Question about AEG Washing Machines
My AEG lavamat 74825 washing machine stopped spining this morning. I cant rotate the drum by hand but it fills and drains ok. Any ideas?
SOURCE: AEG Lavamat 86720 washing machine
FAULT CODE C 9
Posted on Aug 17, 2008
SOURCE: AEG lavamat 6955 sensorlogic, was showing F2,nowF3
Waited half hour; on start up F3 had cleared..pump overheat? Suspect sticky pump bearing..new pump.
Posted on Jun 12, 2009
SOURCE: AEG LAVAMAT 12700 VI turbo washing machine doesn't drain
Hi, You have taken out the strainer of the washer front and cleaned it regularly haven't you?? If that's clear, it's probably just the waste line blocked. Try removing the waste pipe where it joins under the sink, put it in a bucket and see if the washer drains. It's probably full of sh"te. If that doesn't work, then I'm probably full of sh"te and you might need a new pump.
Posted on Jun 15, 2009
SOURCE: SIEMENS XLM1400 WASHING MACHINE DOES NOT SPIN
siemens xlm 1400 washing machine fills with water but wont wash
Posted on Jun 04, 2010
blueextc3221
  • 15935 Answers
SOURCE: AEG Lavamat 518 manual
Head over to the manufacturer's website.
Typically they have a SUPPORT section - where you enter the FULL model number, and then can download a FREE manual.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 17, 2010
Remove housing
How to replace a washing machine door seal on an AEG ...
? 5:38
https://www.youtube.com/watch?v=KlAXmnKJQ9k
Aug 17, 2009 - Uploaded by eSpares
This video will show you how to remove and replace the door seal. ... Do you have video repair instructions for AEG washing machine OkO ...
AEG removing drum Washing Machines Questions ... - Fixya
www.fixya.com/tags/removing_drum/washing_machines/aeg
AEG washing machines removing drum related questions and answers. ... into thehousing and get the object out. well as we say in my town you got a "toston" .
Aeg/electrolux lavamat 76810 waschmaschine E20 - YouTube? 0:28https://www.youtube.com/watch?v=1WX5rKxFrXsMay 3, 2015 - Uploaded by jusuf jerkovicAeg/electrolux lavamat 76810 waschmaschine E20 ... front load washer from not draining -- washing machine error code e20 - Duration: 2:52.washing machine error code e20 - YouTube? 2:52https://www.youtube.com/watch?v=2B7FxovrxKoOct 25, 2014 - Uploaded by teppichkopfSave some money and fix it yourself. Totally bizarre how stuff gets stuck in the drain!
Dec 21, 2015 | AEG Washing Machines
THE DRUM ON MY MACHINE ISNT GOING AROUND AND IT'S NOT SPINNING
Is it old washing machine?
One problem could be belt. It could be dropped. If you hear motor spining noise, but drum isnt spining - this is it.
If you cant hear anything - motor carbong brushes..
If not - electronics problems (semistor or etc).
I need more info to help you better.
Apr 05, 2013 | AEG Lavamat 74640 Front Load Washer
The washing process stops after about 12 minutes at any program and the green door light is on but water in the drum.
it looks like your heating element are dead. But Im not sure.
Does drum is spinning?Does it pumps water then you set in on "drain" program?
Apr 03, 2013 | AEG Washing Machines
My aeg lavamat L washer/dryer has suddenly stopped working and there is no power
Sorry this isnt a solution .. Im just wondering if you did manage to get this sorted as it happened to my machine this morning?
Feb 17, 2012 | AEG Lavamat 16810 Front Load Washer/Dryer
Code c9
Reset using Off-2-Off.
Tested with Gentle rinse: water OK, but no drum rotation. Tested Short Spin: Pump OK but no rotation.
Opened door (first time) and rotated drum by hand - smooth.
Shut door carefully and tested short spin: OK.
Suspect: door safety switch.
or I suggest you look at your instruction manual (or take the link below) and look at the fault bit of the book.
You could perhaps try to follow instructions for the "The washing machine doesn't work" .
Are you able to actually programme the machine? i.e. The display will still show you the programme length etc
It may sound silly, but is the door closed properly etc
Is there a way of resetting the machine, or maybe turn it completely off for a little while, and turn it back on?
If all this doesn't work, i suggest you phone either AEG, or the person/company you got the machine from, and get them to have a look at it.
Also, was it working properly, before it stopped working - i.e. Would it drain properly ?
I hope all this helps you. Source(s): http://www.serviceforce.co.uk/pdfs/U0346...
May 17, 2011 | AEG Lavamat 74640 Front Load Washer
On my AEG Lavamat 62810 washing machine, when I start a wash cycle the motor (pump?) runs for 10–20 seconds then the machine switches off, with no error message and no water having entered the machine....
inside the waasher there is a fill level valve i think its blocked up with "gunk" if you look inside the washer you should see a small pipe from the bottom of the drum going up to a round type of valve with lots of wires fitted to it at the top of the washer,,,pull the pipe off this valve and "blow hard" down through it,,any "gunk" should be pushed out and the washer should wook ok after that,,,if it dont change the valve!!!
Aug 12, 2010 | AEG Washing Machines
I have a aeg lavamat turbo washing machine .when start it the water does not got to the drum ane water never stops simply running
You have a syphon - the waste pipe is probably too low and the end sits in water in the drain, meaning the water runs through the machine and out the waste.
Jun 30, 2010 | AEG Lavamat 12710 Front Load Washer /...
Washing Machines slowly fills with water over a few days
could be leaking inlet valve or if drain is plkumbed in unbder sink, could be filling thro drain pipe when you emptyt sink
Mar 17, 2007 | AEG Lavamat 16810 Front Load Washer/Dryer
Washing Machines Logo
123 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
