Question about Panasonic PT-53WX42 53" Rear Projection Television
Same problem.... I too am having the same problem with the power led flashing three times with no picture. Was there a solution posted for this issue? Thanks in advance
  • 2 more comments
  • Cassidy Haslett
    Cassidy Haslett Jun 01, 2008
    I am having a similar problem to those posted with my Panasonic PT-53WX42 53 Inch Television. It has no picture and the power light blinks in a series of threes. I need a manual for the television that I can view online for free. If not that, then a list of what the LED codes mean. Thanks.
  • Anonymous Jul 09, 2008
    I am getting the 3 blinks after a bad lightning storm. Anybody know how to fix it for free? I mean without having to buy a service manuel?
  • smiller007 Oct 10, 2008
    my light flashes 3 times also after it shuts down. no pic or sound. do i need to replace ic's. what is involved in that.
  • W Smitty Feb 21, 2009
    Mine just happened today. Woke up this morning and 3 blinks. I am fixing to order my replacements. I do have a question, What about the resistors? Should any be replaced or just the (2) STK382-180. I see an offer on the web site posted for a kit, which includes (6) 2.2 Ohm 2 Watt resistors. My only issue is my model is not posted PT53WX42F. Thanks for your help.
  • Panasonic Master
  • 8,617 Answers
# blinks is the error code for Convergence. You will need to change both Convergence ICs number STK392-110 you can get new ICs at the following link and they provide free instalation instructions with pictures and free tech support on line so you can do the repair yourself. Heres the link
http://servicemanuals.vstore.ca/
Posted on May 04, 2008
My Sony KDS-60A3000 randomly turns off, then the red "Power LED" blinks three times repeatedly (not "Lamp LED"). We turn it back on, the process repeats again between 20-60 minutes.
3 blinks of Standby/power LED of Sony sets denotes a SMPS board [G-board] failure. . Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Oct 16, 2016 | Sony KDS-60A3000 60" HDTV
Where is the lamp on an rca d52w15 tv?
That model doesnt have a lamp. They have three CRTs ( Picture Tubes) instaed. You can get the parts for your model at www.tvrepairworld.com. If you have sound but no picture youre needing a deflection board, same item if the set is dead or if the power led flashes three timnes slowly. They all indicate a bad deflection board.
Aug 08, 2011 | RCA D52W19 52" Rear Projection Television
When turned on green light flashes and no picture
Check the Lamp if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 2X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
Check the ballast if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 3X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
Dec 24, 2009 | Panasonic PT-50LC13 50" Rear Projection...
No picture or sound
Does anything start to work? Any of the three fans start to turn, Lamp ignite, etc., when you press the power button or does nothing happen before the Red LED starts blinking. How many times does the RED LED blink?
Jul 25, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Grand wega kdf-55wf655, won't power on and led flashes 3 times
Make sure lamp cover is placed properly and securely after lamp replacement.
3 blinks of LED shows lamp door is still open or not closed properly.
Jul 04, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
When turning on my panasonic cinemavision tv, it makes a click sound then the power button light flashes red three times, no picture comes on the screen, any ideas what should be done?
Most likely a power supply failure although the flashing of the LED a fixed number of times may point to something else such as a lamp failure. If you can find a forum for this series, you may find a Panasonic tech who can give you a better read on this.
Feb 18, 2009 | Toshiba TP55H60 55" Rear Projection...
Power comes on, red light flashes on timer/standby but no picture
Need the model number of your set and also how many times is the led blinking? Please respond to this same post
Jul 25, 2008 | Televison & Video
No picture
you have the ATC311 chassis. do this proceedure and you can track down where the problem is. let me know if you need more assistance. i can also post a link where you can get the training manual at a cheap cost emailed to you if you would like a copy.
5. Apply AC power and press power button.
6. If LED turns on and then off, disconnect J11501 (Audio CBA) and press power
button again. If power LED comes on and stays on suspect Audio CBA. If LED
still flashes or does not light go to step 7.
7. Disconnect J26903 (AV IN CBA) and press power button again. If power LED
comes on and stays on suspect AV IN CBA. If LED still flashes or does not
light go to next step.
8. Disconnect J19500 (Convergence CBA) and press power button again. If
power LED comes on and stays on troubleshoot the Convergence CBA. If
LED still flashes or does not light go to next step.
9. Disconnect J14801 (Deflection CBA) and press power button again. If power
LED comes on and stays on suspect Deflection CBA. If LED still flashes or
does not light suspect DM2 module.
Jun 08, 2008 | RCA HD61LPW42 61" Rear Projection HDTV
Toshiba 50HX81 Power LED Flashing
Check any/all soldered-in micro fuses....F850,F851 etc.
Re-check your work......
solder jumper wires on signal board or fuse (s) may blow......T.
Apr 20, 2008 | Toshiba 65HX81 65" Rear Projection...
TV turns off aftering powering up. red LED flashes 3 times.
3 red blinks means th lamp door in not on. if you have installed the lamp door corectly and it still does this solder all three pins together on the door switch.
Oct 08, 2007 | Sony Grand WEGA KDF-42WE655 42" Rear...
Panasonic PT-53WX42 53" Rear Projection Television Logo
77 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
