Question about Braun 360° Complete 8985 Electric Shaver
My Braun shaver 8585 has died. Foil, cable, box, Clean and charge unit as new. Which Braun shaver replaces Braun 8585 and can utilise good pieces?
  • Anonymous Mar 16, 2014
    Hello. My Braun shaver 8585 model charges but the sensor claims the shaver is clean when it is not and so I can not run the cleaning cycle.
  • Braun Master
  • 1,600 Answers
If I understand correctly, the shaver is dead but all other components are in good condition. If this is the case, you should consider ordering a replacement lower unit. See shaveroutlet.com link below
http://shaveroutlet.com/braun-8585-activator-lower-unit-p-364.html
Newer models made by Braun do not use all the same parts as your shaver so this would be a good way to go
Posted on Aug 23, 2010
Braun activator 8585 change the foil
braun series 5 combi 51S outer foil and cutter replacement pack (Formerly 8000 360 Complete Or Activator) for men electric shaver braun 8585 replacement parts.
Jul 30, 2013 | Braun 8585 Electric Shaver
Shaver is getting very loud
Most likely, the swivel frame that the foil snaps onto has a broken piece(s) of plastic inside making a buzzing sound. If this is the case, you will need to replace the drive unit. You will find this part for model 8585 at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-8000-series-activator-motor-drive-unit-p-36.html
Disassembly video can also be found at shaveroutlet.com. See link below
http://www.shaveroutlet.com/braun_syncro_shaver_disassembly
Jan 07, 2011 | Braun 8585 Electric Shaver
Braun 8585 shaver, charges fine, cleaning cycle acting strange where it thinks the razor is clean, but it is not. When new it cleaned at some level every time put in the cleaning base. Now it very...
The problem is the base, not the shaver. Most likely, the circuit board inside the base has gotten wet and is damaged. If this is the case, it will need to be replaced. You will find a replacement at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-8000-series-360-complete-clean-charge-base-p-116.html
Oct 09, 2010 | Braun 8585 Electric Shaver
The Charging cord's head that fits into the Shaver is broken. How get I get a replacement?
I have several new power charging cords for this model. If you want one Please let me know and will give you a good price.
Nov 13, 2009 | Braun 8585 Electric Shaver
Battery replacement for Braun 8585
I'm pretty sure that the batteries are part of a sealed unit with the PCB on this model, and after checking the Service Diagram I'm even more convinced.
I would suggest fully charging and discharging (leaving it running without the foil and cutter on) a number of times to see if you can improve the performance, as there may be a memory effect on the battey. The model is only 5 years old so your batteries should have a little more life.
It is a mains/rechargeable shaver though, so you "should" still be able to use it with the lead plugged directly into the shaver. So the shaver may not be a dead loss! :)
Apr 11, 2009 | Braun 8585 Electric Shaver
Need a new Clean and Charge Base
yes, you can find it online , also you can find it on ebay if you search for braun 8585 .
Nov 25, 2008 | Braun 8585 Electric Shaver
Braun 8585 charger cleaner - not cleaning
you can try cleaning it with alchol and see if that helps it to become unplugged and able to clean your shaver again. It may also be some contacts that is on base where it contacts the shaver. If it still does not work, you will need to replace it . Look on ebay for one to replace with.
Nov 10, 2008 | Braun 8585 Electric Shaver
Braun 8585 series
I found that the hole that the blade slots into had become worn and the blade was wobbling about too much under the foil. To solve it I wrap a small piece of masking tape around the metal shaft that slots into the hole and then push the blade back firmly into the slot. This seems to result in the blade pushing more firmly against the underside of the foil and giving a shave like new again.
Oct 10, 2008 | Braun 8585 Electric Shaver
Braun 360° Complete 8985 Electric Shaver Logo
437 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Joseph Hoffmann
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
