Question about Kenmore 93862 Top Load Stacked Washer / Dryer
Dryer problem i have staked washer / dryer no model on it it's no heat on dryer p / n 131966700
  • Anonymous Apr 18, 2009
    weve had this dryer for a couple of years and there were no problems yet but the dryer desnt seem to work
  • 240 Answers
Check input voltage make sure you have 240 volts red to black and 120 red or black to white. then check heating element. and hi temp cutoff. On Frigidaire built machines (includes some GEs) a temp thermistor on exhaust duct at front of machine is a common problem. 50ohms is normal- less causes problems
Posted on May 04, 2008
Remove and replace heating element in GE Dryer
Not enough info! what is model number?
GE dryers has many models and each one has different procedure to remove heating element
Apr 20, 2014 | GE Washing Machines
How do i replace the heating element on my kenmore stackable washer dryer 98702 machine
Could you please post the model number of the unit? It will be under the washer lid, in the dryer door, on the top, or the side of your unit.
Dec 25, 2010 | Kenmore Washing Machines
Its about my washer/dryer combo whirlpool model lte6234dqs: -the dryer don't produce hot air and therefore don't dry. -Anybody please?
check your breaker to the appliance you must have 220 volts before it will heat if you only have 110 volts it will run but not heat otherwise it could be a thermostat or heating element which is hard to say with out me being there to check it out with a meter
Nov 19, 2010 | Whirlpool LTE5243D Top Load Stacked...
I have a stackable washer/dryer whirlpool model #WET3300SQ1. Heating element in dryer is not heating. We have replaced the heating element and it is still not working.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 18, 2010 | Whirlpool LTE6234D Top Load Stacked...
Kenmore Stackable washer/dryer Model #11088752793, won't heat
Either the elements have blown, or it could be a device called a thermal overload which has popped. (There may also be a loose wire which connects to the heating elements). Have your drier checked out by a good handyman or technician.
Best wishes,
Graemevm
Apr 18, 2010 | Kenmore 98702 Stacked Washer/Dryer
Our staked washer dryer model 41790872991 washer will fill with water but nothing else I think the motor must have died
The first thing to check is power to the unit then the lid switch. If the lid switch is not making contact the washer will fill but will not run. Turn off all the power to the unit. Remove the front panel with to philips screws on the front bottom, rock the bottom towards you and the panel will come down and off. The lid switch is on the top right side. Take an ohm reading on the switch, it should measure close to 0 ohms when the lid is closed and infinite ohms or no reading when the lid is open. Note: There may be four wires going to this switch 2 for the switch contacts and 2 for the door lock if this washer has a lock. In this case take the panel off between the washer and dryer and connected to the panel will be a wiring diagram and you will need to determine the color of wires that is making contact for the lid switch. If the switch is not the culprit please repost as this could be a timer or motor problem. The motors do not usually fail in these washers.
Thank you
Jan 23, 2010 | Washing Machines
My kenmore 417.94812301 staked washer / dryer problem
Your dryer was made by Frigidaire and needs what is called a rear bearing kit (#5303281153 costs about $30) from frigidaire.
there is also a good chance that your bearing failed because the dryer overheated (overheating is mostly caused by the venting being restricted)
Oct 28, 2007 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 93862 Top Load Stacked Washer / Dryer Logo
87 people viewed this question
Sal De
fordexpert
Robert Rankin
