Question about Empire Interactive Bad Boys 2 for Windows
I have installed bad boys 2 and there is a file coming which windows xp annot open it how i will install the game
  • 6 Answers
I have best solution of this game......... copy the video folder from cd 1 and paste this where you installed your game. then again go to your cd 1 and open DEViANCE folder & then copy BBpc and paste it your games folder. enjoy your game..........
Posted on Nov 09, 2010
Hey when i run the game it shows an error of insert disk 1 so what will i do plz help fast
Posted on Jul 09, 2011
Installed bad boys 2 and massage "Please insert disk 1"
sORRY I MADE A WRONG SOLUTION BUT YOU COULD DOWNLOAD THE GME FULL RIP OR MOUNT THE ISO FILE WITH UltraISo Whenever It says ensert disk 1 mount disk 1
May 16, 2011 | Empire Interactive Bad Boys 2 for Windows
Game won't load.
Go into my computer and click on the syberia disc and click install from there... See if that helps.
May 04, 2010 | Microids Syberia II for Windows
Every time i start bad boys 2 an alert message!:@
Babel component of Bad Boys II was not designed for running in Windows Vista or Windows 7. If you use one of these OS, run it in compatibility mode for Windows XP.
Detailed instructions and documentation here.
Apr 14, 2010 | Empire Interactive Bad Boys 2 for Windows
Error during babel initialisation during execution of bad boys 2
Everyone, I have found the solution to this. The simple thing is this game was never made to run on Windows Vista or above.
You can fix this easily though - go to your desktop and you should see the Bad Boys II launcher, right click and then go to properties. Then click on the compatibility tab and tick the box that says "Run this program in compatibility mode" and choose Windows XP.
Problem solved, if you want to thank me visit, daily-porn.co.uk to make some easy money.
Mar 31, 2009 | Video Game Consoles & Games
Initialization failed
You can still try to make the game compatible for installing it on the Windows Vista by following the steps below.
1. Insert the game disc in your CD-ROM drive, if the game setup or the autorun starts, exit it.
2. Open "Computer", Right Click the Cd Drive which has the game disk in it and select "Copy".
3. Go to your "Desktop" right click and then select "New" and click on "Folder" this should create a new folder on your desktop.
4. Open the New Folder and then Right Click and select "Paste".
6. After all the files are copied to the "New Folder" without any error messages then locate the file "Setup.exe" or "Setup" and right click and click on "Properties".
7. In the new window click on the "Compatibility" tab and run the program in compatibility mode for "Windows XP Service Pack 2" and then click on "Apply".
8. After applying changes double click on "Setup.exe" or "Setup" to launch the installation.
You can delete all the files copied from the CD after completing the installation
The game files need to be copied to the hard drive because the files on the game disk would not let you make changes while on the disk.
After the game is successfully installed right click on the game shortcut or the game "AOM.exe" in the root folder of the game and click and click on "Properties".
In the new window click on the "Compatibility" tab and run the program in compatibility mode for "Windows XP Service Pack 2" and then click on "Apply". (You can also try with the other options also)
The same set of steps can be used for installation of older games installation on Windows Vista.
Nov 19, 2008 | Microsoft Age of Mythology for Windows
3D mazeman
The game was released in 1998, and was developed for Windows 95/98.
To make the game run on Windows XP, try the compatibility for the installation and after it is installed use the same steps for making the game executable file compatible.
Note: Some game ".exe" file (executable file) would let you make changes in the Compatibility option, whereas older games might not give that option at all.
7. In the new window click on the "Compatibility" tab and run the program in compatibility mode for "Windows 98/ Windows Me" and then click on "Apply". (You can also try "Windows 95")
After the game is successfully installed right click on the game shortcut or the game ".exe" in the root folder of the game and click and click on "Properties".
In the new window click on the "Compatibility" tab and run the program in compatibility mode for "Windows 98/ Windows Me" and then click on "Apply". (Again, you can also try "Windows 95")
There are lot of files that need to be changed in order to get full functionality and to communicate with operating system and the hardware, hence there is no guarantee that the game might run even in cases where you will successfully install an older version of the game with the above mentioned steps.
Oct 24, 2008 | eGames 3D Mazeman Amazing Adventures for...
Installing
The game was released back in 2002, that means it was designed for older versions of Windows OS (Windows 98/ME/XP). The updates for the game do not have any patches for the installation to be compatible to the new Windows Vista OS as they were released on November, 21st 2002 aslo that patches resolve functionality issues after the game is successfully installed.
Some game ".exe" file (executeable file) would let you make changes in the Compatibility option, whereas older games might not give that option at all.
Oct 12, 2008 | ValuSoft Hard Truck: 18 Wheels of Steel...
Install
This solution is not for the XBOX version of the game, this is only for the PC version of the game Bard's Tale.
You can still try to make the game compatible for installing it on the Windows XP 64 bit by following the steps below.
7. In the new window click on the "Compatibility" tab and run the program in compatibility mode for "Windows XP" and then click on "Apply".
The same set of Compatibility steps can be used for installation of older games installation on Windows XP 64 bit and Windows Vista.
Again, this solution is not for the XBOX version of the game.
Sep 06, 2008 | Vivendi Universal Bards Tale: Song of the...
Empire Interactive Bad Boys 2 for Windows Logo
752 people viewed this question
Top Empire Interactive Video Game Consoles & Games Experts
Ankit Chandel
Ankit Chandel
Tom Chichester
EnergeeUK
Level 1 Expert
Are you an Empire Interactive Video Game Console and Game Expert? Answer questions, earn points and help others
