Question about Whirlpool GHW9200L Front Load Washer
Smelly washing after cycle - Whirlpool GHW9200L Front Load Washer
  • 15,935 Answers
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Oct 01, 2010
Smelly discharge water
smelly front loader???all front loader tend to leave a little water left over in the inner tub after every load,always leave washer door a crack open to reduce smell/mold on seal,to get rid of smell simply run a normal cycle,no clothes,with a dose of bleach or better yet AFFRESH,made by whirlpool,a bleach tablet with fragerance,sanitze and smells good!!answer,,,AFFRESH
Mar 27, 2012 | Kenmore Elite 45986 Front Load Washer
Water in washing machine drum
I shall give you some tips for cleaning the washing machine and clearing the smell
check this link:
http://www.espares.co.uk/advice/washing-machines/a/7/1182/smelly-washing-machine.html
Oct 19, 2011 | Washing Machines
Smells like old smelly socks
this might be coming from the rubber door seal clean it all the way round make sure holes at bottom are not blocked and the rubber door seal is all clean. also clean the draw so there is no power left in there and it is all clean. also a good thing to do is run it though a cleaning cycle with normal detergent at max temperature that the machine can do. hope this helps.
May 20, 2010 | Creda IWD12 Front Load Washer / Dryer
Whirlpool frontend washer smelly cloths...need
I have this problem with my Siemens machine, it is due to mainly running low temp washes and bateria building up in the hoses etc. (more prevalent if the machine is connected directly to the sink and not on a stand pipe). I run a 90 degree cycle every 4 weeks with the machine empty except for two capfuls of baby sterilisng fluid (approx half a mug) I buy stores own as it is cheaper than miltons. The first time I did mine I ran the cycle twice to be sure it was cleared out. My machine is six years old and the first smelly signs were when it was about a year old, I run the maintenance wash religiously ever 4 weeks and run a machine descaler such as oust thru every 4-6 months. Hope this helps. Roni. (ps don't be tempted to use bleach as it foams up and can cause more problems!!)
May 11, 2010 | LG WM2688HWM TROMM SteamWasher
Smelly front loader washing machine. Clothes come out smelly too. How did I fix the problem???
You may have to do this 2 times and you will never find this in any manual. Use 1/4 cup "Powdered" Dishwashing soap and 1 cup of bleach in an empty tub cycle. Run a load of older dark clothes or non flammable rags FIRST after doing this the first time. If they come out with streaks run the cycle of 1/4 cup Powdered dishwashing soap and 1 cup bleach again. Same routine after 2nd cleaning cycle... dark clothes check for anything out of the ordinary. You should not have to do it a 3rd time unless your machine is really gunked up. Hopefully your using HE type soaps in your front loader. Non HE laundry soaps will cause the smelly machine also.
Thanks for using FixYa.
Kelly
Mar 29, 2010 | Washing Machines
Smelly washer!!!!!!
Check the drain hose for gunk then:
Fill up the tub half way with water (small load) put a cup of vinegar a 1/4 cup of baking soda let it foam up then run the washer through a regular cycle empty. If this does not work: you will need to use a commercial mold removing product.
Mar 17, 2010 | Washing Machines
Smelly clothes after washing. We have one of the models that was recalled for the same problem. Maytag Neptune - MAH6500AWW
Jan 12, 2010 | Maytag Neptune MAH6500A Front Load Washer
My washing machine is smelly!! I was told that I
You don't neeed to remove anything Just set it to large load hot water and add 2 cups of bleach. Run it through 2 cycles. If the smell is still not gone completely repeat.
Never had this fail.
Hope this helps
Please leave feedback
Nov 29, 2009 | Cars & Trucks
Bad smell inside drum and when draining also makes laundry smell
Recommend running it through empty (and without soap) on a long, hot wash cycle a couple of times.
Modern cool cycles don't always wash away all the detergent, and the machine fills up with smelly grey sludge after a while.
A.
Aug 01, 2009 | LG Washing Machines
Smelly washer
Try Putting Lemons in the washer once you done the washing gets rid of the smelly oder
Jul 19, 2008 | Whirlpool Washing Machines
Whirlpool GHW9200L Front Load Washer Logo
47 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
