Question about Canon imageRUNNER 400S Copier
Error 803 displays - Canon imageRUNNER 400S Copier
  • 1,219 Answers
these means that you have problems vith voltage that comes on the fluorescent scanning lamp.
If you do not want to call service and have some electronics skills write me on emma.servis@gmail.com for service manual.
Hope that helps!
Posted on Aug 23, 2010
I have a Xerox workcentre 7345 and reported that the transfer belt cleaner needed to be replaced. I replaced it and the message is still appearing.
Hi, In my printer Xerox 7245 display it appears Replace Transfer belt error. So please guide me how to reset value without replacing ETB
Jan 14, 2011 | Xerox WorkCentre M-24 Color Copier
I keep getting the error message e 803. What is
The Scanning lamp has gone dark at the ends due to old age, or perhaps a fault in the composite DC Power supply.
Try replacing the flourescent lamp first.
Apr 22, 2010 | Canon imageRUNNER 400S Copier
Error 805 and 803
Hello sir; The error code you display 803 & 805 could be come from same problem, both all are composite board 24 volt supply problem, replace composite board will take care this problem. good luck.
Jul 24, 2009 | Canon imageRUNNER 400S Copier
E 803 when machine is turned on
Hello sir;The error code you display including so many mesnings; transfer unit level switch, left front interlock switch, DC power supply, DC fuser board, DC driver board, CPU board, DC power cut relay.
My suggestion go to check al those switch first if still don't work then go to others.
Jul 18, 2009 | Canon CLC 1120 Color Copier
Error code E677
677 error is printer board error.u check conection( lpt port or usb cable loose conection.printer board loose conection.remove all conection and conect all conection i mean reinsert conection ) then this error come u will service u r printer board(re insolve printer softwere).803 error is expouser lamp end side blocked change u r lamp u r 803 problem is ok
Jun 01, 2009 | Canon iR 1600 Laser Photo Printer
Cannon gp200 - we have an error code 803-switch power on and off
we have an error code 000 - the message is switch power on and off- we tried this and the same code/message shows again please answer
Apr 03, 2009 | Canon Office Equipment & Supplies
The machine is a SONY VIDEO CASSETTE RECORDER UVR 1400 AR
uvw-1400 error 02-803 is "tape tension error when threading". possible bad threading motor or threading mechanism.
Feb 11, 2009 | Sony Betacam SP Small Videocassette 30...
CANON IR 400 COPIER - ERROR - E677
Sep 11, 2008 | Canon imageRUNNER 400S Copier
Samsung Error Message
Error message - Internal Printer Error (J) ...... RX ......L1P01 on a Samsung ER 7000 Cash register
May 04, 2008 | Samsung SC-L770 Camcorder
E071 0003
E-071 0003: There is an error in the rising edge timing of the signal plate detected by the C sensor.
The transfer drum isnt rotating or the machine "thinks" the drum isnt rotating. Check for mechanical interferance and check the drawer connectors for paper and debris
As for the guest with the E-803 error, thats not really the same thing at all. I guess both error codes have a "3" in it but thats about all.
E-803: During operation the CPU does not detect a 24V output for 5 sec while the transfer unit, the left door, and the delivery door are closed.
Check the aformentioned doors and switches but most likely it is the power cut relay that is faulty. The relay is located on the lower left hand side beside the main power supply. The relay contacts become pitted and burnt over time.
Apr 15, 2008 | Canon CLC 1120 Color Copier
Canon imageRUNNER 400S Copier Logo
old marine
old marine
