Question about Frigidaire 24 in. FDB635RF Built-in Dishwasher
Model No.FDB4315LFB0. The middle spray arm detached during a wash cycle. I don't know where or how to reattach it. The only port I can see is on the top wall and is round. The port on the arm is oval shaped with a rubber gasket. Thanks
  • Frigidaire Master
  • 43,501 Answers
A part broke that holds it on...happens all the time...
that is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
heatman101
Posted on Aug 23, 2010
Lower spray arm dislodged during wash cycle
Hello Megan Quintas,
I have had the bottoms of the Frigidaire DISHWASHER rotted out AND their center-shaft NEVER LOST IT'S vertical alignment...
So my personal opinion...
You are good once you replace your defective spray arm..
Put your model+make+spray+arm
or better yet the ORIGINAL PART NUMBER to get three estimates...
Good luck, happy hunting!!
- Some example parts houses:
Sears (priciest... but improving)
appliancepartspros.com
partsselect.com
Water Filters Lawn Garden Appliance Parts
Search Over 2 1 Million Appliance Parts
PartSelect Appliance Parts and Repair Help
May 12, 2016 | Frigidaire Dishwashers
Frigidaire Model FDB780RCB0 I am getting water in the machine but it seems the arms are not turning what can I do to get that fixed?
The pump in the dishwasher is supposed to provide enough water pressure to turn the spray arms and make them rotate. The pump is faulty and not giving enough pressure or the arms are stuck.
Try spinning the arms, if they rotate smoothly, you will need to replace the pump.
Aug 03, 2008 | Frigidaire Dishwashers
Tip
How to troubleshoot your dishwasher
<span>Instructions</span> <ol> Dishwasher Does Not Run <li> <br /> Make sure the power is on, door is latched and controls are set properly.<br /> </li> <li> <br /> Look to see if the door switch, timer or selector switch are defective. Solve this problem by using a screwdriver to adjust the door latch's strike slightly.<br /> </li> <li> <br /> Confirm that the power cord is plugged into the electrical outlet under the sink (if applicable).<br /> </li> Dishwasher Won't Fill <li> <br /> Check your hot water supply stop valve under the sink. Turn it counter clockwise to ensure that it is open.<br /> </li> <li> <br /> Turn off the power and wait for your dishwasher to cool.<br /> </li> <li> <br /> Look inside for a float located at the base of the unit. Lift out the float device and clean around the tube. Rinse off the float and reattach it making sure it moves up and down freely.<br /> </li> Dishwasher Doesn't Drain <li>Remove the air gap cover (short chrome cylinder located at the back of your sink) and clean it using a wire.<br /> </li> <li> <br /> Check the drain hose for kinks and blockages.<br /> </li> <li> <br /> Shut off the power to your dishwasher and remove the strainer located at the base of the cabinet under the bottom spray arm. Scrub it clean then reattach it to the appliance.<br /> </li> Dishwasher Leaves Film on the Dishes <li> <br /> Add a rinse additive to your washing cycle and see if this solves the problem. In addition, do not pre-rinse your dishes prior to placing them into the dishwasher. Food particles allow the detergent and drying agents to work more effectively.<br /> </li> <li> <br /> Listen to the spray arms during a wash cycle. If they appear to be moving too slowly, use a wire to clean out the spray holes.<br /> </li> <li> <br /> Make sure the dishes haven't blocked the detergent dispenser or jammed the spray arms.<br /> </li> Dishwasher Leaks <li> <br /> Cut back on the amount of detergent used during the wash cycle. Sometimes this alone will solve your problem.<br /> </li> <li> <br /> Make sure the appliance is level by adjusting the front feet up or down.<br /> </li> <li><br />Take off the lower front panel and check the hoses for leaks.<br /></li></ol><span><br /><br /><a href="http://www.ehow.com/how_2120626_troubleshoot-dishwashers.html#ixzz18lyYrfk2"><br /></a></span>
on Dec 21, 2010 | Dishwashers
The upper spray arm came detached, how do I reattach it?
On my dishwasher, this arm attaches with a huge gray plastic screw. If it comes loose, you'll usually find the spray arm sitting in the bottom rack, but the screw falls down to the bottom of the tub.
The spray arm has a hole that goes all the way through its center. One of these holes is larger than the other, so the arm will only attach in one direction. Most of the spray holes on the arm face "up" when installed.
Slide out the upper rack, position the spray arm on its pivot, then insert the screw and turn clockwise to tighten it. The arm should spin freely.
If this arm isn't attached, none of the dishes will wash well (due to a loss of water pressure).
May 21, 2015 | Bosch SHU9915UC Dishwasher
The top washer is not spinning
Look at the top spray arm and see if it moves freely. Inspect the middle part of the spray arm. Sometimes a tall dishes can prevent the arm from moving. Put the spray arm at 12 o'clock position and have a cup right side up in the dishwasher. Run a cycle. During the cycle the cup should be filled to the top with in 20sec and the spray arm should have moved from its position. If not then change out the spray arm and Delivery tube.
Thanks, Please rate your experience
Dec 11, 2010 | KitchenAid Dishwashers
Upper spray arm came detached
take a good look ,there are two lugs ,from underneath you should see the male /female simply attach and twist .adrian,,,
Jul 10, 2010 | Frigidaire PLD4375RFC Dishwasher
The machine makes a knocking noise on the final rinse/spin cycle
It is a phenomenon called resonance.
Whenever the natural frequency of your sink unit is equal to the disturbing frequency (rpm of the spin cycle of the washing machine) the sink resonates.
It happens only at particular speed of spinning and vanishes with change in speed.
Nothing to worry about and is common. sort of sounds like the spray arm is loose. In your befuddled poking around, perhaps you pulled the lower spray arm out and ran it but, lo, it still makes the noise when washing. You don’t hear the noise during the drain cycle.
Thanks for contacting Fixya.com
Sep 29, 2009 | Maytag Neptune FAV6800AW Top Load Washer
The dish washer is taking ages to wash and it not clean ing dishes well
ok so If your dishwasher has worked fine in the past but, suddenly, your dishes aren't clean after the dishwasher completes all cycles:
1) Check your water heater's temperature dial to be sure it hasn't been changed recently.
2) Be sure dishes haven't prevented the detergent dispenser from opening properly during the wash cycles or kept the spray arms from turning, the lower arm from rising, or the spray from reaching the upper rack's dishes.
3) During the wash cycle, listen to the spray arm spinning inside. If it seems to be spinning poorly, clean out the spray holes in the spray arm(s) with a stiff piece of wire; wait for the machine to cool, and then remove the spray arm(s) by unscrewing the hub cap and lifting the arm(s) off
Regards Gizokieth
Sep 10, 2009 | Dishwashers
Leaks during wash and rince cycles
hi, Check your spray arm that nothing got stuck in its holes. make sure the spray arm is turning all the time when using the machine :
put the spray arm in 90 degree position, turn the unit on , open the door after few min check that the spray arm move...
make sure your seal of the door is clean and nothing prevent it to close evenly the door...
good luck 911servicetoday . com
I hope you find this Very Helpful and best regards!
Jun 25, 2009 | KitchenAid KUDR24SE Built-in Dishwasher
Dishes not getting clean
Yes I had the same problem and just fixed it for $7.00. Did not even had to take anything apart. This is what you will have to do. If this dosen't work then try what these experts are suggesting. Please follow these steps for optimal results. #1 Break off a plastic Tea spoon. #2 Put it in place of a LATCH to by pass so you can watch the operation of the dishwasher.(put down some towels for water spill) #3 start the dishwasher on normal cycle. #4 Pour in Gallon of White Vinegar($2.00) while the Dishwasher is being filled. #5 Let it run through its cycle. After the cycle is complete water will drain out and then actual cleaning cycle will start. Then #6 while the dishwasher is being filled again pour in 48 OZ or bigger bottle of CLR (Calciam Lime Rust) it is available at Meijer, walmart, Rite Aid, Home Depot Ace Menard's etc. for $5.00. sit by the dishwasher and listen for it. if you hear water draining pull and push the water plunger so it won't drain so you don't loose your CLR down the drain. since you have the spoon in the LATCH your dishwasher will always be on so BE CAREFUL when you stick your hand in it. And after the cycle is complete enjoy your NEW DISHWASHER.
Thanks
Kashif.A
Nov 06, 2006 | Jenn-Air JDB6510 Built-in Dishwasher
Frigidaire 24 in. FDB635RF Built-in Dishwasher Logo
218 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
