Question about Kelvinator Ovens
De Ville Std Eye-level oven operating manual or instructions needed.
  • deacondick Aug 23, 2010
    Have already been to Kelvinator in South Africa
  • 2,272 Answers
The kelvinator service center has stopped the manual for De Ville std Eye-Level Oven for other online sites.But you can try getting this manual from Kelvinator service center. To get help from Kelvinator service center.Please click on the link below directly.And fill the required details in the link. http://www.kelvinator.co.za/customer_care.html -------------- Keep updated.Thanks.
Posted on Aug 23, 2010
    Top Expert:
  • Kelvinator Master
  • 79,189 Answers
To have any hope of the manual being avial on-line need the exact model number and year produced.
How do I access the fixing nut on a loose handle on a De Dietrich DME 795x oven.
not so easy
gee ...thats a glass front pull down frame
the user manual
page 8 shows the door but no disassembly of the frame
if no screws to get into the frame and loose screw
..might have to buy the whole door
DeDietrich DME795X Instructions For Use Manual Description Of Your...
Jun 01, 2016 | De Dietrich Ovens
How do I find the instructions manual for De Dietrich DOP705X Multifunction Plus Electric Built In Single Oven (DOP705X)
Go here: http://www.dedietrich.sg/sg/collections/oven.html#/others/user-manuals-10/ then look under User Manuals. Put in Model Number Collection - Cooking Range (or Product Number, if known), Available Language (EN), then download Manual in PDF
Dec 26, 2014 | De Dietrich Ovens
Having gas eye level oven and hob fitted what distance do we need to leave between the two
All the information you require will be in the manufacturers instruction books. If you have mislaid these then contact the retailer or manufacturer for advice. It is essential you follow their recommendations to avoid errors that could be ultimately dangerous.
Sep 22, 2009 | Belling XOU252 Electric Single Oven
I have a jenn-air double oven that is level for cooking on the bottom but the top oven is not level. I can't find manuals on the oven. Is there an adjustment between the upper and the lower oven. Do you...
First check to determine if your cabinet face is plumb (level), as sometimes that is the problem. If the entire face of the cabinents are plumb on both side, you'll likely need to either shim the top edge of the upper oven section or remove the oven and readjust the leveling adjustments (or shim the rear of the upper oven assembly), depending on just how far off the oven is from being plumb and level.
I've tried searching for the installation manual for your oven and found three (3) possible model manuals that could be helpful. I've included the link to the Jenn-air site so you can look at each and glean which one would be the most helpful for your issue.
The link will show the owners manuals and installation instructions that should apply for your situation.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=JJW8230D&siteCd=JA_EN_US
Jul 13, 2009 | Jenn-Air JJW8230D Electric Double Oven
What connection do you require for eye level electric double oven
You need a 45amp circuit for this double oven, under no circumstances , try to run it off a 13 amp circuit.
Plz rate my solution.
Thankyou.
Jan 25, 2009 | Neff U1421 Double circotherm Electric Oven
De Dietrich Oven - Clock tripping back to 00:00 means I cant turn on my oven!
its a fix more than a solution but you can bypass the clock thus allowing the oven to operate again
unplug at the mains and remove the oven from the housing remove the two fastening screws from the metal lid on the top of the oven ,and remove the lid
you will see the timer back panel with 3 wires coming to it, 2 are black (switching line) and 1 is red (Live feed to timer )
If you pull the connectors from the 2 black wires from the timer board and connect the ends together using a connector block, the timer switch becomes inactive and allows the oven functions to operate again.
you will have no timer functions but its a cheap fix and who uses the timer any way
good luck Andy B
ps if anyone has a set of operating manuals for ths oven i would be glad of a copy
May 13, 2008 | De Dietrich DOC310 Electric Single Oven
Ovens Logo
473 people viewed this question
Top Kelvinator Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a Kelvinator Oven Expert? Answer questions, earn points and help others
