Question about Mitsubishi Mr. Slim MXZ30TN Air Conditioner
Leaking from bottom of unit - Mitsubishi Mr. Slim MXZ30TN Air Conditioner
  • Mitsubishi Master
  • 43,501 Answers
The drain is plugged, You willl need to remove the ocver and blow out the drain....
For any other info you need on Mitsubishi A/C check out this tip...
Mitsubishi Air Conditioner Troubleshooting and Repair
http://www.fixya.com/support/r5643983-mitsubishi_air_conditioner
heatman101
Posted on Aug 23, 2010
Garbage disposer leaking at bottom
Since you have checked all pipes and see no leaks next please check the area around the top and bottom of drain housing. If that's not leaking there is a gasket inside the disposal that could fail and cause water to leak into the motor area and then leak through the bottom of the unit. Generally in my experience replacing the whole unit is a time saver because access to that gasket is a pain and finding the right gasket can be timely. Depending on how old the unit is I would just replace it.
Jul 06, 2017 | Electrical Supplies
Why is my keurig 560 leaking water from the base
Most likely the water lines inside your unit are leaking. If you can take the bottom of B60 off and look inside the unit. Usually, the line that comes off the water pump is leaking at the T connector. If not leaking there look for other signs of leaking while the bottom is off. You can call Keurig 800 number to see if your unit is still under warrenty. Hope this helps.
May 28, 2014 | Keurig B60 Coffee Maker
How does the bottom plate come off a badger garbage disposal
Hi, the only plate that should be removed on the bottom is for wiring the power cord to the unit. If there is water leaking, specifically from the bottom of the unit, it's leaking through the enClosure assembly which is not serviceable. If the unit isn't that old it might just be leaking from the sink flange or mounting gasket at the top of the unit which at times can be difficult to detect. Or possibly the gaskets at the drain assembly for the unit. Hope this helps ;)
Feb 01, 2013 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Garbage Disposal Leaks from the bottom.
Hi GF,
Unless there is a leak at the sink gasket that makes it appear that the unit is leaking from the bottom, it's probably the main seal in the unit. It's generally not worth it to attempt disassembly and repair, especially if the unit is 10 years old or older.
Just remember to make sure the power is off before you attempt any
troubleshooting or replacement.
Be safe...
Aug 18, 2012 | GE Continuous Feed Garbage Disposal...
Leaks down through unit, drips out bottom, can't open unit.
Here is a tip that I wrote about how and where a garbage disposal will leak and what can be done to fix it.
Garbage Disposal Leak from bottom of motor
heatman101
Mar 20, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Water leaking out of bottom of unit, near reset
heatman101
p
Nov 11, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Condensation leaking out of unit
if it is the indoor unit leaking, make sure that all your drain lines are clear.... if you're talking about the outdoor unit leaking water in the heat cycle...that is normal.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/cody_17f08cf8e340c06c
May 16, 2009 | Intertherm P3RA-048K Air Conditioner
Mitsubishi Mr. Slim MXZ30TN Air Conditioner Logo
238 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
