Question about Dryers
Samsung Gas Dryer DvG328 Starts, runs 30-45 seconds and when purge cycle is over and it tries to ignite the dryer shuts off? What is it?
  • 176 Answers
Ceck the timer
Posted on Aug 23, 2010
Samsung gas dryer
Nothing to worry about . The problem you had was there was air in the line. Here's how it works. The igniter heats up then the gas valve opens. You had air coming out so it did not light initially . The air was followed by the gas supply but at that point the igniter was already cooling down. When you tried a second time the gas line was purged of all air hence normal operation.
happy drying.
wayne
May 06, 2014 | Dryers
I have a Kenmore Elite older model dryer that will fire the burner up when started, but when the burner shuts down and then tries to cycle on again, the glow igniter starts but no gas is released and the...
most likely its gonna be your coil kit, but it could also be ur gas valve,but the gas valve is not common. I would go with the silinoid coil kit first, its much cheaper too
Oct 11, 2012 | Maytag Atlantis MDE7400AY Electric Dryer
Gas Dryer Ignition Issues
did you try bypassing the cycling t-stat also?
Aug 25, 2012 | Samsung Dryers
I have a gas dryer, model MDG7657AWW that will not stay heated. Every time I put it on, the flame comes on for about 21 seconds & then shuts off. I replaced the igniter, hi limit thermostat, cycling t
On a gas dryer the heat normally only comes on for 30 seconds or until the drum temp reaches 160f at which time the flame is shut down by the cycling thermostat. The drum temp then starts to drop. When the drum temp reaches 105f then another blast of heat is issued for 30 more seconds.That is how they work. Put it all back together and trow a load in there.
Oct 28, 2011 | Dryers
Gas dryer initially heats then heating stops
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 15, 2010 | Whirlpool LGB6000KQ Gas Dryer
Gas Dryer. Heat for only one burn cycle.
Try vacuuming out the intake and exhaust of the burner to remove any lint or other debris. If no help, the main burner may need to be replaced.
Feb 03, 2010 | Dryers
Dryer's flame cycles but will not burn
Check the following to address this issue..
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Jun 01, 2009 | Dryers
Maytag 5806 Gas Dryer starts and suddenly stops.
You may have a problem with a thermal overload sensor. Since it runs and then shuts off, this sounds like the problem.
Dec 29, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MDG300aww Gas Dryer Heats On and Off
hI YES THE COILS IS WHAT YOU HAVE TO CHANGE thANKS FOR THE QUESTION tHE APPLIANCS DOC
Sep 12, 2008 | Dryers
After a few heating cycles the burner does not ignite
The problem you are describing is usually associated with a bad gas valve coil. The dryer runs normally until it gets hot, then starts making a strange clicking noise. After it cools down, the dryer runs normally again. The gas valve coils (there are two of them) usually run about $20 a piece. I recommend replacing both of them at the same time just to be sure. I hope this helps.
Apr 15, 2007 | Maytag MDG3600BW Gas Dryer
Dryers Logo
37 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
