Question about Garmin GPSMAP 188C Sounder GPS Receiver
Unit wont find satellite ant seems to be ok any ideas
Is there an air adjustment for the flame? seems to be a lot of yellow on it.
it probably needs cleaning
shut unit off use compressed air to blow out ant hole you can get into. pilot hole too, relight should be bluer flame
just a guess no idea what you have for a heater
Oct 26, 2015 | Heating & Cooling
Antenna installation
The tuner in that unit is analog ntsc and so you need a digital converter for it.
Feb 17, 2014 | Hitachi Televison & Video
GPS wont aquire a satellite
    Hello there and happy new year
    If Your Unit Cannot Acquire Satellite Signals
  1. For your Garmin GPS unit to acquire the satellite signals it needs to function properly, the unit must be taken outside, away from mountains, tall buildings and heavy foliage where it can get a clear view of the sky. Keep the unit stationary for several minutes while the GPS unit acquires the necessary satellite signals.It may take several minutes for the unit to locate a good solid signal
  2. OK
  3. Hope this is very helpful please keep me posted on this ok?
    Best regards Michael
Jan 01, 2010 | Garmin MAP76 handheldS GPS Receiver
Craftsman 20 hp B&S 42 cut 5 yr old Auto trans Last yr started to backfire and lost power for a few min after 2 or 3 hrs of running I plug wet 1 plug dry installed new magneto runs ok but sometimes...
Check your kill switch first take the small wire off the the ignition coil you could have a short I would not waste money on a wire harness once the small wire is off the coil thats all it can be is the coil if its not firing if its fuel thats another problem
Nov 08, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Remote Control wont open manue on new tv
ensure the satellite receiver is turned on and the output from the satellite receiver is connected to the ant. in on the tv. on the remote control, press the tv button, then the menu button. from the menu, select settings, set input to ant. .
do this and let me know what happens so we can get this working
I will be available till 2:00am CST
clarkco
Feb 16, 2009 | Toshiba 26AV502U 26 in. LCD HDTV
RCA P61310 Works on all inputs but ant a
The other inputs bypass the tuner, so I'd be looking at tuner failure. RCA sets are known for having poor solder connections inside the tuners. I would start there. If you are not comfortable with working insode the set or can not solder, check with a local service shop to get an estimate for resoldering/replacing the tuner.
Dan
Feb 13, 2009 | RCA P61310 TV
No signal
It sound like the ant. is cut ( this happen to me) or the ant not pluged in all the way.
Apr 26, 2008 | Audiovox XMCK10 Satellite Radio Receiver
Zenith System 3 25" no audio picture ok
If you have satellite try unplugging satellite receiver. If doesn't work you probably have a audio output ic bad inside the set.
Dec 31, 2007 | Zenith Z25A66R 25" TV
Hooking up a dvd/vcr player
The easiest way to connect the unit is via coax. You can come out of your satellite receiver via the "Out to TV" on the back of the receiver to the "In from Ant" on your DVD/VCR combo. You can then connect another coax from the "Out to TV" on the DVD/VCR combo to the "Ant/Cable" input on the back of you TV. Make sure the satellite receiver and the vcr are both modulated to the same channel, normally channel 3.
Dec 31, 2007 | Emerson EWF2004 20" TV
Spinmaster 3 wont light up
the problem seems to be with the relay that switches on/off the lamp it seems not to be able to handle the current ant the contacts burn out... just check the side of the relay for melting/burning i have replaced mine with an uprated one with no probs
Nov 27, 2007 | Office Equipment & Supplies
Garmin GPSMAP 188C Sounder GPS Receiver Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
