Question about Dell Inspiron 1420 Motherboard - KN548
Coffee drop into my laptop when turn on no display and dose not boot
  • 480 Answers
HI, If your Dell computer is under an "Accidental Damage Warranty". you can call dell to request for a replacement. If not, you might need to replace the Motherboard on the computer.
Cheers!!!
Posted on Aug 23, 2010
Semi automatic espresso machine shot won't stop pouring
Continuous water flow indicates a stuck valve. These suggestions may help depending on type of machine:
Full Automatic (Super Automatic); Valve needs back flushing, cleaning, or replacement. There is an off chance the dose needs re-programing.
Semi-Automatic; Valve needs back flushing, cleaning, or replacement. Check programing for dose.
Manual; Most manual espresso machines require operator to stop dose. (By releasing dose button or lever)
Arm style Manual "Jaw Breaker"; These are physically chambered dose which are unable to constant dose. Bad seals needs replacement (if you can still find them)
final comment to this 'open' question; All coffee machines needs periodic cleaning. Most espresso machines needs back flushing (not to be confused with de-scaling.) Usually a cleaning tablet or powder is poured into dose chamber (or back flush portafilter) and cleaning cycle or long dose is performed. This cleaner will loosen baked in coffee and push it out the pressure relief pipe. The machine will need to go into a normal dose cycle without coffee to flush the cleaner out of the valve and dosing system. Do this several times. Good daily cleaning habits will keep your machine in top condition.
Sep 30, 2017 | Coffee Makers & Espresso Machines
Coffee stopped brewing well, coffee now brews weak. Even with increased coffee grounds. Clean button won't turn off. Even after 2 clean cycles.
Chances are there are built up scales inside the brewer. Are you using regular water? If so, you may have to descale it. Look for a food safe descaling chemical which you may have to flush with clean water in several cycles. Another solution is to take it apart and clean it. Problem is, you have to be skilled to do this.
Jun 19, 2016 | Mr. Coffee BVMC-PSTX91 10 Cup Programmable...
My asus laptop has no screen display and can sense flash disks
First you thing to check is when you turn the laptop on it should make a single beep sound. if not then in means you need to replace you cpu (central processing unit} or known as a processor. thy tend to blow wen the cpu dose not get serviced. the thermal compound on the laptop cpu must be removed properly and reply st every 3-6 mouths max. If it dose beep then take a normal PC monitor and connect it to your laptop and see if that works. if it dose work then it means that the screen is busted or you should pess the screen buton on the keyboard
Nov 02, 2013 | ASUS Eee PC 1000H Laptop
Ho do i clean the taming filter n my ura F9
you can not, not with out taking machine apart my mom put coffee in the top powder fill and forgot to push the powder button grinder then put more coffee in and when the piston tried to tamp the coffee in was completely clogged up error code came up , $ 250 to service I completely took unit apart I would not req. in less you are a very tech minded person nightmare of parts all working together but anyway the tamping screen is screwed to the piston and is in middle of the machine water is push from the bottom, thur coffee , thur screen , thru piston, up thur a small hose and falls down into the service head and out the two ports to cup I was able to complete remove coffee and remove screen and clean got machine back online ran cleanning program all ok if machine completely clogs and error code comes up it can not be fixed any other way if coffee comes out slow or you get a short cup of coffee you can run a cleaning program to remove the coffee stuck in the piston area the problem is caused by old coffee grounds sticking to the dosing part this part both puts coffee into the piston and take it out make a cup of coffee and look down the door on top of the machine with a flash light when the dosing door opens up and the used coffee puck is drop into the used bin , if you see used grounds on top of the dosing part then next time you make coffee it will end up mixing with new coffee after a while this can cause clogging . try to use diff. coffees some are ground to fine and most of the problems come from the powder dosing door. by the way I and my mom both have a F9 unit I have had the slow and short problems with my machine but it only happens when I use the powder dosing door good luck to all steve
Dec 31, 2010 | Jura Capresso Impressa F9 Espresso Machine
Coffee drips very slowly and descaling not helping
I had the same problem. Check and make sure your dose is not turned up too highor your grind is not set too fine? Turning the dose knob clockwise decreasesit. I have ended up with my grind set on 13 which is more coarse than averagefor the beans I'm currently using. Adjust the grind while the grinder isworking by one number and then brew 3 or 4 coffees before changing it again. Ittakes that long for the grind to be seen in the coffee. The higher the number,the coarser the grind will be. Any time you use different beans it is possiblethat you'll have to reset the grind.
Oct 31, 2010 | Saeco Vienna De Luxe Espresso Machine
My coffee is to strong
You can change the coffee dose that you put in each cup by lifting the cover on the bean hopper (where you put beans), turn the dose knob (small knob closest to front of machine) clockwise to decrease the amount of coffee used for each cup. Set the knob and then press the coffee button. Gradually decrease the dose until you find the taste you like.
Sep 25, 2010 | Saeco Spidem Villa
Laptop boots up but after nothing.
Hard drive is shot. replace and then re install operating system
Jul 05, 2009 | Toshiba Satellite M45-S265 Notebook
My AcerOne Dose not Boot... The Adapter light is On wen Plug in, The power swich turns On. but Nothing Happens. No Post or nothing. What could be the problem ??????
Hi there.
Take out the laptop battery and try to boot the machine on AC power only.
If it boots turn it back off and reinsert the battery and try to boot again.
Please post back.
Good luck
Jun 04, 2009 | Acer Aspire One Netbook 8.9" Notebook
Need to adjust coffee dose for odea go
SEE THE VIODEO AND OTHER LINKS ON TYHAT SAME PAGE:
ALSO:
Saeco Odea Go adjusting coffee dose Questions
May 21, 2017 | Saeco Odea Go
Dell Inspiron 1420 Motherboard - KN548 Logo
102 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
