Question about Quantegy 456 Reel-To-Reel Recording Tape
Hello there, I've purchased on eBay my Sony TC-200 Reel to Reel recorder. I've opened and cleaned it to best of my knoweldge and ability. I am able to hear sounds on both speakers when I connect my computer through the Aux Ch1 and Ch2. I'm able to record and playback from channel 1, but channel 2 will not record any information, it seems. I tried the same test with the Mic Ch.1 & Ch.2 and the same problem. Channel 2 will not record. How should I approach the problem? Will appreciate any help. Thank you Shlomi.
  • Quantegy Master
  • 10,137 Answers
Http://freeservicemanuals.info/en/servicemanuals/viewmanual/Sony/TC200 Go here. when the page opens, click on the TC200 to download the service manual. There are 3 tubes and one transistor in each channel. Test the tubes first. They fail with age. You can still get tubes. You just have to google the tube number to find a seller.
Posted on May 15, 2017
5 Suggested Answers
kakee
  • 1269 Answers
SOURCE: Sony TC 530 tape speed problem
If it's slightly faster than normal, that's fine. You'll just need to check the rollers and tighten them slightly as well. They might be loose or sort of that.
Posted on Dec 26, 2008
SOURCE: Sony Reel to Reel preamp board.
Did you ever get your schematic? I recently got the Model 260 and it has the original owner's manual. I could try scanning the page for you, if you still need the info (if you think that would help you).
--Dave
Posted on Jun 07, 2009
dvdcdlaser
  • 1285 Answers
SOURCE: what are the best tapes to buy to recrod from your
maxell or tdk (which is hard to find now)....if your reel is 7 inch you want 1800 ft, normal bias (lo noise hi output) tape (for 10 inch you will use the 2400 ft) ....anything longer your tape will be dragging (both while recording and playing) hope this is helpful...feel free to rate
Posted on Jul 05, 2009
dunnbiker
  • 8546 Answers
SOURCE: Hear both sides of tape on playback ??
It's a 4-head reversable deck where the Forward tracks are arranged across the physical tape surface, front-to-back as follows:
ForwardLeft ReverseRight ForwardRight ReverseLeft
...so it sounds like the Reverse playback heads are engaged at the same time you play Forward, so you would hear those adjacent tracks backward. If you play the tape in the Reverse direction, is the Forward program audible (but backward)?
If so and in otherwise high fidelity, something in the Forward/Reverse head selection may be hosed.
Or, if the out-of-phase tracks are mushy and low volume, the physical tracking of the tape across the heads could be WA-A-A-A-Y bad. That would probably be visible as sideways distortion in the tape path. Shine a high-intensity light on the tape where is passes over the heads, then reverse it while watching where it sets up on the heads. It should be centered on the heads and not change its orientation when reversed. Compare where it tracks in motion with the probable visible wear marks (shiny bars across the heads perpendicular to the travel) where the tape has polished the heads over the years.
Or, the heads are so worn the coils pick up signals from their neighboring tracks.
Posted on Mar 04, 2010
Testimonial: "I will try your advice. Yes, it happens in both direction, but, it doesn't do it will all the tapes, just some. Why ???"
How do I get this device to play and record again? I often clean the heads.
if one reuses the tape often, ive found that the tape stretches and no longer covers the entire record path (or play path) , i still have a few cassette and reel to reel decks that I still use , and since the tapes are hard to find now I keep reusing the tapes more and more 4 the same thing , I guess its been like in the past year ive seen this tape stretching thing happen now
Feb 04, 2016 | Sony TC WE435 Stereo Dual Cassette Deck...
AKAI REEL TO REAL MODEL 1700 OPERATOR'S MANUAL
Here you are Andrew. That is a blast from the past!!
Service Manual and Owner's Manual!
Akai 1700 Manual Stereo Tape Recorder HiFi Engine
Jan 23, 2016 | Computers & Internet
Where can I find an owner's manual for Sony TC-355 tape recorder
Hi Cloise,
Go to HIFI engine at this link. Sony TC 355 Manual Stereo Tapecorder HiFi Engine .
Here is the TC355 page. Sony TC 355 Manual Stereo Tapecorder HiFi Engine
You must create an ID and Login to obtain the free download.
Fare. Well.
Dec 12, 2014 | Sony Audio Players & Recorders
Sony TC 330 reel to reel tape recorder. Tape will rewind and fast-forward but will not play. I think a new drive belt might be needed. How do I check?
REEL TO REEL RECORDER SONY TC 330 - on back side of the set voltage selector knobe is lost,so how can i fix it ?
Oct 15, 2010 | Sony Audio Players & Recorders
Sony TC-530 hum in internal amplifier left channel.
Electrolytic capacitors are good at causing hum. You could try replacing some of them, they are not expensive. Otherwise you might have damaged the left channel amp semiconducter, whatever that might be.
Nov 25, 2009 | Audio Players & Recorders
I have a sony TC 530. Fast fwd and rewind work
You need to replace the motor run capacitor. It's a small aluminum can looking thing with three wires right next to the motor; they often leak paraffin wax into the bottom of the case when they overheat. Whether or not yours has leaked it's easy to replace if you can use a soldering iron. Search eBay for a Sony reel to reel 1.5uf 250VAC motor run capacitor - they're less than $15 and come with detailed instructions.
Please wait Image not available
Jun 14, 2009 | Quantegy 456 Reel-To-Reel Recording Tape
--Dave
Mar 28, 2009 | Quantegy 456 Reel-To-Reel Recording Tape
Dec 26, 2008 | Quantegy 456 Reel-To-Reel Recording Tape
Sony reel to reel TC -765
I too had this problem with my tc765. I found the two pinch rollers were not lifting up and fully pushing the tape against the rotating capstans in the play/record mode. Solution to my problem involved partly dismantling the pinch roller assembly, cleaning off the old solidified grease and re-lubing with a molybdenum grease. Note: the top plate has to come off first,then the rotating guides and tensioning pegs. Then the cast head cover and flap. It was a time consuming operation, but well within the scope of competent DIY in my opinion.
Sep 24, 2007 | Audio Players & Recorders
Quantegy 456 Reel-To-Reel Recording Tape Logo
157 people viewed this question
Top Quantegy Electronics - Others Experts
Are you a Quantegy Electronics - Other Expert? Answer questions, earn points and help others
