Question about Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator
I have an amana br22 the botom freezer gets an ice block on the radiator coils then air flow slows down to top section i have to hot air gun the freezer to get the air to start moving
    President:
  • 670 Answers
The ice block is due to a defrost circuit failure. Typical problems are due to the defrost heater, defrost timer if used on this model and defrost thermostat. Since you are using a heat gun to melt the ice, check the the defrost heater with a meter to determine whether it needs to be replaced.
Posted on Aug 23, 2010
Fridge is not cooling well. Freezer is fine
This problem is related to defrost.The defrost cycle is not running as it should be. The other possibility can be ice blockage in the ventilations.
The defrost is not working,.The evaporator coil in the inner section of freezer is got blocked by ice .
Try manual defrost reset procedure: ----
First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. It will take near to 4 hours to get run in its proper cooling cycle. Then check, if the problem returns again. If the same problem occurs then it's defrost problem. The defrost board and the defrost thermostat/heater is not functioning properly and it has to be checked and replaced.
Check the damper if there is too much water collected in the damper then press the damper and remove the water collected in it. The procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the refrigerator section and the refrigerator section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located. Now this problem which you mentioned. In this problem the freezer works but no cooling in fridge, this happens if the thermostat is not functioning or the heater is not heating. Then the ice starts getting collected on the evaporator coil. The evaporator coil is at the internal section of freezer. If too much ice gets
collected then this ice blocks the fan in the freezer section from functioning and this blocks the damper section with ice getting collected there. This all procedure is controlled by the main defrost board of the unit. Now if the damper is not got blocked with too much water or if the ice is not got collected on the damper area then check the evaporator coils. If there is too much ice got collected on the coils, then takes a hair dryer and melt the collected ice. Then see if the problem returns again. But if there is little bit ice collected on the coils and fan is running properly then it's not a problem. In that case main defrost board is faulty and it has to be replaced. The main defrost board is working but its not controlling the functions as required so the freezer works but fridge section not getting cold..
You can get required parts from sears part direct online site or from repairclinic.com site.
This will help. Thanks. Helpmech.
Feb 25, 2011 | Frigidaire FRT21P5A Top Freezer...
Amana ARB9059cs: compressor makes loud noise (come and go). Refrigerator not working but bottom freezer is working. All lights on. Please advise.
they had problems with some compressors siezing up due to lubrication issues.refrig not cooling probably air flow problem.either fan in freezer section not working,coils iced up,or return air vent blocked
Jan 25, 2010 | Amana ARB9059CS Bottom Freezer...
Ice maker has slowed down almost to a stop We get about 3 sets of ice a day used to fill up the tray a
ck the freezer tempt / if around 15 deg It's not cold enough and ice producton will be slow .clean the cond coil this will help and make sure the cond fan is working . it may also need the charge adjusted ( loss of refergerant ) . or possible cold control . and look for ice build up in back of freezer .. this would slow the air flow . .. **** hope some of these help . ****
Jan 16, 2010 | Amana ABB1927DE Bottom Freezer...
Amana bottom freezer problem
It sounds like the condenser coil might be freezing up. This happened to me on my bottom freezer. The cooling part of your fridge is only in the back of the freezer compartment. The cold air from the freezer blows up through a vent in the back to the fridge and comes out at the top. If the coils do not defrost (which is what happened with mine) the air flow is blocked by the ice and can't get to the fridge compartment. Your freezer will still be cold but your fridge won't. If you pull the plug on it and time things right you can defrost the coils but this will only postpone the problem. Both will work for awhile again until the coils ice up again. You can also pull out the freezer drawere and try to defrost the coil with a blow dryer. You have to disconnect the icemaker and pull out the back panel behind the freezer to get to it though.
May 25, 2009 | Amana ABB1927DE Bottom Freezer...
Amana BR22 top refrig not cooling
HI, your Air damper control assembly is faulty. you should replace this vital part asap.
May 24, 2009 | Amana ABB1924DEB / ABB1924DEW / ABB1924DEQ...
Kenmore elite 596 73503201 no cooling in top compartment
if the freezer is getting cold the problem is due to the cold air from the freezer not getting into the refrigerator. There are several things that can cause this problem. The coils in the freezer icing up and not defrosting properly is one of the things that can cause the refrigerator not to get cold enough. Another problem is the fan that blows the cold air from the freezer compartment into the refrigerator, not working. When the compressor is running open the refrigerator's door and push the switch that makes the light go out. You should hear the fan blowing the cold air from the freezer into the refrigerator, when this switch is pushed in. If the fan is working then you will need to find what is blocking the air flow. Iced up coils are a common problem. The icing problem can be due to a defective defrost timer or something defective in the defrost circuit. Click here for more information. Check for these problems and let me know what you have found.
REFRIGERATOR TROUBLESHOOTING
#1 Refrigerator side getting warm Freezer still cold
Evaporator fan motor not running.
Defective defrost timer. See Defrost Diagnosis Procedure
Defrost heater defective. See Defrost Diagnosis Procedure
Defrost thermostat defective. See Defrost Diagnosis Procedure
Airflow blocked from freezer compartment.
Freezer control turned to "coldest" setting blocking air flow to refrigerator side. On most refrigerator/freezers, the freezer control closes a baffle when turned to coldest setting, and this blocks off the air flow to the fresh food compartment.
Fan blade broken.
Defective door switch on older models.
Light staying on with door closed.
2 Refrigerator & freezer compartments both are getting warm
Make sure refrigerator is plugged in and has power.
Condenser fan motor on bottom under refrigerator not running.
Condenser coil clogged.
Defective defrost heater. See Defrost Diagnosis Procedure
Defective defrost thermostat. See Defrost Diagnosis Procedure
Cold control defective.
Compressor overload defective.
Compressor relay defective.
Compressor defective.
Low on refrigerant. #3 Freezer compartment getting hot.
Defrost timer stuck in defrost cycle.(replace)
Defrost thermostat stuck.(replace)
Ice maker stuck in harvest cycle
Light staying on with door closed. 4 Ice maker not making ice
Defective inlet water valve.
Freezer temperature not cold enough. (see problem # 2 & 3 above)
Defective thermostat in ice maker.
Defective drive motor.
Water inlet tube clogged with ice.
Defective module in newer style icemaker. 5 Refrigerator sweating around door edges
Door gaskets leaking air.
Defective case heaters.
Energy saver switch not set to reduce exterior moisture
also if require more help click the link http://www.applianceaid.com/refrigerator.html please do rate the solution .thanks in advance.thank you for using fixya.
Mar 27, 2009 | Refrigerators
Amana (freezer on top) not making ice; fridge warm
I would be calling the store from where it was purchased it should be under warranty. If the ice maker is not working the freezer is not getting down to proper temp. therefor the refrigerator does not cool because all cooling takes place in the freezer, there is a damper between the refrigerator and freezer that allows air through cooling the refrigeration section. Look for ice on the back wall, of the freezer section, If present then the defrost cycle is not working. The evap.coil is icing up and there is no air blowing into the refrigerator. This is the most common problem.
Oct 20, 2008 | Amana ATB1836AR Top Freezer Refrigerator
Amana Side-by-Side refrigerator hot spot
hi tanks for the question there are heaters at the spots you said were hot and those heaters are there to prevent moist air from hitting cold surface and create warer droplets from forming on those surfaces i would remove the back of the fridge and vacuum it out that should solve your problem thanks the appliance doc
Sep 18, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Freezer works fine but the fridge won't get cold
It sounds like cold air from the freezer isn't making it to the fridge compartment. This can be cause by a several things. The damper that lets air into the fresh food side is stuck in "closed" position, the temp sensor (t-stat) isn't working properly, the evaporator fan (in the freezer comp above the coils) isn't working to blow air up to the fresh food section. In some situations, the defrost cycle for the freezer section isn't working and the coils have frozen into a block of ice and air can't flow over them properly so you get not cold air to the fresh food section but the freezer still stays cold due to the block of ice.
Feb 21, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Fridge problems - frigidaire
Sort of sounds like the adaptive defrost board is bad and you are not going into a defrost cycle. Do you have ice build up on the lower interior freezer section? Are the vent slots full of frost/ice? Ideally, pull the freezer shelfs out and take the little aluminum panel off the interior back to look at the coils. Are they basically a block of ice and frost? The problem happens when the unit doesn't go into defrost cycle and the coils freeze up. That blocks the air flow in the freezer so you get frozen food at the bottom but soft stuff at the top. And the frige just can't get enough cool/cold air from the freezer section to cool anymore. Power surges or blackouts, etc. can just destroy the defrost circuit board. Without good air flow the unit is not going to cool properly.
Dec 17, 2006 | Frigidaire PHSC39EESS Stainless Steel Side...
Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator Logo
152 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
