Question about Car Audio & Video
Hi, I installed a JVC KD-HDR20 HD Radio/CD Receiver using a GM Wire Harness on my 1990 Pontiac Bonneville LE and i'm unable to get the unit powered on. I followed the instructions and spliced my radio wires with the GM harness, color to color. I thought the unit was defective and replaced it, but i'm still unable to power up the unit. I noticed when I was removing the JVC replaced unit, it was warm. I replaced my factory delco radio because the radio & clock (no display) stopped working but the tape deck continued to work. This happened right after I had my headliner fixed and i'm not sure if this is related in anyway. I figured the radio has broken and replaced it with the JVC radio. Any ideas on how to fix this problem? Any help would be appreciated, thanks.
  • 2 more comments
  • ghosters Aug 23, 2010
    Crutchfield Receiver Wire Harness
    Item#: 120701858
    GM Wire Harness receiver, 1985-up
    Hi Blue,
    I haven't tested the wiring for proper voltage yet.
    Since the previous radio's tape deck worked, could we rule out a fuse issue?
    Also, are there any wires on the hood of my car that the fabricators may have messed with that could have caused this problem?
    Thanks
    Thanks. I re-checked the fuse box and noticed a second radio fuse that i missed, turns out it was blown out. Once replaced the head unit turns on, thanks.
    thanks, it was a blow fuse.
  • 15,935 Answers
What harness did you use?
Have you tested the wiring for proper voltage?
THanks!!
Posted on Aug 23, 2010
    Top Expert:
  • Car Audio & ... Master
  • 76,164 Answers
You need to check the wiring at the radio, u should have 2 12 volt sources with the key turned to on or accessory and one 12 volt source with the key turned off, if not u need to check for blown fuses. Below is the GM wire colors for 12 volts and ground at the radio connector, use a test light to verify or a DC voltmeter
Radio Constant 12V+ Wire: Orange
Radio Switched 12V+ Wire: Yellow
Radio Ground Wire: Black
Installing a jvc cd player into a 99 crown vic
the best thing to do is not to cut factory wires and buy a wire harness from walmart or miejer and the wires will be color coted match up and tape them up them plug the two harness's together that is the best way to wire up a aftermarket radio
Sep 24, 2012 | JVC USB/CD Receiver with Dual AUX Input...
How to use jvc kd-hdr20 car stereo. I need to know how to fix balance,bass,bluetooth,ect.
To pair a bluetooth device with the radio, turn on the Bluetooth function of the device. Then press the SRC (source) button on the receiver. Select BT Audio or BT Phone, depending on the device you want to pair with the radio. Use the up/down arrows to select New Device and press the down arrow. Select Open and then press the down arrow. Then enter the PIN by using the left/right arrows to select a digit and turning the volume knob until the correct digit is entered. (For some devices, you need to enter a specific PIN. Consult that device's manual.) Press the down arrow to set the PIN. Enter the PIN in the device you are pairing to the receiver (if it doesn't have a required PIN). Wait for the message "Connected" to appear.
To use the device in the future, press SRC and choose the appropriate Bluetooth type. Then use the right/left arrows to select the registered device. Press the down arrow and then use the right/left arrows to select Connect and press the down arrow. (See the manual, link below, for setting the autoconnect or autoanswer.)
To adjust the sound system balance, press and hold Menu to open the menu and then turn the volume knob to Audio. Press the center of the Volume knob. Then navigate to balance and adjust the unit as needed.
The manual for the KD-HDR20 is available from JVC on the product support page: http://support.jvc.com/consumer/product.jsp?archive=true&pathId=54&modelId=MODL028465 . The direct link to the instruction manual is http://resources.jvc.com/Resources/00/01/14/LVT1960-001A.pdf .
I hope this helps.
Oct 13, 2011 | Car Audio & Video
Installing KD-HDR20 and I get a red power light but nothing works
I have had the same issue and I tried until I found the problem.
1) I had no power to my remote wire.
(The wire that only allows the radio to work when the care ignition is on.)
2) The radio has a fuse or maybe two.
But the auto mobile may have blown its fuse.
In my case it was the remote fuse.
3) I have had a bad ground and only need to find a good place.
4) I have even found insufficient power to my radio because too many devices were also using that power.
5) Heck I have even forgot to start the care or at least turn the ignition.
6) My battery was so dead it couldnt even power my radio.
Mar 16, 2010 | JVC KD-HDR20 Car CD/ MP3 Player
I need help installing a new radio.
Hi my names Josh and yes you will need a harness if you havent allready purchased one. Plugging your new harness in is very easy and from there you just follow the colors from the new harness to the colors on the harness wires coming out of the new car stereo reciver Red with red yellow with yellow black with black. white with white gray with gray make sure you pay attention to the white and gray wires they are marked one with stirp and one without one you want to put white with stirp toegether with the white with stip on your harness like wise with your green and your purple
Mar 02, 2010 | Buck Saturn Sc1 Sc2 1996 1997 Radio...
KD-HDR20 cannot set equalizer from following directions
I am having the same problem; I emailed jvc tech support and am waiting for a response.
Oct 03, 2009 | JVC KD-HDR20 Car CD/ MP3 Player
Installing a cd player in a 1992 honda accord
The harness looks like what is depicted on this link: http://cgi.ebay.com/JVC--16-PIN-WIRE-HARNESS-FOR-CD-PLAYER-BLACK-BRAND-NEW_W0QQitemZ370214069143QQcmdZViewItemQQimsxZ20090612?IMSfp=TL090612198008r8862
This connector fits the following JVC Car Radio/CD/MP3 Players with 16 pin connection.
All wires are labeled.
Hope this helps....................sodeep
Jul 26, 2009 | JVC KD-G220 CD Player
How to wire car speaker to JVC CD Receiver.
Hello anstrayer,
On your JVC wiring harness the speaker wire colors are:
Left front (+) - White
Left front (-) - White/Black
Right front (+) - Gray
Right front (-) - Gray/Black
Left rear (+) - Green
Left rear (-) - Green/Black
Right rear (+) - Purple
Right rear (-) - Purple/Black
You can download a the manual from Crutchfield. A complete wiring diagram with color codes is on page 41.
Hope this helps.
May 31, 2009 | JVC Car Audio & Video
DOESN'T WORK AFTER INSTALLING A NEW CAR BATTERY
did you check the fuse on the back of the radio. it should be a small maxi fuse that might be rated any where from 5 to 20 amps. most of the time it might be helpful to unplug the radio harness and re plug it after 1 minute.
May 27, 2008 | JVC Arsenal KD-AR3000 CD Player
Trouble playing JVC KD-S580
i have the same problem in a 2001 mercury cougar. i got power all the way to the back of the radio from the ignition (red) and constant (yellow) wires and the ground wire is good. Think the head unit might be screwed the fuses are all fine. not sure though
Nov 11, 2006 | JVC KD-S580 CD Player
Car Audio & Video Logo
105 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
