Question about Dryers
Dryer door is shut tight, but do signal flashes and dryer will not start. previous load ran just fine.
  • Dryers Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 12, 2010
The Dryer won't start. Power light just flashes red on and off
There are too many problems that it could be, anything from the Button going bad, to the Door Shut Switch being defective, to the Motor, Relay inside the circuit board, to loose wire during the move, and the list goes on and on. Unless you can test each component that sends the START signal, nobody will be able to assist you with the information you have provided.
Mar 01, 2014 | Hotpoint Ariston AWD129 Front Load...
Dryer wont turn on
Lots of things it could be. I'd try the shut-off switch first.
There is a switch that is supposed to turn off the dryer when you open the door.
That switch is often made of plastic, and can break or even fall out inside the machine.
After that, I'd check the start switch to see if it failed.
Be blessed.
Feb 17, 2013 | Crosley CDE6000 Electric Dryer
My dryer ran fine with my last load of only 3 towels. I haven't had any problems with my dryer before. I went to "wrinkle release" my towels and nothing happened. No lights, no 18min. showed...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
heatman101
Aug 03, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Dryer doesnt work at alll you push the start
make sure the door is shut good nd tight check the breaker for 220 volts
Jul 11, 2009 | Frigidaire FEX831CS Top Load Stacked...
LEQ2152ES 2005 dryer shuts off when start us pushed
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Jun 14, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Dryer will not cycle
Replace the belt and all will work fine. The belt spins the drum
Feb 09, 2009 | KitchenAid KEYS700LQ Electric Dryer
GE Dryer Will not start
possible door switch broke when uou shut it back also ck wiring diagram under console for thermal fuse in motor circuit
Jul 24, 2008 | Dryers
Whirlpool Electric dryer E1
An E1 Code is a thermistor fault TEST #3a Thermistor Test
The machine control electronics monitors the
exhaust temperature using the thermistor, and
cycles the heater relay on and off to maintain
the desired temperature.
Begin with an empty dryer and a clean lint
screen.
1. Plug in dryer or reconnect power.
2. Set the following configuration:
➔ Door – must be firmly closed
➔ Press Control On
➔ Press End Of Cycle Signal (Louder)
➔ Press Start
3. If after 60 seconds, E1 or E2 flashes in the
display and the dryer shuts off, the thermistor
or wire harness is either shorted or open.
➔ Unplug dryer or disconnect power
➔ Check wire connections at the machine
control electronics and thermistor.
To access the Thermistor you will need to open the bottom front panel 2 screws the thermistor is on the exh duct (Center) check it there let me know if you need futher help
Dec 09, 2007 | Whirlpool GEW9250 Electric Dryer
Whirlpool Duet Electric Dryer (5yrs old)
screen.
➔ Press Control On
➔ Press Start
Nov 10, 2007 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
37 people viewed this question
Top Dryers Experts
