Have hp descjet 3900 series printer. the printouts started appear with smudging black marks on the paper. how to solve the problem?
  • Anonymous Jan 14, 2009
    The ink does not seem to be drying.  Replacing the cartridge did not help.
    Problem Solver:
  • 15 Answers
REPLACE A NEW CARTRIDGE AND VERYFY THAT THIS IS REPEATING . IF YES CHECK WEATHER INK HAD LEAKED OUT FROM THE SERVICE STATION.CLEAN AND WASH OUT PRINTER SERVICE STATION AND PAPER FEED ROLLER .
Posted on May 04, 2008
My hp3600n makes a grinding sound at start and the printout always has gray verticle smudges on it
If you run the PQ troubleshooting pages you will likely find that your black cartridge is faulty. Sounds like the drum is dragging.
Aug 02, 2015 | HP LaserJet 3600n Printer
Printer: HP Laserjet 1010 model Black dots appear on the paper
Dots, Lines and smudges on the printouts are due to deteriorating cartridges and cleaning the green drum of the cartridge may help temporarily. Take out the cartridge and gently clean the roller/ green drum with a dry, soft, lint-free cloth wiping off the toner dots marks/ lines.
Also, make sure that the visible inside of the printer is clean and ther is no spilled toner inside, which sometimes results in dots.
Let me know if any further clarification/ assistance is required.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Dec 10, 2010 | HP LaserJet 1010 Printer
Printer is printing two smudge marks on my documents.
Two parts of the printer can affect this.
1) the toner cartridge
2) the fuser
Testing can be done to determine the problematic part.
Do a print using manual feed. Once the last bit of paper goes into the machine, open the printer door.
Remove the toner to check if smudge is there.
Replace toner cartridge if there is smudge, replace fuser it not.
May 29, 2009 | HP LaserJet 3330MFP All-In-One Printer
1 inch ink smudge down right side of paper
try going on ur computer that the printer is contected to and have the printer align itself
Mar 17, 2009 | HP LaserJet 1020 Printer
I have black smudges on my printouts. I using
This may be the cartridge itself, take the black ink cartridge out and check the head on it (the part that points in to the printer, usually down) and see if it is dirty or has ink smudges on it.
Mar 12, 2009 | Epson Stylus CX5000 InkJet Photo Printer
Ink smudges on the right side of the paper
Your problem is due to a worn fuser unit (upper fuser roller).
The teflon coating has worn again, alowing the toner to stick to the roller and then "repeat" about 3x down the paper (getting fainter each time).
You need to order a new fuser unit.
Click here to go to HP direct
RM1-1083-070CN Fuser assembly - 110 VAC - For LaserJet 4250/4350 series RM1-1083-070CN Fuser assembly - 220 VAC - For LaserJet 4250/4350 series
Make sure you order the currect voltage (US or UK)
Regards
Vince.
Mar 04, 2009 | HP LaserJet 4250n Printer
Smudged Printing
change ink cartdidge then try. check also paper jam.
if still problem then change ink cartridge then check.
Jan 05, 2009 | HP LaserJet 2100 Printer
Canon i9900 black ink smudging
ok, What cartridges are you using, Are the Canon cartridges?
What paper are you using, is it Canon paper?
If you are to both of these it could be wise ordering a printhead, but this is mostly caused in the uk by None Canon Paper.
Please let me know what you are using?
Sep 24, 2008 | Canon i9900 InkJet Photo Printer
HP Laserject Printer/Copier
first u must diagnostic the problem to see if the problem from the drum unit or the fusser unit by stop the printer in the middle of print and remove the paper then u can see if the smudge appear it well be from the toner if not then the fusser faulty
Mar 26, 2008 | HP LaserJet 1200 Printer
Minola print smudge
Pleas check the imagine unit drum, is it clean or does there are the same marks as in paper.
if yes, the IU drum cleaning or drum itself is damaged and needs to be replaced.
Try:
after sending a print job, when printer has take a paper from tray, open cover, open cover before the paper enter the fusing unit, then you can see, if the mark is allready in the paper then the problem is in the IU or toner cartridge, if not, then fusing unit rollers.
Dec 31, 2007 | Konica Minolta magicolor 2400 Laser...
180 people viewed this question
k24674
jasbo
jasbo
