Question about Frigidaire FRS26R4A Side by Side Refrigerator
Had mouse get caught in fan,removed it fan still works.fridge not getting cold.any resets I can try.sounds like compressed. Comes on 2 seconds n turns off
  • Frigidaire Master
  • 909 Answers
Your compressor is faulty. When the cooling fan motor goes faulty and not caught in time, the compressor overheats and siezes.(What you are experiencing now).
Posted on Aug 23, 2010
Testimonial: "thank u for assistance"
HP Pavilion not turning on, orange light and alarm sound.
Try a Hard reset!
1. Remove all connections from the computer including the power cable
2. Press and hold the power button for 20-30 seconds and then release
3. Only hook up the mouse, keyboard, monitor and power cable
4. Turn the computer
let me know what happens!
Oct 15, 2014 | HP Pavilion Computers & Internet
E442B Fridge is not cold & some ice build up in fridge. How do you remove the back of inside of freezer to check ice build up there?
don't mess about with it just remove items and get a new one sound like its leaked it's gas (BUT DON'T PANIC) its not harmful and its not going to blow up! you could call a engineer but a lot of the time your just as good putting that money towards a new one
your friendly domestic appliance engineer chris
Dec 05, 2011 | Refrigerators
Wall dividing fridge from freezer is very hot to the touch
You either have obstructed coils (lots o dust) under the fridge or the fan that is supposed to draw air across them has ceased to work. Check the coils and clean as necessary, and check the fan. Maybe you will get lucky and find something caught in it. If the fan is not working, leave the back cover off the fridge and put a small window or box fan back there until you can get the fan replaced. The fan will keep the fridge running for you in the meantime.
Jun 29, 2010 | Refrigerators
Temperatures not staying cold, then getting too cold. First everything in freezer thawed out. Then, fridge wasn't cold enough. We moved everything to freezer just to keep colder (not to freeze). Then, days...
assuming fan now working. clean out vents/ drain holes (make sure no ice in bottom of freezer or in fridge unit)i.e. a total defrost.then check door seals all okay(no air leaks) if unit was trying to defrost itself and you reset to colder it will need to reset itself.....
Feb 11, 2010 | Hotpoint HSS25GFP Side by Side...
Fridge does not get very cold,compressor comes on, frezer is cold
check to fan inside unit air not transferring from freezer to fridge fan uses cold air from freezer to cool fridge check that fan is working usually can feel but may have to push button on door and hold if no fan remove cover and check for ice on blockage if none have fan serviced or replaced -if fan is working properly, same area is a damper that my be blocked or frozen good luck and thank u for using fixya
Oct 14, 2009 | GE Refrigerators
Subzero 590: freezer works, refrigerator not cooling
This is a Sub Zero and many technicians do not realize that these units most all run on 2 separate systems. 2 cold controls 2 compressors 2 evaporators. They share a condenser and condenser fan motor. What you are describing is most likely a bad cold control. It is pretty common for these to get some age and go bad. If you are very savvy with repairs yourself then if you access the compressor area and feel that the compressor on the right is cool and the compressor on the left is warm then you know that the ref. compressor has not been running. UNPLUG THE UNIT OR CUT THE BREAKER OFF. Remove the shelving from the fresh food section and the cover to the lights and the panel below the lights and lean the back panel forward to access the cold control. You will see 3 wires to the cold control. The green wire is the ground wire of corse. Unplug the other 2 wires remembering their location on the control unit. Take a jumper wire and jump these 2 wires. If when you power the unit up the right side compressor comes on then you know that your fresh food cold control is bad. Replace fresh food cold control.
Feb 01, 2009 | Sub-Zero 690 Side by Side Refrigerator
Whirlpool side by side freezer not working fridge is fine
Pull out the fridge and unplug. Remove the back cover. Clean the condenser coils and fan. If they're difficult to get to, use compressed air to blow out. (you can get a can from walmart). That should fix the problem. If that doesn't work, then write back.
Doug
Jan 05, 2009 | Whirlpool GC5SHEXNS Side by Side...
Not cold
A friend came to fix it there was a piece of insulation caught in the damper. Thanks anyway.
Aug 19, 2008 | Amana ABB1927DE Bottom Freezer...
Kenmore fridge isnt working
check in the rear of the unit u will need to pull it out and remove the panel see if the fan (Condenser) is running is the compresser running?? is the compresser hottt?? do you hear a hum and then a click noise?? is the condenser dirty?? remove the front kick plate to see this.. After you have cked these things let me know and we can go from there
Feb 16, 2008 | Refrigerators
Freezer works fine but the fridge won't get cold
It sounds like cold air from the freezer isn't making it to the fridge compartment. This can be cause by a several things. The damper that lets air into the fresh food side is stuck in "closed" position, the temp sensor (t-stat) isn't working properly, the evaporator fan (in the freezer comp above the coils) isn't working to blow air up to the fresh food section. In some situations, the defrost cycle for the freezer section isn't working and the coils have frozen into a block of ice and air can't flow over them properly so you get not cold air to the fresh food section but the freezer still stays cold due to the block of ice.
Feb 21, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Frigidaire FRS26R4A Side by Side Refrigerator Logo
165 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
