Question about Casio Exilim EX-S1 Digital Camera
EX-S1: fault in function and data transfer
During data exchange with PC some fault happened (probably power
supply short interruption). Result - camera Casio EX-S1 doesn't work:
puts on, waits for 2-3 sec and shows "No Menu Data" on display.
When connecting to PC and switching data exchange on, the PC recognizes
USB device and after 5-7 sec puts the "removable disc F:" icon on the
control panel, but can not open this disc and read/write something to it, and starvates. Upon switching data exchange off, the icon removes from the table and PC continues to work.
Probable the root program failed? Could something be done in this case?
Thanks,
Alex (Ufa, RUSSIA)
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Casio Master
  • 102,366 Answers
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Posted on Jan 30, 2013
SOURCE: Exilim EX-VZ camera won't take pictures
I have just experienced exactly the same problem so went to a camera shop where they pointed out that my camera had had a fall. In fact it was in its case inside my handbag when I tripped and fell in the street. It worked for 5 days after the fall. The only solution is to go to Casio. I wonder if your camera has also had a shock of some kind.
Posted on Aug 05, 2007
jackboy
  • 2985 Answers
SOURCE: PC Connection problems
Simply disconnect the camera, Restart the computer. See what happens. If no go Do a restore to a day before the incident. Come on back Also if you have Casio software loaded -remove it - Windows can do with out that.
Posted on Sep 29, 2007
SOURCE: Reading images off the camera
If you cannot find a solution to your problem you may want to email fixityourself@gmail.com. He has good advice and good used parts at a fair price.
Posted on May 22, 2008
  • 10 Answers
SOURCE: Computer not detecting USB
Use the original cable. Download the correct USB driver from Casio website and install.
Posted on Jun 22, 2009
BillB-SA
  • 2761 Answers
SOURCE: Casio exlim EX- Z29 lens error upon power on
If you've recently dropped the camera you may have damaged the lens tube (housing) or jarred the zoom mechanism off of its track -- either of these problems will require professional repair. If the camera has not been dropped, your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may be too weak/worn to properly power the camera, or the camera may require professional repair.
Posted on Oct 17, 2009
Exchange Public Folder Recovery to PST
I would like to suggest you to use of PST Recovery Set. The PST recovery service, offered by PST Repair Kit, offers the highest quality of analysis during the processing of corrupted PST and OST files in Outlook. For more: https://www.pstrecoverykit.com/
Apr 24, 2015 | Microsoft Office Outlook 2007: Windows
Transfer OZ-750 Data to Computer
Hi Pat,
and with the indulgence of otacon and Ekse...
You would need the Docking Module and the attached COM1 cable/plug.
You might find this page/document very informative if not interesting. Should you need the software (Day-Timer Organizer), it is available here. Additionally, a Q & A about OZ750 is here.
Hope this be of additional help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 04, 2008 | Sharp Wizard OZ-730
I cant upload my photos to my pc
hi friend
here are several ways to transfer mobile phone photos onto your PC, ranging from, emailing them using GPRS, Bluetooth file transfers, Infrared file transfer, using MMS service, using a card reader or simply using a data cable. VideoJug themselves even have a film on the subject, but this guide will address transferring photographs to your PC using the manufacturer supplied data-cable and software.
  1. Step 1: Check To See If You Have The data Cable And SoftwareMost mobile phones nowadays come standard with a USB data transfer cable and bundled software utility. Check the box that your mobile phone came with for the cable and CD-Rom. If not provided with the software, it may be available as a free download from the manufacturer’s website. If your phone did not come with a data cable, check the manual if your model supports data cable transfers.
  2. //');document.write('');document.write('');} //]]> google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
  3. Step 2: Install The Communication SoftwareOnce you have located your software CD, check the system requirements necessary to run the software such as hardware specifications, operating systems supported etc. Install the software following on-screen instructions, but do not plug in the USB data cable or phone in just yet, unless the software requests you to do so during the installation process.
  4. Step 3: Connect Your Mobile Phone To The PC Using The Data CableOnce the installation is complete, the software would usually require a reboot of the PC before plugging in the mobile phone for the first time. Then connect your mobile phone to the data, and the cable to the USB port of your PC. Several phones may display a message on the mobile display that the phone is now connected to the PC, but if not don’t worry just yet!
  5. 1px.gif Remember never to unplug or disconnect the data cable from the phone during a data transfer or you could end up damaging your phone or loosing all your data.
  6. Step 4: Start Up The Software Package And Locate The Image Or File Transfer UtilityOnce connected, start up your mobile phone’s software, and browse through the interface. Most manufacturers offer some form of phone browser where you can browse through the content on your phone, copying files onto, or taking files off the mobile. The software utility may also offer a separate tool for transferring photos and video shot with your mobile, if this is the case use the utility!
  7. Step 5: Transfer Mobile Phone Photos Onto Your PCUse the software’s browser or photo utility to transfer your photographs to your PC. Some software tools provide image editing tools as well that will enable cropping, rotation, and sharpening of images once transferred to you PC. Don’t be afraid of referring to the software’s help file incase you get stuck.
  8. 1px.gif As phone models and manufacturers vary, it is always a good practice to read through the mobile phone user manual and the software's help or readme file while using this guide. It is also always good practice to use the backup function of the software first to ensure you can restore your phone back to its original state should anything happen to it.
download Samsung Pc suite and
Mar 31, 2010 | Samsung Tocco F480 - Pay Monthly Cellular...
Can a sonyo s1 from sprint be flashed to cricket?
it can be unlocked by calling your carrier and they will give you the infomation unlock code as long as the account is current and not delienquent if canceled it will cause some of the features not to work on the device
Jul 08, 2009 | Csdc DataPilot Data Transfer Suite for...
4 way system from master phone socket I have broadband lights flashing intermittently at sporadic intervals on new router Ethernet light follows broadband light Line has been checked by Plusnet and no...
This light is replicating the spordic exchange of data, and the light is designed that way. This means your braodband and modem are both functioning perfectly.
Jun 16, 2009 | ASUS Computers & Internet
Motorola L6i usb data cable software
my motorola l6i cannot connect with my pc through data cable. so pls give me USB Data transfer sotware .................send software on my e-mail id....................www.raj_veer.19@rediffmail.com
Aug 09, 2008 | Motorola Mobility Mobile PhoneTools 3.0...
Pes2008
That's the best way to do over your PC to your USB. Create a folder on the storage media in which to save the update data.
Using a PC, create a folder named “PS3” on the storage media or USB device. Within the PS3 folder, create a folder named “UPDATE”.
  • Download the update data and save it in the UPDATE folder created in step 1. Select here to start the download.
Notice
Be sure to save the update data as noted below. If the data is not saved in the correct way, the PS3™ system will not recognize the update data.
  • File name: Save as file name “PS3UPDAT.PUP”.
    Update procedure
Notices
  • Do not turn off the PS3™ system or remove the storage media or USB device during an update. If an update is cancelled before completion, the system software may become damaged, and the system may require servicing or exchange.
  • The power button on the PS3™ system front is not active during an update.
  1. Insert the storage media or USB device that contains the update data in the PS3™ system.
  2. From the home menu, select (Settings) > (System Update), and then press the button
The folder name must be in all uppercase letters.
    Update procedure
Notices
  2. From the home menu, select (Settings) > (System Update), and then press the button.
  3. Select [Update via Storage Media], and then press the button.
    The system automatically searches for and finds the update data saved on the storage media or USB device.
  4. Start the update data.
    Press the button to start the update data. Follow the on-screen instructions to complete the update.
  5. Confirm that the update was successful.
    After the update has been completed, go to (Settings) > (System Settings) > [System Information]. If the System Software field displays the version number of the update, the update was successful.
Hint
You can delete the update data from the storage media or USB device after the update has been successfully completed.
Jan 06, 2008 | Sony Playstation 3 (PS3) Console
Backing up data from PDA with damanged screen.
u can sync ur data with pc using active sync. everything link contacts, schedule etc can be transferred to pc
Aug 13, 2007 | HTC S710 Smartphone
Casio Exilim EX-S1 Digital Camera Logo
62 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
mohamed salim shaikh
Are you a Casio Camera Expert? Answer questions, earn points and help others
