Question about General Electric JEB1860 1100 Watts Microwave Oven
Display works, turntable turns, but it won't heat.
    President:
  • 670 Answers
If it making a loud humming or buzzing noise when it is turned on, it could mean that the magnetron has failed. If that is the case, then it typically not worth fixing, since the cost to repair is almost as much as a new oven.
Posted on Aug 23, 2010
  • 75 Answers
Check the fuse first.then megnetron.most of time the fuse is blown and the oven seems to be fine but not working.
Posted on Aug 24, 2010
GE Spacemaker XL1800 not working?
  • Open internal fuse
  • Magnetron failure
  • Faulty door interlock
  • Faulty control board
Feb 05, 2018 | GE Microwave Ovens
My under cabinet microwave is not working correctly.
The possible reasons are: 1) The high voltage transformer is broken, 2) The magnetron is broken.
For the 1st problem, no power can be applied to the turntable.
For the 2nd problem, the magnetron is broken with no microwave can be issued.
Jul 14, 2015 | GE Microwave Ovens
My kitchenaid microwave will not heat in microwave mode. In fact the turntable starts and stops and the display blinks intermittenly. In convection oven mode everything works fine - It heats, turntabl
The magnetron is the main part that gives out microwaves to heat the food. As the convection bit is working this points towards the microwave bits.
The magnetron has a main diode, fuse and transformer to run the microwave bit, any of these could be faulty. A word of warning though, there are extremely high voltages inside microwaves, even when unplugged in the main capacitor. Also to repair this section you will need to be a fully qualified engineer to even order parts for this.
Find a microwave technician who can repair for you
Nov 04, 2014 | Microwave Ovens
GE Microwave JVM1540LM2CS Doesn't Heat
The turntable and the magnetron are two separate items and one should not impact the other. Since the other items are working it is doubtful that the fuse is bad. Also you need to know that the proper way to work on a microwave requires the use of special equipment to check for microwave leakage, it is not recommended to service them yourself.
Jan 22, 2018 | Microwave Ovens
Everthing works but won't heat
If turntable works suspect inverter (power) or Magnetron itself is bad.
Oct 29, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
Goldstar under counter microwave spindle won't turn
use the common sense, and logically, fix it. God bless you
Microwave Runs, Heats, but turntable does not move This is a fairly easy one. First, make sure the turntable coupler under the glass dish is not broken. Second, on the control board, find the turntable relay and test for voltage. Some turntable motors are 24 volts DC, so make sure your testing the correct voltage. If no voltage from the control board, then replace the control board. Otherwise head towards the turntable motor.
On OTR models, you can get to the motor by un-screwing the bottom panel on the microwave. On countertop models, there will either be a knockout or screw on access panel. Check for voltage at the motor. If no voltage, check the wiring back towards the control. If voltage, then replace the turntable motor. The component list below also shows how to test a turntable motor.
Aug 02, 2012 | GE Microwave Ovens
Sharp Convection Microwave won't heat and turntable won't turn.
I typically find it is not door hinge issues but door switch issues, especially with sharp. You may heve a little movenent in the door hinge and that is allowing the door hook to move up and down on the plunger for a door switch that is probably a bit melted due to bad connections. If you check the door switches and look for any browning around the terminals where the wires push onto the switch you will probably find an overheated connectoion. Replace the bad switch and run better wires and better termninals to the new switch and it will probably be fine.
Oct 09, 2017 | Sharp R-930AK Convection/Microwave Oven
Prestige gs25 microwave won't heat
no the problem is more than your fuze! Micro waves have a high voltage output transformer inside that goes bad. You can fix it yourself but if your not good with electronics I would have someone else do the job!
Feb 07, 2012 | Microwave Ovens
Sharp Carousel Model R-1874 no heating or turning, display works
sorry without seeing the machine we can not help try whatever you want . that is how many of us learned what we know today
Nov 17, 2017 | Sharp R-1874 Convection/Microwave Oven
Open Questions:
GE microwave JEB1860 runs like normal but no heating i have a GE microwave JEB1860. it is little over 2 years old and has a problem. The microwave lights/turns/sounds/operates like normal except no heat. Absolutely no heat. Clues are that it started making sound like it was operating, when not being used with the door closed (doesn?t do it anymore.) Also few days ago a cup of milk was overheated and spilled in the oven. And before that many days ago I had a faint suspicion that the oven wasn?t heating fast enough. I used my digital multimeter to probe the following and they all check out right: . I checked both the primary and the door interlock switches and they are inf when door is open and 0 when closed . I didn?t check the monitor interlock since the fuse is still intact . I checked out the transformer. The primary input leads are 0.3-0.4 ohms (the shorted mutimeter probes itself reg 0.2). the filament leads are 0.2 ohms. Both set of leads are open wrt the ground. The high voltage lead registers 82 ohm to the ground (as is in the circuit diagram.) . the magnetron leads look pristine. They are short between themselves and open to the metal case. This also true with the multimeter leads switched. . the diode looked open (both directions) with the diode function on my multimeter but turned out to be not the case. My guess is that the 2v that my multimeter puts out is less than the cut-in voltage of the diode. In any case it is confirmed that this is not the problem because I replaced it and the heat isn?t there still. . the capacitor measures 959nF as is stated in the circuit diagram. Also the ohmmeter registers increasing voltage until it matches resistance of the 10Mohm internal discharge resister. . the temperature sensor is closed (0.2 ohm) so fine . humidity sensor tested fine as mentioned in the service pamphlet left inside the oven. (the inter-terminal resistances were not exactly as what was mentioned but seemed close enough) any thoughts on what might be wrong?
Feb 27, 2017 | General Electric JEB1860 1100 Watts...
General Electric JEB1860 1100 Watts Microwave Oven Logo
107 people viewed this question
Top General Microwave Ovens Experts
William Miller
William Miller
Steve Mason
john h
Are you a General Microwave Oven Expert? Answer questions, earn points and help others
