Question about Treadmill Doctor Proform J6Si Treadmill Rear Roller
My Proform J6Si will not start. The power turns on and everything lights up, but there is no speed and the motor is not running. The incline works, but that is it. Any ideas on how to get it to move??
  • 16 Answers
SOURCE: Proform 515s treadmill motor won't start
If the colse buttons make a chirping noise when you push them the console should be Ok. If there is no chirping noise with the push it is a bad console. If everything but the speed works it will probably be your motor controller that is bad.
Posted on Apr 14, 2009
SOURCE: proform 360p stuck on incline
I had the exact same problem.
This usually happens if you switch it off at the mains while the incline is adjusting or is somewhere other than lowest. You should always make sure before finishing off, to lower everything.
Now for the solution: If you open up the case it has 5 or 6 black philips (cross head) screws (use your user manual if you don't have your original go to proform and find the support link and download the .PDF if your model is not available get the one before or after in the same model product line (model number is below the power input)).
Make sure you remove the power before opening the cover, obviously.
Anyway, once opened, you should find a sheet of paper wrapped around in some plastic wallet. On that paper it should explain everything. Try not to mess with too much things in the settings, otherwise you might mess it up badly.
Mine is something like: Hold the speed up (+) button and then while holding the button insert the key - that will get you to the service menu (obviously the power has to be connected).
Once in the menu pressing the incline up does a self-calibration (maximum up and maximum down) after that it should be perfect.
Remove the key any time to come out of that mode and resume normal operation.
I may not find this place for any more replies 'cos i only found this site by accident. While looking for info. on my burnt out motor model: PETL 3013.6 .... But i have come across someone selling a faulty one on ebay for like 5 quids... it's picking it up the trouble!
Posted on May 31, 2009
  • 64 Answers
SOURCE: Pro Form C525. Then incline motor works with a
The repair for this is usually a new elevation motor. However if elevation isn't a big issue for for you, you can disconnect the elevation motor and use treadmill like that. The elevation motor doesn't go out that often. You should check with a local repair person. They may have a used one laying around. I usually keep one on hand to test with.
Posted on Nov 17, 2009
SOURCE: treadmill belt runs very slow and stops when I get on
proform 625 belt slips cause
Posted on Jan 28, 2010
SOURCE: incline does not work
ProForm Treadmills have a reset procedure for the incline function. With the key inserted in the console, activate the incline; while the incline is changing, remove the key. Wait 30 seconds, then replace the key. The incline should to maximum, then to minimum, resetting its limits. It worked for mine just 10 minutes ago; the procedure is in the manual if you have it. Good luck!
Posted on Apr 18, 2010
Testimonial: "Great thanks"
Incline does not work but incline motor runs for 3 to5 seconds proform415ct
if the motor tries to work but incline does not go up something is jammed on the treadmill or the incline motor is bad
Oct 17, 2014 | Proform 415 CT - Treadmills
Incline problem
All icon models are the same. The easiest way to incline calibration is to start the treadmill, push the incline up button and then after you release the button, remove the safety key. Replace the safety key and the treadmill should calibrate.
If that doesn't work, press the stop and speed up buttons and hold, then place the safety key in place. This will bring you to the speed/incline calibration. Press stop again. now press incline up. This will run the incline calibration.
You may need to remove the hood and manually with a drill lower the motor. Using a slot screwdriver bit, lower the motor a bout 50 turns and then try the procedure above again if necessary.
Mar 05, 2014 | Proform Exercise & Fitness
Proform V650 Treadmill - Main motor does not turn
The board will most probably need replacing. Almost certain.
I repair this brand for the manufacturer.
Nov 06, 2013 | Proform Exercise & Fitness
Proform 400 GI - Treadmill
go under the HOOD cover the instruction for RUN the software calibration for easy diagnostic , and fix it.
God bless you
Jul 07, 2013 | Proform 400 CT Treadmill - Treadmills
Hello i have a proform crosswalk sport treadmill and when i turn the speed on it shows a reading for a couple of seconds, but doesn't come on. The incline works just fine. The motor will turn manu
adjust the REED switch see the diagram attached m clean it+test for open or faulty with DVOM, tight the connector very well,However try to RUN the software calibration and fix it. see the diagram attache too for speed sensor, adjust it and test it , clean it, and tight very well the connector.God bless you3_22_2013_4_18_58_pm.gif3_22_2013_4_19_19_pm.gif3_22_2013_4_19_33_pm.gif
Mar 22, 2013 | ProForm CrossWalk Sport Treadmill
My proform 750 CS will power up and incline but the motor won't start moving. While performing troubleshooting on the MC-60 SCR Motor Controller the D11 LED is the only LED lit up on that circuit
please LUBE the deck belt+rollers bearing. see the video attached.
If the problem persist TIME to replace the old deck belt board.
This happen because the lack of maintenance schedule in LUBE.
God bless you
note:forget it the LEDS troubleshooting, you must see the functions ONLY when there are electronic problem with the electronic board+sensor2_4_2013_6_01_12_pm.gif
Feb 04, 2013 | Exercise & Fitness
Speed and incline button not working
Please RUN the software calibration for diagnose, troubleshooting and fix it. However see the diagram attached, and lube the gear, shaft too.
God bless you
Jul 12, 2012 | Treadmill Doctor PROFORM 540 TREADMILL...
Treadmill proform model 831.29605.0 (proform xp 550e was working fine till I Changed the walk belt. After changing belt, display looked ok but treadmiil would non trurn on. Operated incline. incline
1) i recommend that you lube very well deck belt + rollers bearing
2) see the videos.
3) see the block
4) Try to RUN the software calibration, for troubleshooting.
5) measure the input voltage motor, if there are the motor need repair.
6) Measure the output voltage board, for input voltage board, if there are NOT, the board is faulty.
Jun 27, 2012 | Proform Treadmill Motor Controller 241697
Lower incline
Dear Sir:
I STRONG recommend RUN the calibration Software Inmediately, for eay Diagnose and troubleshooting, most of them instruction has coming in the Hood of Motor, follow the instruction or use your instruction manual.
Adjust the sensor speed attached the diagram. Tight the wires from sensor speed. The sensor speed can be faulty. Adjust the Pot with the gear in the same motor, both can be faulty. And finally the main motor board can be wrong. sincerely.
God bless you.
ernesto cuadra
managua, nicaragua.
Feb 12, 2012 | Proform Exercise & Fitness
Every time I put the key in my Proform 590T, the incline rises for a second, and lowers for a second while displaying 2 hash marks. Then, the home screen comes. All speeds work fine for walking/running,...
how long have you had this treadmill? usually when the hash marks appear it means that the console control board is not recognizing the incline motor. even though it does run a little bit that is just the basic test that the treadmill starts but resets after it does not sense the incline motor. These motors rarely go bad so it is more than likely your motor controller that is causing the issue. I have seen this case many times as i am a fitness repair technician. The motor controller fixes the issue 9 times out of 10
Aug 05, 2010 | Proform 590T Treadmill
Treadmill Doctor Proform J6Si Treadmill Rear Roller Logo
63 people viewed this question
Top Treadmill Doctor Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Matt Olenzek
Matt Olenzek
Are you a Treadmill Doctor Exercise and Fitnes Expert? Answer questions, earn points and help others
