Question about Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Vertival Color Lines
I just bought my LCD tv and now i must deal with 2 vertical lines on the left and right sides, why is this happening?
  • 1 more comment
  • Anonymous May 31, 2008
    I have the same problem, but my lines are on the right side of the screen.
  • Anonymous Oct 26, 2008
    I have a red, thin vertical line about 3" from the right side of the screen. It appears to be in the transition zone between HD and non HD. It appears when the TV is cold and first turned on but disappears after 15 minutes. My TV is the 46" model.
  • kaht22 Dec 16, 2008
    i have lines on each side and down the middle. it seems to be getting worse.
I have the same thing on mine and it is just outside where the transition from HD to non HD is. I went back to the place that I purchased it from last year and as soon as I said I had a line in it he told me Toshiba will call me and they are replacing these tv's!
Posted on Oct 04, 2008
We had the same thing happen to us on the right-hand side. A technician told us yesterday that the Motorola Cable Box (supplied by Shaw Cable) places a border on Non-True HD Channels. Because we didn't place our picture setting to 'full-screen' each time we viewed these channels and burn line was created. He gestimated a replacement screen runs about $800.00 Canadian, but we have a 3 year extended warranty and will receive a new TV. He also said it happens on all big screen tv's that use a cable box creating borders on Non-True HD Channels.
Posted on Sep 09, 2008
I have an LG 2009 60ps60 plasma TV with multi color vertical lines on the left side of screen. Is there a board I can change to correct this problem??
1. Identify the TCON board.
2. Reset the Left side ribbon cables on the T-CON board
3. Replace CON board if you find a spare
Apr 13, 2016 | LG Televison & Video
I HAVE A SAMSUNG 50 INCH TV, THAT JUST STARTED HAVING A VERTICAL LINE ON LEFT SIDE OF SCREEN. WHAT'S THE CAUSE AND HOW DO YOU FIX IT ????
samsung lcd tv: vertical color lines *PLEASE HELP* - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - samsung lcd tv: vertical color lines *PLEASE HELP*. by justinwu86 / March 31, .... In reply to: Vertical colored line on left side of screen. yeah the pannel has ... Red/Blue vertical lines on display
Jun 11, 2015
Vertical Lines help samsung led lcd tv
Oct 4, 2014
Thick vertical line in Samsung 52' TV
Jul 5, 2013
Thin vertical line on Samsung LCD TV
Feb 10, 2010
More results from www.cnet.com
Jan 03, 2016 | Samsung Televison & Video
Black and white vertical lines on left sided of screen. Black and white vertical lines vary in width. Left of vertical lines is wrapped video from right side. This is happening on all inputs. I have very...
If its under warranty take it back immediately!!! If not you will need to have the set diagnosed to pinpoint the problem. You could be looking at a faulty t-con/panel connection (easy fix) or a bad t-con board(inexpensive) or a LCD panel(very expensive) failure !
Oct 08, 2013 | Samsung UN60C6300 60 in LCD TV
Vertical lines
you could have a faulty LCD/t-con ribbon connection, or a failing LCD panel. I would suggest you try and reseat the ribbon cables to the panel and t-con, if you are comfortable doing this!
Apr 27, 2013 | Samsung LN52A550 LCD TV
Fine color vertical lines in right and left side of screen
One of two things could be wrong.. One is the digital board and or connector. the second is that the LCD display is going bad..
Jan 28, 2009 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
Philips Flat Screen Green Lines
The LCD Panel is defective. You will need to replace the LCD Panel. It will probably be cheaper to replace the monitor since the LCD Panel may exceed the monitor cost.
Single lines of single color (red,green, blue) are LCD panel failures.
1 or 2 lines of single color are LCD Panel failures.
Multple color lines could be anything so in this case you start by checking the power circuit.
Nov 28, 2007 | Philips 20 in. TV/VCR/DVD Combo Flat...
Toshiba REGZA 42 in. Flat-Panel LCD HDTV Logo
502 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
