Bosch WFF2000 W/M It goes through the cycle, gets to the final rinse/spin and stops (3 lights warning on the Pre Wash) and then switches off. I open the drain line, reset the timer to spin and after a minute or so it starts to spin but does not discharge via the normal route - i have to leave the drain line open. During the normal wash cycle the drain system works normally. Any help would be appreciated. Regards Eric
  • 14 Answers
SOURCE: bosch wff2000. goes through program
it sounds very much like the carbon brushes in the drive moter. the best way is to remove the motor and then you can also check the commutator for wear as well. model no and serial no needed to get spares, sometimes moter type.
Posted on Oct 06, 2008
VtToolMan
  • 704 Answers
SOURCE: No user's manual for Bosch WFF2000
Donna,
Give this a try! This might be just what you're looking for, but unfortunately, there isn't a model number provided for the download.
http://laundry.manualsonline.com/manuals/mfg/bosch/bosch_washer.html
If that doesn't give you what you're looking for, go to the link below and enter in your information and Bosch will contact you directly and should be able to provide a link for a downloadable (free) manual for your washer.
http://www.bosch-home.com/us/bosch/customer-care/contact-us.html
Another possible source, although I've not used them before is the following link. You'll need to provide your information for them to send you an email, but not sure if the provide free manuals, or charge a small fee for their service. There is no cost to at least enter in the search parameters to find out.
http://www.2instructions.com/search.php?cmarque=BOSCH&modele=WFF2000
Hope you find this Very Helpful and best regards!
Posted on Oct 23, 2009
  • 6 Answers
SOURCE: Kenmore HE2 won't finish spin cycle
you have blockage in you drain plug. to solve this problem you'll have to remove the lower front panel of your machine by removing the 3 (1/4") screws on the vary bottom of the machine. once the panel is removed you'll see a 1 1/2" white PVC drainage plug. turn the inner plug to the left in till open. (WARNING ALL THE WATER IN THE DRUM WILL DRAIN THOUGH THIS PLUG) remove debris likes socks or everything that's there replace the panel and your all set.
Posted on Jan 19, 2010
barkencoa
  • 3463 Answers
SOURCE: washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
SOURCE: Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Posted on Mar 21, 2010
Brand new Bravos. Why doesn't it do the final spin?
NO ITS NOT UR DOOR SWITCH IF IT WAS IT WOULDNT SPIN ON ANY CYCLE. I SUSPECT U HAVE A TIMER THAT IS STICKING AND THE POINTS HAVE BURNED OR SEIZED
May 26, 2015 | Maytag Washing Machines
3 lights and loud beeping
When you start your machine is the water just go stop go stop,
Just wait for the machine to display an error code on the wash progress lights and beeps constantly.
It could be the Rotor Position Sensor, out of balance switch or lid magnetic reed switch.
Your error code will determine this.
Is your machine beeping & showing a weird pattern of lights on the wash cycle, It is displaying an error code,
To read this error code you start at the red spin light & work to the left only add up the lights that are on. Red spin light = 1 2nd rinse light =2 1st rinse light =4 last wash light=8 4th wash light=16 3rd wash light=32 2nd wash light=64 1st wash light=128
j8paojvh5jrgaaaaabjru5erkjggg==
Dec 12, 2013 | Fisher and Paykel Washing Machines
I've a 97 bosch wff2000, washes, drains but will NOT spin either after main wash, rinse nor does it do the final spin. Had it from new, so definately can't complain. I've just replaced brushes...
Try disconnecting the small bore hose from the pressure chamber it could be the switch has stuck in the on position in which case the pressure chamber is blocked (the chamber is at the other end of the small bore hose )
Mar 28, 2017 | Bosch Washing Machines
Machine will not spin or drain water.
I have a problem with my MW512AU. Sometimes it drains after wash cycle, but sometimes it sticks when it goes to spin, doesn't get up to speed, water comes on for about 10 seconds and shuts off, and it tries to spin again. If I hit the wash progress switch it goes directly to final spin and works ok. I then have to run a 2nd wash cycle to rinse the clothes. I also noticed a buzzing sound when I turn on the power point, which lasts about 3 seconds before stopping. It will come back on every 3-4 minutes for 30 seconds. This is with the machine power switch off. It powers on normally.
Mar 13, 2010 | Fisher and Paykel GWL11 Top Load Washer
The wash cycle starts with a 5 second delivery of water then stop
SOUNDS LIKE YOURE INLET VALVE HAS FAILED IF YOURE MACHINE IS COLD FILL ONLY IT WILL ONLY WORK ON ONE PART OF THE CYCLE ALTHOUGH IT HAS ONLY COLD FILL THERE ARE 2 VALVES SHARING SAME BODY,WILL NEED CHANGING
Aug 11, 2009 | Bosch Nexxt 700 Series WFMC6401UC Front...
Operates correctly on all wash,rinse,soak cycles but does no spin
Check the door switch, if it's faulty the spin cycle will not work, but everything else will.
Apr 02, 2009 | Asko W6021 Front Load Washer
Hotpoint Aquarius WMA34 not progressing through wash cycle
hi
iwould think it is the programer may have failed mechanically not moving on
cheers
grant
Oct 23, 2008 | Washing Machines
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Bosch wff 2000 washing machine - won't spin/drain
How did you solve this problem. I have the same problem. Kiran
Mar 09, 2008 | Washing Machines
Washing Machines Logo
44 people viewed this question
Top Washing Machines Experts
