD.)Very good track records from my clients.
solutiondoct
Nov 03, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Same problem....
# blinks is the error code for Convergence. You will need to change both Convergence ICs number STK392-110 you can get new ICs at the following link and they provide free instalation instructions with pictures and free tech support on line so you can do the repair yourself. Heres the link
http://servicemanuals.vstore.ca/
May 04, 2008 | Panasonic PT-53WX42 53" Rear Projection...
TV won't turn on
problem is fan stoppage this is probable caused by excessive
dust in fan take off back and locate visually the cooling fans in unit
use canned air to remove dust until fan moves freely. if all fans
are clean maybe one fan is not giving rotation detect signal
look at voltage on white or yellow wire from fan s/b 5v then 0v
when fan rotates if one stays at 5v replace it
Jan 07, 2008 | Panasonic PT-50DL54 50" Rear Projection...
When powered up, no pix and power LED blinks three times
yes there can be ,check the 145 volt . The problem could also be the convergence ic,s These cannot be check other than replacement. The stk392-110 are a problem with a lot of big screens
Apr 18, 2007 | Panasonic PT-47WXC43 47" Rear Projection...
Panasonic PT-53WX42 53" Rear Projection Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
