Question about Cub Cadet Street Sign- tractor lawn riding mower parts
Have Cub Cadet LT 1050, Will not start. Solenoid does click, "once" when start key depressed, but starter does nothing. Battery is charged and good. Suspect solenoid, or starter. How can I determine which? Can I touch "Hot" lead of starter to battery to test?
RonInFla
  • 86 Answers
SOURCE: Cub Cadet LT 1045 - Not starting, the engine does not turn.
remove the starter...use jumper cables to "run the starter manually...red to big lug, black to body (anywhere is fine) should torque hard at initial run and continue to run smooth...if it buzzes or vibrates, it's bad...replace...
Posted on Apr 10, 2010
  • 760 Answers
SOURCE: cub cadet 1050 fuel problem
Clean, gas tank, fuel filter (replace) fuel shut off valve, and then clean carb, starting with bowl.
Posted on Jul 23, 2010
  • 376 Answers
SOURCE: finding the oil plug on Cub Cadet LT 1050 with Cohler engine
It is probably on the right side in the middle of the engine. It should have a yellow cap on the end of the drain. Take the cape off and slide about a 12" piece of 5/8" x 1/2" clear vinyl tubing (available at Home Depot, Lowe's, etc.) on the end, turn the plastic body to the left (about 1/4") and pull out about a 1/4". Oil will flow. Reverse to shut off.
Posted on Jun 12, 2009
  • 10865 Answers
SOURCE: i have a cub cadet lt 1050 need diagram for drive
Hi. All of these questions are answered in the owner manual. TO download one go to this link http://manuals.mtdproducts.com/mtd/Public.do?BrandCode=10051&langId=-1
J.
Posted on Aug 03, 2010
  • 2239 Answers
SOURCE: Cub Cadet LT1050-Replaced the solenoid, had starter checked out-it's good, battery has full charge, but mower won't start. Help!!
You need to check that there is a 12volt supply from the low tention wire at the solinoid when the key is turned, if there is not either the switch is bad, or the wire from the switch is bad, or the fuse has blown.
Posted on Mar 07, 2012
Cub cadet lawn tractor not starting?
There are several safety switches located on the tractor that could be giving you the problem. The starter solenoid may be bad as well.
Jul 10, 2016 | Cub Cadet Garden
Cub cadet 2186 wont turn over or even "click"
be sure the blades are disengaged. the brake petal is depressed all the way and you are on the seat. might check the fuse. be sure battery has good connections and is fully charged. could also be the solenoid.
Feb 18, 2018 | Cub Cadet Garden
Cub Cadet Riding Mower LT 1046 have to jump, but won't stay running
Check the bottom of the carburetor for a little solenoid. If it has one, the battery may be dead enough that it can't keep the solenoid open causing the carb to shut off the fuel flow causing the unit to die. The easiest way to check if it works is by turning the key to the run position and listen and/or feel for the solenoid to click. If it clicks it is working and there is another problem, if it doesn't then replace it. I recommend having the battery tested or replaced too
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Jan 03, 2013 | Garden
Cub cadet lt 1050 replaced solenoid and battery starter will move very slow
try using jumper cables in series with the battery cables one might be bad
Apr 06, 2012 | Garden
Mar 04, 2012 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet ZTR will not start
Is the blade engagement off? If that is ok, does the solenoid even click when you put the key to start position? If the solenoid doesn't even click check the battery connections and make sure they are good and clean. If the connections are good, are you sure the new battery is fully charged. If the battery sat around for a long time in the store it could need charged. If all that is good and then you don't get the starter solenoid to click when you put the key in start position, then it is either the seat switch, parking brake switch, handle switches, or mower engage switch keeping it from starting. If all that is ok maybe you have a bad starter solenoid. Please rate my answer so I am rewarded points for it.
Jan 30, 2012 | Cub Cadet Garden
My lt 1050 will not start without a charger attached. Once its running, the pto will not engage. Thought the battery was dead but battery has 13 v. Starter makes no sound when trying to start. No problems...
Does the battery have good voltage even with the key on? A battery can have 12.6-13 volts with the key off but once it is turned to "ON" it can drop considerably. Lights, solenoids, safety switches, and relays all take voltage from battery. Also check to make sure the battery connections are free of corrosion and tight.
Aug 04, 2011 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
I have a Cub cadet LT 1024 which will not start. The solenoid clicks like it is trying and lights will come on but that is only reaction. Battery is brand new and hooked up properly.
solenoid clicks, only tess you the coil is working inside the solenoid. disconnect cable from battery to starter. with ohm meter check for continuty across main terminals of solenoid while holding key to start. if no continuity, solenoid is defective.
Apr 29, 2010 | Oregon Scientific Electric PTO Clutch for...
Apr 10, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
2,609 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
