Question about HP Compaq ProLiant DL580 G3 (364636HP1) Server
How i can replace one of server hard disks?do i need to turn off server. or i can replace it without turn server power off.
  • 149 Answers
Hi
All server drives support hot-swap mode so you can replace the disk when the server work
Posted on Aug 23, 2010
Physical disk not found
Move into Raid Controller bios (ctrl +c)
Check other hard drives are visible.
If yes, you may insert disk in other free slot and see if it detects on that slot. If same issue then particular hdd may be faulty. You have to replace it
If no, turn off server, reset scsi and power cables.
Turn on server and see if it detects hard drives. If server has same issue then either scsi cable or hdd back plane may be faulty. Chance is more for hdd back plane
Thanks
Oct 15, 2013 | IBM X236 Server
I have to format IBM server model no MT-M-8648-IIS by using window server 2003 but the error showing Hard Disk not traced out
Your hard disk may be faulty. If the BIOS cannot detectthe hard drive then it is faulty and you need to purchase a new hard disk before you can install Windows.
Aug 18, 2011 | IBM xSeries 226 Server
NO HARD DISK FOUND DELL POWER EDGE 2950
Your probably got one ofthe following:
1. har drive crash
2. Hdd controller failure
Ether witch will need replacment parts and that you would see a local tech for if you do not know what your doing. You might need a new hard drive or acontroller in this case.
Thanks and please do be considerate and leave postive feedback ratings.
Jun 07, 2010 | Dell PowerEdge 1600SC Server
Hard disk upgrade
I faced the same problem i asked to the ibm people they said that non ibm hdd's are not supporting x3400 servers and they are hanging when we work with non ibm hdds. when I use segate 1 TB sata hard disk the server working fine the only problem is little bit slow for booting and programme running, this not a broblem. so pls use 1 TB sata hdds with your x3400 servers.
Jan 15, 2010 | IBM x3400 Server
We have a Power edge 840 that can't not detect any HDD in starting process, although power and data led are on. Can you help me to solve this problem? Thank you very much! Best regard!
Check both the POWER and the DATA cables between the motherboard and the HDD (Hard Disk Drive).
Remove them, and then re-insert them.
Try connecting the DATA cable to an alternate connector on the motherboard.
Remove the HDD, and connect it to another computer,
to see if the HDD can be detected on that computer.
If not, the HDD is the problem.
Oct 27, 2009 | Dell PowerEdge 840 (becwmk1_2) Server
CAN YOU TELL ME HOW TO GET WINDOWS XP TO LOAD ON THE DELL 2600 POWEREDGE SERVER IT ONLY OFFERS SERVER 2000 AND SERVER 2003 AND I CANT USE EITHER OF THEM THANKS MIKE
Hi tham01,
First off, if the server has raid already setup, you will need to go into lsi logic to format the drives so you can install XP. Once the drives have been initiated from the server bios, just place XP in the CDROM, and shouldn't have a problem loading on the 2600 POWEREDGE SERVER. If your trying to install it with the Dell quick install disk, you can't!!! Install it on it's own without the Dell Disk.
Good Luck!
Mark
Jan 13, 2009 | Computers & Internet
RAID5 SCSI HDD
YOU WILL NEED TO UPGRADE THE FIRMWARE ON THE OLDER DRIVES
Dec 25, 2008 | Seagate (s40a102) 146 GB Hard Drive
Lacie Ethernet disk mini 500 Gb
I had exactly the same problem, no access to the windows media server - the no space message - and all my users missing from the user tab.
Following up from gogogo123's comment, we simply cleared the log and it was fine. I can only assume that there is an internal file size limit on the log file, and if it can't write your actions to the log then it doesn't do them!
Jan 22, 2008 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
HP Compaq ProLiant DL580 G3 (364636HP1) Server Logo
80 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
