Question about Hotpoint 24 in. FDW60 Free-standing Dishwasher
Dishwasher issues hotpoint dishwasher model HDA1200 used for a year and put into storage for a year. reinstalled this weekend. dishwasher was fussy about the door latch for a minute...door latch did not want to engage all the way...but went into its cycle. we stopped it and added a few dishes for a test run it started right up and ran about 8 minutes and shut itself down. it will not restart. the power supply is ok. no leakage about the door once latch engaged. what can we do?
  • 487 Answers
It can be the 10A fuse located in the back of the machine. but.... storage is kind of a problem with determining what is wrong with it.
Mouse can have chewed the wires, moisture can have rusted or corroded some components.
Check the internal fuse first and please check all wiring fo damage.
Posted on May 04, 2008
  • eric bosman
    eric bosman May 04, 2008
    It can also be one of the swiches as you said it was hard to close at first.
    Check next link for diagram and parts if needed
I have a Hotpoint BF71 dishwasher. I put it on but it hasn't worked, it filled with water which won't drain not will it even start now. I took out the filter but I couldn't find any blockages Help!
Reset the power at the breaker, but you may need a new pump and motor assembly. The same pump washes and drains on most Hotpoint models- a solenoid is used to open a drain flap and let the water out, but a bad pump will equal no wash or drain... Hotpoint Dishwasher Pump and Motor Assembly WD26X10013 Hotpoint Dishwasher Drain Solenoid Kit WD21X10268
Jul 11, 2016 | Hotpoint Dishwashers
Hello! I have an issue with my maytag dishwasher model number MDB6100AWQ. It is running, and it goes to drain, and slowly starts leaking onto my kitchen floor! We took it out about a year ago and...
check the door gasket. check that it is draining. disconnect drain line from under sink ad put into a bucket. most likely it isn't draining ad is overflowing.
Sep 22, 2011 | Maytag Dishwasher
Water from my disposal backs up into my hotpoint ($300-model) dishwasher. The dishwasher works fine otherwise. Is there a one way valve in the diswasher that is suppose to prevent reverse flow and/or is...
If it's what I think, it's a simple fix. Does your dishwasher drain run along the floor of the cabinet, then up to the disposal? (my guess is yes). There should be an "air gap" between the disposal and dishwasher, this means when it comes out of the disposal, it should go UP and be clipped to the highest point of the inside of your cabinet, then down. Think about it, sh*t flows downhill, but it can't get over a hump. Good luck
Dec 26, 2009 | Hotpoint 24 in. HDA3400G Built-in...
Dishwasher trips the fusebox.
You have a obvious short circuit.
Remove the lower panel and inspect the drain valve solenoid attached to the pump beside the motor.
These GE solenoids will stick and melt causing a short circuit.
If not that, open the front panel and inspect all wires for a break.
May 26, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Door on Hotpoint Diswasher BF1620 won't shut
To better assist you I need the Hotpoint Model n serial # look like this;
HDA3540NSA Hotpoint® Built-In Dishwasher HDA3500NWW Hotpoint® Built-In Dishwasher HDA3500NCC Hotpoint® Built-In Dishwasher HDA3500NBB Hotpoint® Built-In Dishwasher HLD4040NSA Hotpoint® Built-In Dishwasher HLD4000NWW Hotpoint® Built-In Dishwasher HLD4000NBB Hotpoint® Built-In Dishwasher HDA1100NWH Hotpoint® Built-In Dishwasher
Let me know wish one is yours.
Thank you
May 13, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Dishwasher running on a short cycle, not cleaning
It is hard to be specific without knowing the model number of your Hotpoint dishwasher and approximately how many years old it is...
If your dishwasher has a mechanical timer knob that you turn to get the dishwasher started, I would suspect that it is failing (not advancing after a certain point.)
Please report back with what you find, OK?
Apr 20, 2009 | Hotpoint Dishwashers
A noise could be created by something getting down into the motor-pump assembly piece of glass, piece of bone, wire tie anything really. If this is the case and you can remove it before it causes further damage problem solved. At ten years old the problem may be the motor and or pump one thing to consider before putting money into it is disheashers average 7-10 years these days. Good Luck.
Jun 02, 2008 | Hotpoint 24 in. HDA3400G Built-in...
30 hotpoint dishwasher
#1. If you have to put downward pressure on the float in order to fill, then float switch is not OK.
#2. It would seem as though your pump impeller is missing some, or all vanes. (Not pumping water out).
#3. It will become even more difficult to find parts as time goes on.
#4. 30 years...It has done it's job. It has paid for the trip, It's time to move on, What else can I say.
Jan 27, 2008 | Dishwashers
Hotpoint 24 in. FDW60 Free-standing Dishwasher Logo
171 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
