Question about Admiral AAV7000A
Its constantly in the drain cycle - Admiral AAV7000A
  • Admiral Master
  • 909 Answers
Very seldom is the motor faulty on those units. My diagnocis is a blocked pressure switch pipe. What happens, after a period of time soap starts to build up in the machine. A direct hole outlet is the pressure switch outlet. Basically, you need to locate the clear thin(1/4 inch ) plastic pipe attached to the drum. once off, place another one similar onto that point and blow hard into the the second pipe. You should feel resistence initially the it will be free. Once happy all is clear, reinstall original pipe and test.(Make sure plug is pull when working on and around the drum Please let me know thanks. terfou@imaginet.co.za.
Posted on Aug 23, 2010
Water drains during wash cycle
A couple things to check, is it actually turning on the drain pump? Is the water valve leaking by?
Apr 10, 2013 | Fisher and Paykel Fisher Paykel Intuitive...
Wash cycle starts then drains washes then drains continuously. Every few seconds
Hello Peter,
What happens after a few seconds of the constant changing cycles?
Bruce
Jan 12, 2011 | Miele W310 Front Load Washer
The water constantly drains so it will not fill and will not continue with the cycle. Any ideas?
Drain hose to far down in drain. Raise drain hose at drain and secure so it doesn't get sucked down in again.
Jan 27, 2010 | GE Spacemaker Washer and Dryer Electric...
DWF 415 Ikea Whirlpool Dishwasher as constant
DWF 415 Ikea Whirlpool Dishwasher has constant green blinking light. Drain pump works ok (as it will pump out a jug of water if I tip it into it!) but no water comes in. Cycle stops about 30 seconds after thre is no more water to pump. Any ideas on how to fix?
Oct 09, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Gets to the spin cycle and does not spin and drain
What is error code?
Does unit spin?
Does unit drain?
Does unit fill on all water settings?
Ie set to hot, warm, and cold and see if fills.
Jul 14, 2009 | Frigidaire GLTF2940ES Front Load Washer
Drain in freezer plugs up
sometimes can be solved by loosely coiling a piece of solid copper wire around the defrost heating element and down into the drain a little. the radiant heat on the wire during defrost cycle may help keep the drain open
Mar 13, 2009 | GE Refrigerators
Water won't drain out of dishwasher
outflow soloenoid stuck/ blocked, remove and clean/ replace as required
Jan 27, 2009 | GE Dishwashers
Eco light flashing on Global 300
drained out where the float is, haven't run a full cycle yet but a partial cycle worked. i think definitely drain the float tank.
Apr 18, 2008 | Dishwashers
Admiral AAV7000A Logo
18 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
