Question about HP Photosmart C5180 All-In-One InkJet Printer
Hello, I have an HP Photosmart C5180 All-in-one printer. Printer cannot/will not produce a workable document in black. After about 2 lines large gaps appear. It will print fine in any other colour. With black it shows all signs of a dirty print head even after the head cleaner routine. However, it produces good results when printing both B&W and colour photographs (on photo paper) and produces a perfect result from the extended self diagnostic test, including everything printed in black. Changing the black ink cartridge made no difference at all and the current one is a genuine HP ink cartridge insalled on 6 Aug 2010 with an expiry date of 29 Oct 2011. Help please! Lawrence Williams lawrence@home-secretary.co.uk
  • lawrence221 Aug 26, 2010
    Hi Owoblow11 concerning my HP Photosmart C5180 All-in-one printer
    I tried everything except taking the printer to pieces to get at the print head.
    I held down 6 and # keys (on the computer keyboard) whilst unplugging the printer (without turning it off) and then plugged it in again as you suggested but no matter how long I kept the 6 & # keys depressed neither the monitor nor the small printer screen went blank. The printer just continued to boot up as normal.
    I also tried unplugging the printer during boot up and re-plugging but again, it just carried on booting up.
    I then loaded a new genuine cartridge, which the printer acknowledged "New genuine cartridge detected" and then tried to print. Absolutely nothing in black at all although all the other colours worked ok, even after cleaning the print head.
    How difficult is it to get the print head out for cleaning?
    Lawrence Williams
    Genius:
  • 1,478 Answers
Do you have another black cartridge? If so please install it and try again. Clean the cartridge's print head and contact points. Also clean the contact points on the printer, leave to dry. I would also suggest you to use a new cartridge to make sure if the problem is related to Cartridge. If the problem still persist, reset the printer. Follow this steps to reset your printer,
. Without turning the unit off, unplug the power cord from the back of the product.
2. Press and hold “# and 6′ keys.
3. While holding those keys plug the power cord back in.
4. Wait until the screen goes blank before you release those keys.
5. Follow on printer screen instructions.
You can also power off the printer and power on back, while the printer is warming up/loading, pull out the plug from AC wall, this can also help to rest your printer.
If after resetting the problem persist, it means the cartridge you inserted into the printer is not genuine. You will need to get a genuine cartridge.
Take care.
Posted on Aug 23, 2010
What is printer documentation
Hello
You are looking for the user guide to your printer I assumes, and posts this solution.
Try these links.
h10032.www1.hp.com/ctg/Manual/c00737535.pdf - United States
retrevo.com
downloadmanualuserguide.blogspot.com/.../hp-photosmart-c5180-m..
http://www.dataentryjobs.us/67948.html
Feb 07, 2012 | HP Photosmart C5180 All-In-One InkJet...
C5180 will print when sending document from computer to printer but will not make copies or scan when using printer. The scanned or copied document has many vertical and horizontal lines and many blocks of...
I recommend you work through the instructions provided in this HP support article for your printer. If resetting the printer doesn't work, please check the available resources for your printer found here and here.
Hp has a wealth of online resources to guide you with troubleshooting your printer errors, and with patience and a deliberate approach, you will often be able to zero in on the cause of the problem and solve it yourself. Just make sure you follow the steps outlined in the order they are given, after determining the most likely solution that matches the symptoms your printer displays.
With any luck, and a little routine maintenance, your printer will continue to provide useful service.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Dec 20, 2010 | HP Photosmart C5180 All-In-One InkJet...
Ink system has failed. Unable to print. Refer to printer documentation Error: 0xc18a0201
I have a HP photosmart C5180 all in one. It has an error message that says....Ink system failed unable to print refer to printer documentation error OXCa0501. By chance would you know what to do to fix it? Thanks
May 25, 2010 | HP Photosmart C5180 All-In-One InkJet...
ERROR CODE OXC19A0027 ON AN HP FOFO SMART C7280
Hello.
Per HP web site -
Turn printer off -
unplug power cord from printer -
remove all ink cartridges -
wait 2 minutes -
plug power cord back in -
turn power back on -
install ink cartridges when prompted.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=uk&docname=c00551397
May 01, 2010 | HP Photosmart C5180 All-In-One InkJet...
Ink system failure message on HP photosmart c5180 all in one
tengo una impresora photomart c5180 hp y me produce un error 0xc18a0107
Nov 07, 2009 | HP Photosmart C5180 All-In-One InkJet...
My printer won't print word documents!
The best thing to do is take it in for warranty service.
Jan 12, 2008 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart C5180 All-In-One InkJet Printer Logo
67 people viewed this question
Seeker5211
Seeker5211
