Converg. ont pkt195 chass. - Televison & Video
  • 8,617 Answers
The convergence board or the convergence power supply board is the fault. If you would like more info please let me know, As that model doesnt have convergence ICs
Posted on May 04, 2008
How to clear Huawei ONT data?
Clearing ONT data is similar to restoring factory settings for an ONT. Use either of the following methods to restore factory settings for an ONT:
Choose System Tools > Restore Default Configuration from the main menu on the web page and click Restore Default Configuration.
Hold down the RESET button for a long period of time (longer than 10s) to restart the ONT with factory settings.
Mar 30, 2018 | Huawei Cell Phones
Does an ONT Support Routing?
Query the ONT nameplate to determine whether an ONT supports routing. If "gateway HGU" is marked on an ONT nameplate, the ONT is of the gateway type and supports routing. If "bridging SFU" is marked on an ONT nameplate, the ONT is of the bridging type and does not support routing.
Apr 19, 2016 | Cell Phones
Is chasses on kia sportage 2001 model strong
about as strong as folded 1mm thick sheet metal can be. Most cars now do not have a chassis but are uni-construction which means that the whole body is the chassis and if you are planning in fitting a tow bar to the car then get a tow bar fitter to do the job with an approved tow unit that has been designed to spread the stress over a large section of the car.
Jan 07, 2014 | 2001 Kia Sportage
Boot warning chassis opened
disable the chasses intrution detection in bios setup.
Dec 23, 2013 | Acer POWER APS290-UC4201P MT CELERON M 420...
How to replace power supply
unscrew the screws on the back and open the chass. then draw a map about the connections where those power cables went into inside the chass. then unplug all the power connections and unscrew the screws on the back which fasten the power supply to the chass. remove other components if necessary to alow space for the power to come out. then replace the power and anything else in reverse order and reconnect the power cables according to the map.
Mar 02, 2012 | Acer L410G PHM19 3GB 160GBDVDR X1250...
Color setting ......
you have t adjust it to the green to get it to set right, if it ont line up youll need to have it converged
Oct 27, 2008 | Akai PT5598HD 55" Rear Projection...
Toshiba 43hx70
i dought it, check aroiund the convergence ic's "stk392-xxx"
Feb 08, 2008 | Toshiba 43HX70 43" Rear Projection...
Volume buttons stuck inside
hi , first i want to say that the tv is not a game it is hazard set very high voltage inside so if you don't have any experience please dn't try to , but you can do it your self just took outlet off and took case off and try to draw the chasses towards you to behind then look inside to the place of the buttons you will see aplastic tips which will push the volume switches that are soldered on the chasses and with your fingures try to push out the plastic tips to relocate it to the original state it is too easy and the please try to be away from the cable that is fixed to the screen cause high voltage is it, refix chasses and cover and give me high rate insted of £40:) regards
May 06, 2007 | Sanyo DS24425 24" TV
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
