Question about LG Washing Machines
My machine keps stopping and giving a 6E message
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error 6E is a ball sensor error which is displayed due to loose Ball Sensor Connector and/or when the Ball Sensor goes bad/is out of order. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 23, 2010
My innotab max keep giving an error message 404 which mean not connected to the internet but it is
I too have a InnoTab MAX children's tablet with same issue. Power cycling it, leaving cartridge plugged in/then out, have power plugged in then not, forgetting WiFi connection and re-linking after verifying WiFi is fine from other devices, also standing beside the wireless router all have been fruitless.
Having spent an hour on it last night and almost that long tonight - it's going back to BestBuy tomorrow. If I resolve the issue I'll pay what I did.
Dec 25, 2015 | Toys
My Samsung washing machine p1453 stops after 10 mins washing and comes up with code error 6E which is not in the manual
They usually stop with an unbalance load or If its a newer model and u use h.e detergent or suppose to be using it, and if u use it or another detergent to much , to heavy many newer washer have a suds sensor and when it detects to much detergent it will shut u down
Oct 03, 2014 | Washing Machines
It gives me an error code either 6E or bE
BE OR 6E IS belt broken check your belt if its ok you will have to check pc board and wireing
Apr 03, 2014 | LG IS 250 Dryers
During my activation 2010 office give me error csript
Hi, does it give you an error code? or a message of some kind?
Mar 20, 2014 | Computers & Internet
6E what does it mean?
Took me a while to figure this one out as there is very little information. I think that 6E means that the water is not hot enough, i.e. that there is a fault with the heater. However, at the point my machine stopped the washing was hot, so I think the problem was with the sensor. If you lie the machine on it's back and remove the base the heater is below the drum. At the top (front) of this there is a little white connector which attachs to the water heater. On my machine it has one pink and one yellow wire coming from it. This connector seemed a bit loose, so I pushed it home securely and the machine seems to be working now (fingers crossed!).
Hope this helps.
porsche parts
May 27, 2012 | Samsung Washing Machines
Samsung p1453 error code 6e?
6e fault is saying that the temperature is not high enough, this is most likely a malfunctioning temperature sensor or an issue inside the electronics.
Mar 10, 2012 | Computers & Internet
Brother 8040 error 6e
For error code 6E:
This means the heater temperature isn't rising fast enough.
The heater should rise at 2°C every 5 seconds.
You should first reset the code to see if the problem is just an anomoly or a real problem with the heating circuit (the halogen lamp and/or the power supply PCB). If after resetting the code the error returns, have a technician or service center diagnose which is the culprit (or you could simply replace both yourself -- if that is affordable to you).
To reset the trouble status follows these steps:
1. Press MENU *,2,8,6,4
2. The machine beeps for approx. one second and displays “MAINTENANCE" on the LCD, indicating that it is placed in the initial stage of the maintenance mode, a mode in which the machine is ready to accept entry from the key pad.
3. Now you are inside the simulation Press 01 to reset the trouble status.
4. To exit the simulation press 99.
• Pressing the 9 key twice in the initial stage of the maintenance mode makes the machine exit from the maintenance mode, restoring it to the standby state.
• Pressing the Stop button after entering only one digit restores the machine to the initial stage of the maintenance mode.
I hope this helps.
Aug 20, 2009 | Brother DCP-8040 Copier
Willnot spin, error code 6e
lg wf-t851 will not spin. displays 6e error code
May 23, 2009 | LG WM-2277HW Front Load Washer
To get reset code for errors on brother dcp 8040
6E
Heater temperature does not go up enough.
(Slower temperature rise rate than 2°C/5
sec. is detected.)
To cancel the trouble status follows these steps:
STEP1 .Press MENU *,2,8,6,4
STEP2.The machine beeps for approx. one second and displays “MAINTENANCE" on the
the machine is ready to accept entry from the keys.
STEP3.Now you are inside the simulation Press 01 to reset the trouble status.
STEP4.To exit the simulation press 99
If again 6E occurs try to check the halogen lamp or power supply PCB.Contact authorized technician to do this checking.
Dec 18, 2008 | Brother DCP-8040 Copier
Washing Machines Logo
445 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
