Question about InFocus ScreenPlay 5700 Multimedia Projector
I replaced the lamp assembly and the replace lamp still shows on bottom of screen. I now have 10 vertical lines across whole picture..?
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 269 Answers
If I remember right, you have to hold in both of the keystone buttons for 30 sec. As for the line, I'd have to guess it is the main board or the dmd board on the back of the light engine. Very expensive to fix..However, if you are good with taking things apart you can clean the connection between the light engine and the main board with an approved electronics cleaner, make sure it is dry and reseat the connection between the two. Sometimes thats all it takes.
Posted on Aug 24, 2010
  • canam58 Sep 10, 2010
    I have the same problem (vertical lines). Was told it is the light engine failing...any luck cleaning the connection?
    BK
Only half a picture
"the vertical lines" is not correlated with the lamp
1,the interface between the mother board and DMD drive board
2,to clean the the interface with some alcohol
3,securely plugged
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
skype:lampdeng
Feb 16, 2014 | Vidikron MODEL 65 Lamp
I have multi colored vertical lines across the entire screen. The menu screen is perfectly legible when selected on the remote and will go on and off like it is suppose to.
If this tv vertical colors lines problems happen by itself,tv problems not causes by u or an object by hitting forces to the tv LCD screen panel itself.The tv board that call the T-CON board it is dead,this board sit in the bottom in the middle of the LCD screen panel.Must be replaced the T-CON board to solve tv vertical colored vertical lines.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish T-CON board for the replacement.If causing by u or an object by hitting forces it to the LCD screen panel itself.The tv not worth a whole tv anymore,because by replacing the tv LCD screen panel will cost the same as a new tv.
Jul 28, 2011 | JVC LT37XM48 LCD TV
I have 2 lines running down my monitor screen. One blue, one green.
They are vertical lines running from top to the bottom, then it can be loose ribbon cable or dirty connectors, or failed LCD controller board (part of the LCD panel assembly, whole panel will have to be replaced).
See pictures: http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
Apr 03, 2010 | HP W2338H Monitor
Color lines in tv screen
it's an lcd filter fault it's betwine lamp and screen before mirror, seems like u will need to replace it but it hard to say without look at it.
Mar 22, 2009 | Philips 55PW9363 55" Rear Projection...
Jvc av-29ts2ek
It sounds like a vertical deflection problem. You mentioned you had a white HORIZONTAL LINE in the middle of the screen. If this line runs from left to right across the screen it's in Verticla deflection. If it runs from top to bottom, it's in Horizontal deflection. I am assuming the problem is a Vertical deflaecion problem. The repairs necessary are most likley to replace the vertical capacitors or the verticla deflection chip.
Good Luck
Ed
NC Electronic Mills, Wyo USA
Jan 05, 2008 | JVC TM-2703SU 27" TV
Discolored image and lines...
I also am having the same problem. at first it only showed up after the projector was on for about 15 minutes. Now I get a purple vertical bar on the right of the screen. I also get vertical green bars spread across the screen.
Does anyone have a diagram of how this machine is assembled?
greg
Dec 17, 2007 | ASK Proxima DP6860 Plus Multimedia...
Can only see half the picture
Locate Vertical Output device--replace w/OEM equiv.or better.
Oct 10, 2007 | RCA TruFlat 27F520T 27" TV
JVC AV-27790 - single horizontal line
Since Intermitant always inspect the vert ckt for bad solder connections. If not replace the output IC they're cheap and most likely the problem If you still have lines on the top or bottom I would replace all of the electrolytic capacitors in the vert ckt also. Without much test equipment rebuilding the whole little ckt is the best way to go.
Apr 24, 2007 | JVC AV-27790 27" TV
InFocus ScreenPlay 5700 Multimedia Projector Logo
166 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
