Question about Sharp Microwave Ovens
I have a Sharp R330J 1100W Microwave. The lamp is no longer working and I am wondering how I am to fix it? Thank-you
3 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave
This is a problem with the control board assembly, which we repair nationwide for $32.50. Feel free to e-mail me at _ for more information or visit _ for full details.
Posted on Sep 15, 2006
SOURCE: regarding microwave
Dear Sir/Mdn
My microwave is running but not heating food,model R-248J(S),S/No: 070737958,I hopw i will get better solution ,thank You.
Aung Aung
HP: 65-90468925
Posted on Apr 12, 2009
Samsung microwave malfunction
I too have this problem with my KitchenAid KHHS179LSS-5 model. Based on the owner's manual I located behind the grill which pulled off, the F7 Error code indicates that power to the magnetron was interrupted. You will want to make the following checks: 1. Unplug microwave oven or disconnect power. 2. After 40 seconds, check to see whether this solves the problem. 3. Unplug microwave oven or disconnect power. 4. Check resistance of the magnetron thermostat. 5. Check the magnetron. 6. Check wiring to the 1100W inverter and control system. See "Checking Inverters." 7. Plug in microwave oven or reconnect power. 8. Check operation of all interlock switches. Check door, hinge and cavity front alignment. Adjust as needed. 9. Unplug microwave oven or disconnect power. 10. If switches operate correctly, replace 1100W inverter. 11. If problem persists, replace electronic control. 12. Plug in microwave oven or reconnect power.
After removing the control display, there is a virtual zoo of connectors. So unless you repair microwaves on a regular basis, it may be difficult to ascertain which ones go to the magnetron thermostat. I will probably resport to shelling out the dough to get someone to fix it. Sorry I couldn't be more helpful.
Jun 27, 2013 | Microwave Ovens
The digital display no longer works on my sharp half pint microwave r120d. How can I fix this? thanks in advance.
On this model, it's usually not economical to repair, but in most cases it can be repaired for $39.95. Details are here.
Aug 16, 2011 | Sharp R-120D Microwave Oven
The door to my Sharp microwave over the counter will not close
You can fix this. The same thing happened to my Sharp Microwave.
I got my parts at www.repairclinic.com . On my partidular model (which is probably onder than yours) there is a right hand latch and a left hand latch. Make sure of the one you need. Heck - buy them both.
The door was a little trickey for me to get apart - there was a plastic strip hiding the screws.
While I had it apart, I replaced the door safety interlock switches too ... you may want to consider replacing yours as well.
Also, as long as you have it all apart, you might want to change the lamp as well.
If you need more help with this ... tack a note on to this post.
I hope I have helped you ...
Thanks for visiting fixya.com
a
Oct 25, 2009 | Microwave Ovens
The display no longer works on my Model R303CW Sharp Microwave. Is there a part that will fix the display?? Everything else works fine.
Nope , could be dry joints or corroded pcb or defective display driver or supply ? Only can be told once opened and inspected.
May 13, 2009 | Sharp R-303CW Convection / Microwave Oven
Regarding microwave
Sanjay
This is due to the magnatron failing (this is the part of oven that cooks the food!) This is the most likely cause of y isssour oven not heating the food!
Magnatron needs replaced for oven to work again!
Please rate this free soultion!
Jan 18, 2009 | Sharp R-308J Microwave Oven
Sharp microwave model R-395F(S) bought in NZ. 1100W about 30litre. Problem from new, display weak but main problem as some buttons work some don't work and you have to push stop a few times before it...
Hi Lindsay
Sound like you need a new key pad if you have some handy man around you you can replace it, It require dismantle the front key pad remove electronic part and clean then reinstall properly the key pad itself about $40.00 Aus
Let me know if you need part number for that key pad
Cheers
Dec 02, 2008 | Microwave Ovens
R-9h81 sharp microwave oven
Replacement keypads for the R-9H-series of microwave ovens are no longer available.
So for as long as you can get by with the oven like it is, go ahead, but the only solution id to replace it with a new model.
You can contact Sharp at 1-800-BE-SHARP (1-800-237-4277) or visit them online for current equivalent models.
Sorry I can't bring better news.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 08, 2008 | KitchenAid KCMS1555RSS Stainless Steel...
Microwave
I wiggled the ribbon cable between the control board and the intermediate circut board. The LCD came back for an instant. I am sure it is this ribbon cable. It looks like it is held on with adhesive. How can it be impossible to repair if people are offering to do it less than 40.00 dollars to fix it? Someone must be selling a replacement ribbon cable that will work.
Mar 20, 2006 | Sharp R-1501 Microwave Oven
Microwave Ovens Logo
69 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
