Question about Nintendo 64 Console
The reset button is stuck down and i dont know what screwdriver it needs, how do i get it unstuk?
    Genius:
  • 1,175 Answers
Spray some WD40 around it and see if it loosens at all
I'm not sure if that model needs a torx driver to open it but I would think a #8 driver might work
Posted on Aug 23, 2010
Keurig power button
I am not familiar with the button itself but I am familiar with stuck buttons. If this is an analog (push down button then is most likely stuck in cover or housing. For this you can use a pin or small screwdriver and gently pry it back out from the side it is stuck on. If this is a digital (touch button) then you will most likely have to replace the board it is on. One thing you can do is take it apart, unplug the board the button is on, leave it for a few seconds and plug it back in. That might reset this.
Jul 12, 2014 | Keurig Vue Brewing System
MY Cricket MSGM8 2 is stuck on the starup screen for the last 2 days my phone has tried to starup but only gets stuck on the startup screen and every 15 minutes of it being stuck it simply resets its self...
I have the MSGM8 ii phone which got stuck on the logo/start/splash screen the looped for hours in this pattern. Solution: 1) Take the battery out of the phone. 2) Hold down the camera button on the side simultaneously with the power on/end call button, 3) If you have a volume button depress that simultaneously as well. You will be holding these buttons down for 5 seconds. The phone will either vibrate, then backup data, and go to your main screen. I had to give this several tries before it finally went back to the normal screen. This has now happened to me on 2 different occassions and this is the only thing that works.
Jul 02, 2011 | Cell Phones
FEATURE BUTTON IS STUCK ON, MUST PUSH ANSWER BUTTON TO ANSWER PHONE CALLS.
with this nec phone. you need to unplug it all . stick a small screwdriver on the feature button to pop it up and off the board (since its stuck) and plug it back in. to reset the phone.,
Mar 17, 2011 | NEC DTH-8D-1 Corded Phone
How to change my vivitar vivcam 8025 language preferences....its stuck in some language i dont even know
Press the HOME button to bring up the main menu. Touch the pliers and screwdriver symbol to bring up the setup menu. Language should be the eighth item on this menu.
Dec 27, 2010 | Vivitar ViviCam 8025 Digital Camera
Game stuck in ps3
whils switched off. hold down the eject button and turn on, you will hear a loud fan noise this is ok, the game will then eject.
May 22, 2010 | Sony Playstation 3 (PS3) Console
My aiko tv is stuck on child lock. I have no remote and dont know how to get the child lock off.
You can try turning it on and pressing all the buttons down at the same time, that sometimes will reset tv's to factory.
May 12, 2010 | Televison & Video
It makes me type baclwards and frezzes and makes a clicking noise when i try to type why ?
You might have a problen with your laser lens, umd drive or umd its self. do any other umds work?if not and you still have a warranty i strongly recommend you get a new one before your warranty expires, if youd hate to send it back to sony because they might give me you the new PSP that cant be downgraded, you could just open up your PSP and clean the UMD drive (once you open your PSP the warranty Expires straight away,so that wouldnt be something i would do)if you still want to do it follow this simple steps.
1. How to open your PSP
Tools needed:
One small size Phillips Screwdriver, if you dont know what that is you should probably not try to open your PSP, ok its something that look like this X
On picture 1 you will see the 5 screws that need to be removed to open the PSP, marked with red arrows. If you are not going to remove the whole inside of the PSP then dont bother to remove the 2 screws marked with green arrows. There is also no need to remove the whole label inside the battery compartment. I just did it for this picture.
2. How to remove the LCD screen
Its quite easy to remove the LCD screen, just use a small flat screwdriver and put in the side like you see in the picture and pry it open. Now dont slip, you dont want to put a big scratch in the LCD screen.
Now it will look like this, and you will see the screen is attached with 2 orange flat cables. Always be extra careful when opening this type of clips, they can very easily be damaged.
3. How to fix stuck L/R buttons
This is how it looks like when you have the stuck button problem, its not very common, but I have seen it a few times. Fortunately its easy to fix. It should be noted that Sony have fixed this issue as far as I know on new productions, so new comers shouldnt be worried about this.
Before you start doing this, check what part of the plastic that actually get stuck and then just use a nail file to remove some of the plastic, put it back, test again if it still get stuck. If it does then file down some more, but be careful not to remove to much or you will end up with a lose button instead.
Copyright http://www.pspmod.com/forums/hardware/14387-psp-wont-read-games-repeted-clicking-noise.html
DigitalJedi1 www.iPSPhone.webs.com
be sure to visit my site for fre Mp4 Movies & more
Jun 20, 2009 | Video Game Consoles & Games
My Ipod is frozen
OK what you need to do is reset it. To do this you will need to hold down the menu and select buttons simultaneously for approx 6 seconds until the apple logo appears on the screen. This should reset and un freeze your ipod.
Try this and let me know how you get on.
May 12, 2008 | Apple Mini IPod
Pantech c120, stuck on vibrate alert
press the * button and hold it down that should take it off vibrating mode
Dec 28, 2007 | Pantech C120 Cellular Phone
Screen Stuck
The Samsung YP-F1 has a reset button located under the black Samsung cover plate. It can be gently removed via a finger nail or mini flat blade screwdriver. Once plate is removed a hole labeled reset will be seen. Use something like a paper clip and press in. MP3 will power down/reset. MP3 data is also retained after reset.
Nov 03, 2007 | Samsung Yepp YP-F1X MP3 Player
Nintendo 64 Console Logo
111 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
