Question about Lenmar 1000W Power Inverter
The power is on but the battery is not charging.
Maybe it is old
Posted on Aug 23, 2010
The battery wont charge for my lt2802u
POWER SUPPLY & BATTERY PROBLEM
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods. When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Apr 16, 2013 | Gateway Lt2802u Laptop/notebook
Tip
How to Help HP Pavilion Laptop Power Battery Using Problems
Hp laptop users might experience that the battery is overheated, or the laptop battery suddenly stop charging. Sometimes, the battery health "good" but the battery does not hold a charge, etc. So, how to fix these problems?
First of all, you know that the most common type of AC power adapter involves a small box, with one wire to go to the computer and another wire to go to the wall. There is usually an LED light on it, to tell you that it is on. When your laptop doesn't work, you need to troubleshoot the AC power supply, system board and the battery are functioning correctly. The battery is an important part. It supplys power to the input-side of the voltage regulators, just like the power from the AC adapter. Additionally, there is a charging circuit, which uses the power from the AC adapter prior to the voltage regulators, to charge the battery. (By the way, this is why the AC adapter voltage is always rated higher than the battery's rated volatge-- you need higher voltage for charging.)
Verify the Hp laptop battery like this:
1. Insert the battery into the battery compartment on the bottom of the notebook PC.
2. Connect the AC power supply and allow the battery to charge for 15 to 30 minutes.
NOTE: The power LED, located near the power icon (displayed as a lightening bolt on most PCs) , should glow while the battery is charging.
3. Unplug the AC power adapter cord from the notebook PC.
4. Press and release the Power button to start the computer using only the battery as the power source.
If the PC does not power on, then the battery needs to be replaced. Contact HP service and support for further assistance.
If the notebook PC does power on, the battery is functioning, however you should run the HP Battery Check utility to evaluate the battery's health.
NOTE: If you have purchased a second battery for your notebook PC or you have access to an identical battery, you can also check the battery by inserting the second battery into the PC and performing the Troubleshoot the battery steps again.
Your new HP laptop battery comes in a discharged condition and must be charged before use (refer to your computer manual for charging instructions). Upon initial use (or after a prolonged storage period) the battery may require two to three charge/discharge cycles before achieving maximum capacity. When charging HP laptop battery replacement for the first time your computer may indicate that charging is complete after just 10 or 15 minutes. This is a normal phenomenon with rechargeable batteries. Simply remove the battery from the computer and repeat the charging procedure.
It is important to condition (fully discharge and then fully charge) HP replacement laptop battery every two to three weeks. Failure to do so may significantly shorten the battery's life (this does not apply to Li-ion batteries, which do not require conditioning). To discharge, simply run your device under the battery's power until it shuts down or until you get a low battery warning. Then recharge the battery as instructed in your user's manual. If replacement HP laptop battery will not be in use for a month or longer, it is recommended that it be removed from the device and stored in a cool, dry, clean place. It is normal for HP laptop replacement battery to become warm during charging and discharging.
How to solve the batery can't be charged?
Possible Reasons:
a.The battery has no voltage.
b.There is problem with charger, as it has no output electric current.
c.Low charging efficiency due to external cause.
Best Solutions:
a.Test whether the charger has voltage and output electric current or not.
b.Check if the charger is well contacted with battery.
c.Activate the battery with voltage and current 1.5 time higher then the highest ones of battery. (Use this method only when the battery can't be charged.)
Original: http://www.papatek.com/Knowledge/Battery-knowledge/Knowledge_194.html
on Sep 02, 2010 | Computers & Internet
Batter wont stay charge
Most laptop batteries have a life expectancy of two years or 400 to 450 charge and discharge cycles. After this time, the battery may lose the ability to charge or to hold a charge for substantial periods of time. When this happens, it's likely the battery needs replacement. However, troubleshooting can narrow the problem and ensure you are not wasting money on a battery replacement.
Check Power Adapter Turn the laptop off. Remove any power cords or power sources. Separate the battery from the bottom of the laptop. Slide or press the locking mechanism to unlock the battery. Slide the battery out of the battery compartment. Plug the power adapter into an electrical outlet. Insert the opposite end of the adapter into the charging outlet on the side of a laptop. Power on the laptop. If the laptop does not turn on, the power adapter is not correctly working. If the power adapter is not working, the battery can not charge. Replace the power adapter. If the laptop powers on, the power adapter is properly working. Clean Battery Contacts Turn the computer off. Remove any power cords or sources. Take the battery out of the battery compartment. Dip a cotton swab in isopropyl alcohol. Rub the dampened swab on the battery compartment and battery contacts. Dust and buildup can prevent battery contacts from properly charging. Slide the battery back into the battery compartment. b> Charge and Test Battery Plug the power adapter into the laptop. Charge the battery for six hours. Remove the power adapter. Turn the laptop on. If the laptop turns on and stays on for at least 30 minutes, the battery is holding a charge. If the laptop doesn't turn on or the battery doesn't power the laptop for at least 30 minutes, the battery should be replaced.
Battery Won't Charge Or Short Power Life In Notebook
http://www.daileyint.com/hmdpc/battery.htm
Laptop Battery Depot http://www.laptopbatterydepot.com/problems.asp - clean
Feb 24, 2013 | Computers & Internet
No charging battery
Nov 01, 2012 | Computers & Internet
Toshiba satellite l305d-s5934 Won't charge battery dont power On
Oct 25, 2012 | Toshiba Satellite L305D-S5934 Notebook
Lap top Battery problem
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then -The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty.Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced.If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard.This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Aug 02, 2012 | MSI Computers & Internet
My battery is not charging
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then -The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty.Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced.If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard.Thiscan be repaired but it requires the laptop to be completely dismantled to getat this power socket and repair. If you cannot DIY then I suggest you get aquote first.
Jul 24, 2012 | Computers & Internet
Laptop will not charge battery. Issue with internal power converter, etc.
The motherboard has charging circuits built in to regulate the charge to the main battery, in rare causes it fails leaving a choice to attempt a repair or replace the motherboard. I suspect this is what has happened to your system.
Apr 05, 2012 | Lenovo IdeaPad U550 (374955U) PC Notebook
No problem just bought a mpd-1760 from someone its brand new never even been used ,but no instructions/need to know how long to charge battery for first time or at all //charging time for battery to watch...
To charge the battery back you want to
  1. Turn the power off the DVD player first as the battery pack will not charge with the power on.
  2. Attach the battery pack to the player.
  3. Connect the AC power adapter and the power cord to the player.
  4. Charging will now start and the Power/Charge indicator should now be orange.
  5. Do not unhook either cord until the Power/Charge turns off.
  6. Time of charging is approximately 4 1/2 hours.
  7. The battery pack will more than likely get warm while charging. This is normal. Keep it as much in the open as you can for the best ventilation possible.
  8. You will get a low power indicator on the screen when the battery has a low charge.
As for playback time you will get about 2 1/3 hours of actual playback and about 4 hours of standby with the DVD player actually on.
Regards, Tony
Apr 12, 2011 | Mintek Televison & Video
No power will not trun on
Hello
Plug in the printer power cord into electricity to charge the battery.The battery might need charging if the On light flashes green it indicates that the battery is charging.
Switch ON the printer, the battery charging icon (lightning bolt icon) flashes above the battery icon on the printer screen to indicate that the battery is charging.
If the battery is charged and the printer does not turn on with the battery power, unplug the printer power cord, if it is plugged in. Open the battery compartment and remove the battery. Wait for about 10 seconds, and then reinstall the battery.
An empty battery should fully charge in approximately four hours when the printer is not in use. If the battery still does not charge in 4 hours,you should replace it
Good luck
Apr 23, 2010 | HP PSC 2210 All-In-One InkJet Printer
Lenmar 1000W Power Inverter Logo
112 people viewed this question
Top Lenmar Electronics - Others Experts
Are you a Lenmar Electronics - Other Expert? Answer questions, earn points and help others
