I have a gas fired furnace with only two wires comming from the furnace and i bought a new honeywell rth7000 thermostat and it does not give me a wiring diagram for two wires
    Scholar:
  • 149 Answers
Which colors are they? one should be from the igniter that goes to W on the thermostat and the other goes to Rc just make sure that the one from the igniter goes to W
email me if you need additional help hvac.tech7872pr@gmail.com
here's some additional instructions if you need them:
http://customer.honeywell.com/techlit/pdf/PackedLit/69-2104ES.pdf
Posted on May 05, 2008
I just bought a Honeywell 5.2 Day RTH2300B Programmable thermostat to replace my old mercury thermostat for my gas fireplace. When I took of old thermostat it only has two wires. A white wire and a black...
I just installed a Honeywell 5.2 Day RTH2310B Programmable thermostat and I had to deal with the same situation: 2 wires, one white one black. After reading the edvice in one of the blog, the solution that worked for me was: BLACK ON Rc terminal and WHITE on W terminal. My furnace is running fine now. Hope it helps.
Dec 06, 2010 | Honeywell Focus 6300B 5-2 Days...
I am replacing an old Lennox thermostat with a new Lux DMH110 digital thermostat. My furnace(oil) has only two wires on the thermostat(heat only). I connected the wires according to directions of new...
Make sure on the furnace that you have the same colored wires connected at the thermostat to R and W. Check for good connections at both locations. You can always test to make sure the unit fires by crossing the two wires together. If the unit fires, you have a bad thermostat.
Feb 17, 2010 | Honeywell Programmable Thermostat Heater
RTH7000 thermostat won't maintain the heat I've
if the thermostat is wired correctly, your problem is likely in your furnace.
My first guess would be a faulty limit switch, but without seeing your furnace, it would be hard to say.
Have a qualified service person look it over... It would likely be a good time to have it cleaned and tuned also (once per year is best, or every other year reduces your chances having problems)
Jan 03, 2010 | Honeywell Programmable Thermostat Heater
With fresh batteries, the thermostat works fine, but after two or three days, the thermostat fails to turn on the furnance after the temp drops below the setting. Replace the batteries, and it works for a...
If you have a spare wire (unused) in the thermostat wire sheath you can eliminate the batteries as the power source.
Turn off the power to the furnace.
Open the thermostat and look for terminal "C". If it is not being used,then
look inside the furnace for the thermostat wire terminals. Black or blue are probably not being used. Take one of these wires and strip insulation back 1/2 inch. Connect this wire to the COMMON (C)(-)wires from the low voltage transformer.
Open the thermostat and connect the same wire to the "C" terminal on the thermostat.
Dec 22, 2009 | Honeywell Programmable Thermostat Heater
I have a TH8000 Vision Pro. It is controling a
Whats' so hard is the Honeywell thermostat has a built in 1@ differential. It is not adjustable.
You might ask your installer about a time delay relay installed in the furnace to break the thermostat heat wire (usually white wire).
Most time delay relays are 90 seconds. But that might be enough to reduce the furnace cycling.
Dec 15, 2009 | Honeywell Programmable Thermostat Heater
Updating old honeywell thermostat with a new honeywell thermostat
check in the unit heater to see what is hooked up most only need to have red from transformer white to call for heat and green to make the fan run in man and somtimes common usually blue or black
May 09, 2009 | Honeywell Programmable Thermostat Heater
Changing out old thermostat
your old thermostat is a milivolt and the wire runs from the heater to the thermostat. You have to open the back of the new one and connect the wire as per the instructions on the wireing diagram that came with the new one. I just installed a similar one myself, you will be very happy with it.
Jan 24, 2009 | Honeywell Electronic Programmable...
New honeywell thermostat on new gas furnace not working
sometimes there's a differential setting anywhere from 1-3 degrees, see if you can make sure it's down to 1
Nov 12, 2008 | Honeywell Programmable Thermostat Heater
Installing Honeywell RTH7000 - I have too many wires!
check to see if the B terminal is on the new t-stat if connect to it , but this terminal refers to heat pumps and is normally use to energize the reversing valve on the outside unit and not used on ac units , but normally the tag O/B is the same terminal on therostats
Oct 26, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
104 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
