My washing machine does not spin and the water does not stop when it reached it's level.
  • 4,070 Answers
Your pressure switch stops the water and allows it to start the next cycle. It's a switch either in the control panel or at the top of the tub with a small tube connected to it which goes down between the inner and outer tub. As the water level increases the air in the tube is compressed until there is enough pressure to make the switch stopping the water from filling. This tube can get clogged and the switch won't work. Remove the tube and clean it out. Blowing on the tube when it's still connected to the switch will make the switch if it's working and clear.
Posted on Aug 23, 2010
How much water does a 7kg front loader use?
Depends what cycle it's used on. For example "Spin" uses no water at all.
If you want to measure it, run a cycle without laundry, and mark on a piece of paper tape stuck to the porthole how far up the water level reaches. Count how many times the machine empties and refills during your chosen wash cycle. After the final spin, close the door, and slowly refill the machine via the detergent drawer from a graduated jug or watering can, until the water level reaches the mark on the porthole. Multiply the volume poured in by the number of cycles, and there's your answer - approximately.
Feb 03, 2018 | Washing Machines
Tip
The washing machine is under filling water?
This problem is due to fault in the Water-level switch in washing machine.
The Water-level switch is the part in the washing machine that senses the filling water in the tub. When the water reaches to its required quantity the Water-level switch sends the command to stop the water supply. But if the Water-level switch is faulty. It will sense the wrong quantity of water in the machine. And makes the water supply stop bit early then required. So washer does not fills with required water .The Water-level switch is located at the bottom of the outer tub in the washing machine. Many a times removing and reconnecting the switch makes it proper. in other cases it needs to be replaced.
These will help. Thanks
on Mar 18, 2010 | Washing Machines
I have a defy laundromaid. The machine doesn't reach the correct water level to start the washing cycle. However if I deselect wash and rinse options it does spin
good solid commercial unit 13 kg
could be a timer or control board fault
my best guess is
faulty water level sensor
Sep 20, 2016 | Washing Machines
Its stops when it reaches in 39 minute the function set on cottons what is the problem
Try resetting the mainboard by removing the wall plug overnight. May also be a faulty lid switch if it is a top loader.
  • Hello, my washing machine stops completely when it reaches ... www.shopyourway.com > Manage My Life > Questions ... my washing machine stops completely when it reaches the pause cycle, ... Answered in 5 minutes ... Kenmore washing machine 417 44252500.
  • Washing machine stops mid cycle - White Goods Help www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help Possible causes when washing machine stops mid cycle by a repairman with 30 years experience.
  • What could cause my washing machine to stop before the ... diy.stackexchange.com/questions/21181/what-could-cause-my-washing... What could cause my washing machine to stop before the ... i.e. it never reaches the end of the cycle ... What would cause my washing machine to stop at the rinse ...
  • Washer Stops Mid Cycle - Repair Parts - RepairClinic.com www.repairclinic.com/...A-Washing-Machine/50---/Washer-stops-mid-cycle ... listed below for the symptom Washer stops mid cycle are ordered from most likely to least likely to occur. ... Electrolux Front Load Washing Machine Disassembly
  • once my washing machine reaches the rinse cycle, about 3 ... https://answers.yahoo.com/question/index?qid=20080526150940AA3izVT
    • RESOLVED
    • 6 POSTS
    • 5 TOTAL ANSWERS
    2008-05-26 · Once my washing machine reaches the rinse cycle, about 3 minutes after ... Once my washing machine reaches ... My washing machine stops after the ...
  • Common Problems to all Washing Machine Brands ' Washing www.appliancerepair.net/washing-machine-repair-2.html Washing machine designs vary widely, ... but stop agitating after a few minutes and fill some more. ... stop the spin cycle and unplug the washer.
  • My washing machine will not spin and now it does not stop ... www.shopyourway.com > Manage My Life > Questions My washing machine will not spin and now it does not stop when it reaches the water level. ... Answered in 5 minutes
  • washer stops in the middle of washing cycle - Appliance ... forum.appliancepartspros.com > ... > Washer Repair
    • 6 POSTS
    • FIRST POST: 2012-02-07
    2012-06-22 · Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer stops in the ... but when the timer reaches 24 minutes left to ... Washing Machine stops ...
  • LG Washer Stuck Timer 2 - YouTube Youtube
    • BY SBUBANDIT
    • 14 MIN
    • 4.9K VIEWS
    2012-08-29 · Video embedded · In this video the washer display shows 8 minutes remaining in ... machine stops and turns ... 10kg Top Load LG Washing Machine
  • http://www.bing.com/search?q=washing+machine+stops+when+it+reaches+39+minutes&qs=n&form=QBRE&pq=washing+machine+stops+when+it+reaches+39+minute&sc=0-47&sp=-1&sk=&cvid=04BC47135B524BD8B5BAC3759F010C1B
    Jun 10, 2016 | Washing Machines
    My Kenmore 300 model # 11028332700 washing machine filled with water and stopped working. It won't agitate, spin or drain. I've replaced with lid switch and checked the coupling and it's fine. What's...
    Possible fault with the water level sensor , it must send signals to the program controller main board to switch on the motor for the wash cycle only when the water level set is reached. Remove the water level controller unit , check the diaphragm with a blow test , it must switch with vacuum , if not replace.
    Aug 22, 2013 | Kenmore Washing Machines
    My washing machine comes up with error code 4e i have changed the solenoid valve and cleared any possible blockage water is flowing in to the machine but still getting the same error code if i chose the...
    Your machine has a fault with the water level contoller switch - pressure switch that activates when water reaches the level set . So check the water level controller and test. If not the fault can be with the program controller unit.
    Please check this link for parts identification.
    http://www.espares.co.uk/advice/washing-machines/a/7/40/identifying-washing-machine-parts.html
    Sep 17, 2011 | Samsung Washing Machines
    Hoover 750 top loader goes through cycle drains but will not spin if you manually put it in spin it will not stop fills up and rinses drains but will not go again into spin until manually do it then again...
    Two issues are possible , After the first start of the wash , check if the machine starts only when the water level is reached- to confirm the working of the water level sensor.
    Secondly if the program cycles seems out of hand then it is possible there are errors in the program controller unit.
    Apr 21, 2011 | Washing Machines
    When i turn on my washing maschine it takes in water as normal but when its time for it to spin it does nothing so it trys to take in more water and the same thing happens again then it turns it sel*** and...
    you have to check the water level sensor, included to check the small hose from the drum to the water level sensor. there must be pressure from the water to suppress these sensors, the operation of the washing machine are:
    washing process / cycles will start when the water level, which we set is reached. then there is pressure from the water through a hose, pressure water level sensor.
    while SPIN is the reverse process of the washing process, water in the drums will be drained through the drain valve. and there is no pressure in the water level sensor so that the spin will start.
    Jul 14, 2010 | Hotpoint Aquarius WF220 Front Load Washer
    My Kenmore 70 is also overfilling...
    Sounds like it could be a faulty water level switch. A defect or an obstruction can mean that it can't tell the water to shut off. This switch raises the water level in the clothes tub. It's usually a diaphragm like device with a small clear plastic tube attached between the switch and the bottom of the washer's outer tub. As the water level rises, the pressure increases on the air in the plastic tube. When the pressure reaches a certain level, it activates the switch and turns off the water. It also signals the washer to begin the wash cycle. Clean out any obstruction in the plastic tube or replace the water level switch. Hope this helped.
    Jul 16, 2009 | Kenmore 22422 Top Load Washer
    Washing Machines Logo
    14 people viewed this question
    Top Washing Machines Experts
