Question about Dell XPS 410 PC Desktop
While cleaning I took the processor out and now my Dell XPS 410 wont start.
  • 700 Answers
I do not understand what do you want to find under the processor??? Leprechauns???
If you desperately want to clean your computer, never ever use vacuum cleaner, if you want to clean heatsink and fan, exactly remove only and only fan, brush and blow heatsink if you must.
Now, again, as you did put already your computer to pieces:
1. switch off computer, remove power cord from teh socket
2. remove again the wall,
3. remove heatsink and fan, check if processor is correctly installed, replace heatsink and fan,
4. remove and re-insert memory sticks, thes have tendency to burn or get moved during cleaning, check if memory is correctly inserted
5. check power connectors on the motherboard, 24pin as well as 4 pin
6. check power supply itself
If computer after tha procedure still do not start, tehre question arises:
1. did you used vacuum cleaner to clean?
2. did you use static strap...
If your answer is yes/no you fried your processor, memory or motherboard... or all three, check then all three components against known working computer and then replace bit which you fried...
Posted on Aug 23, 2010
Want to replace processor intel V//V with a newer dup cpre at least but not sure if possible.
I would look at the motherboard specifications and then look it up online about what can or cannot be used with it. They often have a list of processors that can be used, on the makers website. Some even have forums. You can also look up the processor you want and see if it can be fitted to your motherboard. Intel might even be able to say if you give them enough specifications about your product.
Jan 10, 2016 | Dell XPS 410 PC Desktop
How do I change boot sequence on Dell XPS-410 desktop
Hi!
Hit F2 on startup to get into the BIOS. Then, modify the start up sequence in there.
Hope this helps!
Mar 01, 2015 | Dell XPS 410 PC Desktop
Dell XPS 410 turns off and on again like in loop
Get another power supply unit and check to make sure the power button is not sticking. That is how I would handle the matter. John
Apr 13, 2012 | Dell XPS 410 PC Desktop
Xps 410 will not start up 2 beeps
Hi Al,
This is possibly a RAM memory problem. Remove the RAM memory from the motherboard and clean off the connecting pins with an electronic contact cleaner or surgical spirits. Replace them one at a time(if you have more than one dimm installed) and check to see if you still have this error.
Best wishes,
Graemevm
Jan 12, 2012 | Dell XPS 410 PC Desktop
Blinking yellow power button xps 410 will not turn on
I suggest replacing the memory as the diagnostics lights suggest.
Memory can and does fail in some cases.
May 04, 2010 | Dell XPS 410 PC Desktop
XPS/Dimension 410/9200 Desktop, And Virtual Memory!!!!
you can set your virtual memory as high as 512 depending on what you want to do with your pc are you gamer if so reduce that setting if not and you using it for applications setting it higher will acheive better results.
Jan 26, 2010 | Dell XPS 410 PC Desktop
I have a dell xps 410 i replaced the power supply because it wont turn on still have the same problem,i used a dell replacement.it just shut down one day now it wont do anything just one yellow light on...
Ok to troubleshoot it, connect the PSU to the MotherBoard ONLY, test, you may find that with it connected to the MB only it doesn't work, remove RAM and check, if PSU still No Go then MB is faulty if OK, add devices, DVD, Hard Drive, one at a time untill you find one that stops the PSU, that is ya faulty bit. replace it.
Have dell xps 410 was on a network took it off now pinter wont
Click on HP's link http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=303756&lang=en& and select your Operating System. Then Download the driver for your printer. Follow the Instructions and Install it.
Oct 21, 2009 | Dell XPS 410 PC Desktop
Dell XPS 410 PC Desktop Logo
122 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
