Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Whirlpool lut..II you said....check the drive coupling between the motor and gearbox,does it make a clicking sound does it spin or just pump the water out only. But how do I get there. I can not find my owners manual...uggg Thanks Janine
  • Anonymous May 07, 2008
    Clicking sound during spin cycle
  • 868 Answers
The manual will never have this information.You have a machine that wont spin but will drain ,correct?The motor coupler is the most common repair if thats the case.Usually you can tell by pulling out the washer and looking at the floor under neath for fine black/white plastic shavings,almost like a powder that would be sitting right there on your floor.If you see this ,let me know.I'll say this for sure,If you are attempting to replace this your self ,I will guide you the best and fastest way through it,cause its not going to be easy.
Posted on May 21, 2008
Washer quit the spin cycle
If the machine will not wash or spin, but will still pump the water out, you probably have a broken coupling which connects the motor to the gearbox. This is a simple job for an experienced tech, and should not be expensive...good luck....Nomess
May 23, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Whrilpool modle #lsq9544kq0 washer works in
Humming could mean a stalled motor. These machines also have a coupling between motor and gearbox which can fail. However, the pump is attached to the motor, so if it's not pumping it probably means the motor isn't spinning. Check motor and/or gearbox.....Nomess
Apr 18, 2010 | Whirlpool LSQ9544K Top Load Washer
My washer fills and drains with water, but is making a buzzing noise and nothing is "spinning."
sounds like your coupling is faulty. it is a common fault with this unit. the coupling goes between the motor and gearbox, it is designed to break to protect motor or gearbox.if u r confident reply back and i will guide u thru changing coupling.
Apr 17, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool model SM 8525079 fills with water but will not agitate or spin
If you have motor sounds after water fill,but no agitation or spin it could be a broken direct drive coupling. If it will not pump out water,there could be something stuck in the drain pump.
Jan 17, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer wont work
If the motor is running but no agitation or spin is happening, then most likely the coupling between motor and gearbox has gone- look for black sooty deposits under your washer as proof. There may also be one or more pieces of white plastic. This coupling usually goes if the washer is overloaded regularly.
Dec 29, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool washer fills up; makes LOUD whine/click metal noise
sounds as if you have a bad mootor coupling, part number 285753, easy enough part to change, easier to search on the you tube site for whirlpool motor coupling repair, fo rthe video, then try to explain procedure, but definalty easy enough repair for home owner
Nov 19, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool untimate care II won't spin/agitate.......
Welcome gonecamping
Whirlpool/Kenmore- Weak Clutch Spring
If the clutch is slipping the spring is weak and must be replaced.
In the Whirlpool it could be this.
Or a door latch
Oct 24, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool ultimate care II motor overheating
this type of whirlpool washer has the water pump on the other end of the motor. if you are sure that you installed the drive coupling correctly then it is most likely something in the pump.
you can unhook the pump and run the washer and see if it works OK.
If it does then go get a new pump
May 18, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Agitator
Mar 21, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care HD Plus Model #LSR8233EQ0 won't agitate or spin
It sounds like the coupling between the motor and gearbox has worn out. It should cost around $15 plus shipping and handling.
Aug 04, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
57 people viewed this question
Dan Webster
Dan Webster
Sal De
