Question about Nikon D80 Digital Camera with 18-135mm Lens
Withnew battery, indicator shows low battery and shutter willnot activate until the on/off selector is cycled several times. D80 with18-200mm lens
  • wdwright0709 Aug 23, 2010
    Both batteries are original Nikon and new
  • 3,083 Answers
It's possible the battery contacts are slightly dirty or oxidized. Clean them good with a qtip and isopropyl alcohol, or a pencil eraser, then see what happens. Here is a web blog about cameras with power problems, and perhaps some info about the various switches on the unit will help:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
Also, some batteries require recycling to fully charge, refer to the information at the bottom of this web page:
http://www.ebuybatteries.com/product/models/2_Sanyo-02491-0066-00-battery_Sanyo+Xacti+VPC-T700.htm
Good luck, and hope this helps.
Posted on Aug 23, 2010
  • 4,924 Answers
Try a different battery model ...cause for these kinda cameras you need to use the best on the market to assure that they have the amperage necessary to be able to power them in the proper way ...and there s the possibility that the batteries are just weak from factory ...it happens..
Also the fact that you have to power it up a few times it makes me think that a contact might be under issue ..and it will not be a bad idea to clean the battery contacts inside ...with some acid solution ..like vinegar ...(be careful do not make it a bath ..)this will get rid of any oxidization ...and like I said ..if they are rechargeable batteries..they might not have been well formatted..or are defective ...just go to the store and try a new pair just to see ..cause if it says low battery ..than the reason is the power only .. If we are talking about normal ones..just get some of a better quality ..
Don't know what buttons on back of camera are for.
Besides the auto-flash mode, you can select fill flash, flash off, self-timer, and nighttime-view with or without flash.
Press the MODE-SELECTOR BUTTON until the desired indicator appears on the LCD PANEL.
c3015.gif Fill flash and flash off modes remain selected after you take the picture. To cancel the selection, press the mode-selection button or close and reopen the lens cover/flash to return to the auto-flash mode.
Fill flash
c3014.gif When bright light indoors or outdoors comes from behind the subject (backlighting), dark shadows (especially on faces) may occur. Use fill flash to lighten these shadows.
  1. Open the LENS COVER/FLASH to raise the flash and to turn the camera ON.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the FILL-FLASH INDICATOR appears on the LCD PANEL.
  3. Frame your subject within the VIEWFINDER EYEPIECE.
  4. Partially depress the SHUTTER BUTTON. When the FLASH/CAMERA-READY LAMP turns off and the fill-flash indicator on the LCD panel stops blinking, fully depress the shutter button to take the picture.
Flash off
c3013.gif When you do not want to use the flash, especially indoors where flash is prohibited, such as in theaters and museums, or when you want to take twilight scenes or distant subjects that are beyond the flash range, or capture the ambiance of existing light, use the flash-off feature. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed in these situations will most likely be slow.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the FLASH-OFF INDICATOR appears on the LCD PANEL.
  4. Press the SHUTTER BUTTON to take the picture.
Self-timer with auto flash
c3016.gif Use this feature to include yourself in pictures.
  1. Use the TRIPOD SOCKET to attach the camera to a tripod or place it on another firm support.
  2. Open the LENS COVER/FLASH to raise the flash and to turn the camera ON.
  3. Press the MODE-SELECTOR BUTTON repeatedly until the SELF-TIMER INDICATOR appears on the LCD PANEL.
  4. Frame your subject within the VIEWFINDER EYEPIECE.
  5. Press the SHUTTER BUTTON. The SELF-TIMER LAMP will glow and then blink during the last three seconds of countdown.
    • To cancel the self-timer selection before the shutter releases, close the flash.
    • The self-timer automatically turns off after the shutter releases.
Night-view with flash
c3012.gif In this mode, the camera balances the flash and existing light exposure so you can take beautiful pictures of people at sunset or at night. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed at night will most likely be slow.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the NIGHTTIME-VIEW INDICATOR with flash appears on the LCD PANEL.
  3. Frame your picture in the VIEWFINDER EYEPIECE.
  4. Press and hold the SHUTTER BUTTON for 12 seconds without lifting your finger. Note: If you remove your finger from the shutter button before 12 seconds, the shutter will time out immediately.
  5. After 12 seconds, release the shutter button to take the picture.
Night-view without flas
c3011.gif In this mode, you can capture the natural existing light of city-night scenes or fireworks at night. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed at night will most likely be slow.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the NIGHTTIME-VIEW INDICATOR without flash appears on the LCD PANEL.
Jun 17, 2010 | Kodak Advantix C400AF APS Point and Shoot...
Shutter release not responding
Hi tmclaughlin0, In the camera is in AF-S mode, the camera will not shoot until it acquires focus. Look on page 29 of the D80 manual.
May 14, 2010 | Nikon D80 Digital Camera with 18-135mm...
D80 "battery drained' and "F"sign when pressing release button
Pls make sure of the following:
- You are using original Nikon batteries (generic batteries gave a similar problem to me)
- The aperture ring of your camera is correctly placed
Nov 16, 2009 | Nikon D80 Digital Camera with 18-135mm...
No shutter release
It turns out that supporting the camera while taking a shot can impart a slight twist on the seated lens. This twist is just enough to cause the camera to think that there is no lens installed .. hence the error message. Solution (provided my Henry's Camera experts) was to reseat the lens by reversing the twist. It has since happenned twice and each time recovery was effective .... Keith
May 25, 2009 | Nikon D80 Digital Camera with 18-135mm...
Will not autofocus...
Page 36 of the D80 manual—The r09 displays how many images can be stored in the buffer. Page 132 of the manual states the F- - is an indication that a nonCPU lens is being used or the lens is not attached. If the lens is a CPU lens then remove it then replace it turning until you hear the click as it seats.
Apr 11, 2009 | Nikon D80 Digital Camera with 18-200mm...
Shutter won't release
If the lighting is low and shutter speed is set for a long period of time its the function of the camera taking the picture. If it is a malfunction of the shutter take it in for cleaning you might have foriegn material stuck in your shutter mechanism
Jan 20, 2009 | Nikon D80 Digital Camera with 18-135mm...
D80 shutter issue
contactjoni,
Your shutter will stick if it gets dirty or dust gets in the camera, a reputable camera shop can inspect the shutter, the sensor for dust & dirt and can clean it for you. If the battery is low while shooting the shutter can also stick on longer exposures.
randy320sgi
Jun 28, 2008 | Nikon D80 Digital Camera with 18-200mm...
Malfunction D80 showing erratic "Lo " message,
if you're in a P mode it means it in low light condition. whne you see the Letters "LO" and take a shot it woudl take time before the camerea releases the shutter because it's automatically exposing the image and exposure may take longer depending on the lighting condition.
Jun 01, 2008 | Nikon D80 Digital Camera with 18-135mm...
Nikon D80 Digital Camera with 18-135mm Lens Logo
20 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
