Question about Oster 76076-010 Hair Trimmer
I am looking for a blade sharpener for the a5 blades
I bought a Geek Squad Battery Surge Protector (GS1285U)and the LCD display doesn't stay lit all the time? After I push the select button, it lights up then goes off after maybe a minute or so? Is this normal operation?
Posted on Jun 22, 2008
    Problem Solver:
  • 4 Answers
Ry`s Barber has blades for you oster.
Oster A5 clippers work briefly then "pull" hair
Lever arm worn, blade blunt, or loss of movement inside the gearbox. It is possible to have a 'bad' sharpen.
Aug 03, 2012 | Oster Golden A5 Single-Speed Clippers
I have just had all the blades sharpened for my clippers but they won't cut my dog's fur. Never had a problem before. Can you please help?
It is common to that a Blade Sharpening Service return your blades just as blunt as before, or even worse.
I advise that you try a new Blade Sharpening Service; trying out only a couple blades to begin with.
I recommend a mobile/on-site sharpening service.
Sep 15, 2011 | Oster Golden A5 2-Speed Universal Motor...
Hi I bought Oster golden A5 clippers from ebay and I am not sure if they are fixable. I tried to use them to groom my dog and the blades wont cut the only solution was to tape the blade flush to the unit,...
it's seem that your clipper blade are out of adjustment and also dull, The Lever from what you stated your Lever is worn out also. The only way I can help is to send your clipper and blades to us so we can make all the necessary adjustment, replace the worn out part and sharpen your clipper blades.
I don't know how many blade you have, but we can work some thing out to help you solve your problem. You can e-mail at
We have been in sharpening business since 1990 You can check out my rating on Manny's Sharpening
Mar 22, 2011 | Oster Golden A5 2-Speed Universal Motor...
My Golden A5 clippers won't shave a knowlegable dog groomer friend of mine said the blade seems sprung from the housing it doesn't fit snug against the body of the clipper is there an adjustment I can...
it seem the hinge on your clipper is worn out, here how you can check it, place blade on with the clipper off tap the blade forward if the blade pop,s open the hinge is worn out, you need to replace it, Now on the cutting part of the blade when was the last time you had your blade sharpen. if it been a while or you can not remember it's time to have it sharpen by a professional.
Apr 13, 2010 | Oster Golden A5 1-Speed Universal Motor...
Doesn't cut. we sharpened, we cleaned, it's
Most likely, the blades were not adequately sharpened. To effectively sharpen these type blades, you need a special sharpening wheel designed for this task. If you have attempted to sharpen them on a sharpening stone or other device or you are not sufficiently knowledgeable in sharpening these blades, you probably have not satisfactorily sharpened them. Often, attempting to sharpen without the correct equipment makes them worse than when you started.
If you require professional sharpening, please see
Feb 04, 2010 | Oster Golden A5 1-Speed Universal Motor...
I just had my A5 clippers serviced and was
Do you know how to sharpen your blades? Sounds like you need to give them a quick touch up.
Sep 08, 2009 | Oster Golden A5 1-Speed Universal Motor...
Run but will not cut
Are you sure you have Andis A5 or did you mean Oster A5 Clipper, if this clipper is A5 Clipper, You need to check the Lever for wear, The front of the Lever show wear on both side, Like white color and is not squad this Lever is worn. Need to replace. This Lever moves the blade side to side fully. if the Lever is worn the blade will not move fully side to side and the cutter blade the smaller blade will stay in the middle with hardly no travel to side to side and will not cut the hair even if you purchase new blades. Also I would like to mention if the Oster Locking Hinge is worn out and don't have the require tension to hold the blade in place the blade will not cut. How do you test the Oster Hinge on a Oster A5 Clipper,
(1) first close the hinge, in close potion with your finger nail try to open the Hinge, if the hinge slightly open or opens loose the Hinge is worn. if the Hinge is good it will not open or move and your nail may just brake your nail.
Many of my customers run into this type of problem, and the problem can be solve easily by checking these parts first.
One more item I would mention here if replace the A5 Hinge make sure you get the A5 Hinge not the Oster 76 Hinge they are driferrent, The A5 Hinge has on the back two wire's sticking out that fit on the Oster Latch for the A5 Hinge, the Oster 76 Hinge would not have these wire's on the back. I recommend replacing the Latch when you replace the Hinge. I hope this helps any body that have a A5 Oster clipper or A Oster 76 Clipper.
I have over 20 years in the repair business of Sharpening & Clipper repair. Mannys Sharpening 323 263-4697
b61c252.jpgOster Hinge
Jun 10, 2009 | Andis Outliner II Hair Trimmer
Blades are not cutting
hi, yes blades can wear out but your sharpener should advise if there is a problem with them. check to make sure the clipper is moving your blades and your blade cannot be removed without depressing the latch. If your are experiencing tram lines with larger blades then it is more likely to be a clipper problem. However if your blades just wont cut i would recommend a new sharpener as it is a specialist area.
Jan 29, 2009 | Oster Golden A5 2-Speed Universal Motor...
Replacing blades on Oster A5
A5 blades are not made to be unscrewed. Once they are sharpened they are aligned and when you unscrew them they will need to be realigned again. You can call factory service 800-830-3678 if you have any questions. Please just in the future always use the snap on/off method.
Jul 27, 2008 | Oster Golden A5 2-Speed Universal Motor...
Oster 76076-010 Hair Trimmer Logo
60 people viewed this question
Top Oster Health & Beauty Experts
Anglia Clipper...
Michael Vincent Cruz
Are you an Oster Health and Beauty Expert? Answer questions, earn points and help others
