Question about Candy CDV262 Dryer
Drum not going around - Candy CDV262 Dryer
  • 176 Answers
Check the belt
Posted on Aug 23, 2010
REPLACING THE DRUM BELT
Belt should go around entire drum then around motor pulley (which is metal) and tensioner/safety pulley (which is the white pulley)
Apr 17, 2014 | Haier HLP140E Electric Portable Dryer
The drum have stopped going around. Is it worth repairing?
washing mechine wont spin or drum stopped going around .siemans xli1240
Aug 16, 2011 | Siemens WXLP1460 Front Load
How do I replace the dryer belt on a maytag dryer model #pye2300ayw. How do you connect to the pulley and get the belt around the drum?
lift the hood by pushing in clip on either side. remove two screw at top inside to remove front. unplug first. thats as far as we go there. remove belt out of dryer. take new belt and put on drum groove side down, get it uniform around drum. putting belt on pulley might be easier to do from behind for you. two screws to remove small access panel.take belt under pulley and over and around motor pulley. turn drum slowiy to make sure belt is not twisted. this belt can only go on a couple ways and one is obviously wrong. good luck.
Jan 30, 2010 | Maytag Dryers
The drum on my amanda dryer is making a noise as it go around.
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine, Unplug the dryer, remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the roller with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve you noise problem.
Good Luck,
I hope this helps
Oct 02, 2009 | Amana Dryers
The dryer will get hot but the drum will not go around
More than likely, the belt is broken. Otherwise, the drum motor is shot. (That's not very likely though).
Apr 22, 2009 | Whirlpool LGR5636L Gas Dryer
My washing machine drum will not go around
Certainly sounds like the motor, see if you can see if the drive belt is o/k, if it is then I would remove the motor and check the brushes for wear, if they appear to be o/k ,then I would think you have a controller problem.
Plz rate my solution.
Thamks.
Dec 17, 2008 | Washing Machines
Kenmore Dryer Drum Felt
i know have to ck myself on those sometimes the stitch closest to the edge of the seal goes toward center of drum..you will also have to stretch the seal around edge of drum 4 hands make it easier
Aug 01, 2008 | Dryers
Danby dcd5505 dryer
remove the front panel(s) and the top panel. the belt will go around the drum to a drive wheel at the bottom. the belt turns the drum. You will have to route the belt around the drum and go either in front of or behind the drum to get the belt installed correctly.
Jul 03, 2008 | Dryers
Candy CDV262 Dryer Logo
61 people viewed this question
Top Candy Dryers Experts
Gerry Harvey
Gerry Harvey
Billy Detlefsen
Are you a Candy Dryer Expert? Answer questions, earn points and help others
