Question about Panasonic Heating & Cooling
I am buying a Panasonic CU 73ke split type aircon is this a legitimate model of Panasonic? Thanks. Benjie Calma
  • 19 Answers
SOURCE: Split system airconditioner Panasonic model CU-A28CKR.not responding to remote
some of the samsung units need to be reset if you have a new remote..contact your nearest agent for that aircon they will give you a code to type in using the remote control.if this does not work you might have to replace the internal pc board.good luck
Posted on Nov 25, 2007
bobotfel
  • 236 Answers
SOURCE: not turning on
Hi
Try to reset the unit by disconnecting the power supply for 10sec. and operate the unit. If it wont work replace your Room Air and Coil Thersmistor or test the thersmistor with mulitester. The resistance reading of thermistor is 10 kilo ohms @25deg. C room temp. If it is shorted or open the unit wont operate.
Hope this can help :)
Posted on Jan 08, 2009
  • 400 Answers
SOURCE: WATER LEAKING FROM MY SPLIT TYPE LG AIRCON
1. Do not set the aircon too low temperature in overcast weather, this will cause ice ups and water dripping. Optimal comfort zone temperature is 24c.
2. You need to open the grill cover on the front of the aircon which unclips either end left and right with a finger pressure. You will find two filters which can slide out and should be cleaned. First tap them together to remove dust, then you can wash them with mild soap and cold water.
3. There is the third possibility that an insect has made a nest in the drainpipe. You should look on the outside of the building and locate a plastic drainpipe. You can either blow into this pipe with your mouth or get a blower. This will unblock any restriction in the drainpipe.
Goodluck and ratemeplease.
Posted on Mar 19, 2009
  • 23 Answers
SOURCE: i have a sanyo aircon split system and i need to know the icons
the icons are snowflake = cool, raindrop = de humidification, fan blade = fan, sun = heat. hope this helps.
Posted on Jun 15, 2009
  • 334 Answers
SOURCE: drain line obstructed Fujitsu split unit aircon model ASA12ASHTW
The best way to clear the drain line is by using a shop vac and sucking out the blockage and the water. This will make sure all the goop in there comes out. Let me know if you need anything else.
seth
Posted on Jun 28, 2009
Airswing function not working on panasonic aircon split system
Remove side screws and pull out the PCB compartment, and check wiring to swing motor. Most of the time, the clip would have been removed on transportation or during service time. If connection is good, replace swing motor. Thanks.
Feb 05, 2011 | Panasonic CW-XC83HU Air Conditioner
I have an split-type aircon (brand: General) remote control AR-DL2. it has power and display when i put on batteries. but the aircon unit does not respond to the remote control. what do i do to fix...
i have general electronic ac brand i cant found universal remote can u find one for me what are the universal remote that compatible for my ac tq
Nov 29, 2010 | Heating & Cooling
My carrier split type non-inverter aircon always blinking
It indicates afault within the unit. Give Carrier a call and get it serviced.
Mat
Jul 01, 2009 | Carrier 36KCARMS Air Conditioner
Panasonic Split System Air Conditioning.
we have a old national air con cassette model cu-5chv11p , works for three days , then controller comes on e4 error ,and then switches off , and will not reset .
Dec 28, 2007 | Heating & Cooling
Try turning of the power to the unit.Wait 60 seconds and try it again.This may reset the unit.
Nov 24, 2007 | Heating & Cooling
Heating & Cooling Logo
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
