Question about Refrigerators
Hello help People, Water is dripping very slowly from the back of the fridge ceiling seemingly coming from the drain in the freezer? We cleaned out both the freezer and fridge and allowed for some collected ice in the freezer drain to melt and cleaned that out. We are also sure to keep the airflow unblocked. It still is leaking and am not sure what the cause Is? any ideas and help would be much appreciated. THANKS Bruce
  • bodoh May 08, 2008
    thanks bud55...I will try that.
    bodoh
    Habit-Forming:
  • 18 Answers
Maybe the drain is blocked further along - at the rear of the fridge. Sometimes there is a small bend or elbow in the drainage system that blocks.Check the outlet to see if water is actually coming out at all.
Posted on May 07, 2008
The fridge is dripping water from the top ceiling in the fridge and the fridge itself is making a terrible noise. We unplugged the fridge for four hours and now it is quite however there is ice covering...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 11, 2011 | Frigidaire 14.7 Cu. Ft. Top-Mount...
Water dripping insie the fridge
Water accumulating on the ceiling of the refrigerator is usually caused by a clogged drain in the freezer section beneath the evaporator. The clogged drain will cause water from the self defrost cycle to leak into the divider between the freezer and refrigerator. This water may then freeze and cause condensation build-up on the refrigerator ceiling. The solution to this problem begins with unclogging the drain. It may also be necessary to remove the entire freezer/refrigerator divider to thoroughly dry the insulation in the divider. Occasionally the insulation needs to be replaced to prevent a recurrence of the problem. This can be a big job – you may want to hire a qualified appliance repair technician.
Jul 28, 2010 | Frigidaire FRS26R4A Side by Side...
Whirlpool ET19DKXFW01 water dripping and heavy frost
Hi this sounds like a blockage in the defrost drain. Follow this link to my tips and tricks which will give you instructions on clearing the blockage. If you have any other questions please feel free to comment. Mike
http://www.fixya.com/support/r3557045-how_to_clear_a_blockage_in_the_defrost_d
Dec 10, 2009 | Refrigerators
Water leaking inside fridge.
If you remove the back panel of your freezer you will notice what looks like a drain - melted water will go through a drain hole that extends to your refrigerator inside a cup that slowly drains the water through a tube through the back of your refrigerator and down the drip pan. Your cup may appear fine, but maybe there is some obstruction somewhere causing the water not to drain fast enough - so what happens is that the cup will eventually overflow - try to see if you can remove this and pass a long wire down the drain tube at the back to dislodge anything blocking or partially blocking it - see if you can also clean your drain cup, eventually small derbris accumulate. At the back of your freezer panel look for any partial or complete obstruction of the drain hole and its surroundings, which might be iced up.
I myself have had this problem for months, my refrigerator would have water at the bottom accumulate and eventually under the crispers a river of water :)
Cleaning the cup and the drain tube at the back of the fridge and the drain and surroundings at the back of the freezer panel should fix this problem. Sounds like your drain at the freezer level is plugged up and water is backing up and leaking from elsewhere !
Sep 25, 2009 | Frigidaire PLHT219TC Top Freezer...
Freezer leaking into refrig compartment how do i
need to know the brand or call me at 813-270-4029
Aug 22, 2009 | Refrigerators
Water is on the shelfs in the fridge for some time now and hen yo
Remove the control box from the ceiling of the ref section, (4) 1/4 inch screws. unclip the wire connector and gently pull forward and remove from refrigerator. On the ceiling you will find the drain for the freezer about 1/2 an inch wide and about 3-4 inces long. Use some silicone caulk to go around the drain. Whats happening is when the unit defrosts and drains the water is running along the ceiling and dripping onto the shelves, the silicone around the drain will make it drip into the drain cup and drain the way it is suppose to. also check the back of the panel previously removed to see if there is any thing blocking the drain tube. Also use a turkey baster to put water down the drain in the back wall of the refrigerator to make sure that is clear, you should hear it drain in the drain pan under the unit. there was a bulliten from frigidaire a few years back, you may want to check with a dealer or servicer. You can order a new ferrule, which is the drain tube from the freezer to the ref. however it is easier just to put the bead of silicone around it.
Apr 08, 2009 | Frigidaire FRT21H8 Top Freezer...
Freezer drips water into frigde filling up ottom tray
Hello, If it is a top mount freezer then there is a drain that runs from the freezer to the drain pan that gets gummed up sometimes and if that happens then the water has no place to go but the fridge. Look all the way in the back of the fridge and you'll see a yellowish colored tube. You can just pop that out and take it to the sink and clean it out.. Hope this helps
Feb 18, 2009 | Kenmore 62232 / 62234 / 62239 Bottom...
STANDING WATER ON TOP SHELF
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
Jan 12, 2009 | Whirlpool ET1FTKXK Top Freezer...
Refrigerators Logo
71 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
